0015658 | ParaView | (No Category) | public | 2015-08-18 10:00 | 2016-08-12 09:59 | ||||
Reporter | Menno Deij | ||||||||
Product Version | 4.3 | ||||||||
Summary | 0015658: Gradient Palette gives different SurfaceLIC | ||||||||
Description | As per title: - a data set visualized with SurfaceLIC - change Backgroun Color Palette to "Use Gradient Background" the SurfaceLIC changes completely. | ||||||||
Tags | SurfaceLIC | ||||||||
Project | TBD | ||||||||
Attached Files | slic_nogradient.png [^] (172,590 bytes) 2015-08-18 10:00
slic_gradient.png [^] (174,860 bytes) 2015-08-18 10:01 | ||||||||
(0035016) Menno Deij (reporter) 2015-08-18 10:53 |
I just realized this only happens when the input data of the SurfaceLIC is cell-centered. Point-centered data is not showing this problem AND is giving a much better SurfaceLIC. So much better that I wonder if it should not even bother with cell-centered data. |
(0035107) Utkarsh Ayachit (administrator) 2015-08-31 16:15 edited on: 2015-08-31 16:24 |
Schuyler, can you check is the issue exists with OpenGL2 backend? Actually, I just realized that the plugin is not yet active in ParaView with OpenGL2 backend...maybe you can modify a VTK example to try coloring by cell data. |
(0038870) Kitware Robot (administrator) 2016-08-12 09:59 |
2015-08-18 10:00 | Menno Deij | New Issue | |
2015-08-18 10:00 | Menno Deij | File Added: slic_nogradient.png | |
2015-08-18 10:01 | Menno Deij | File Added: slic_gradient.png | |
2015-08-18 10:08 | Menno Deij | Tag Attached: SurfaceLIC | |
2015-08-18 10:53 | Menno Deij | Note Added: 0035016 | |
2015-08-31 16:15 | Utkarsh Ayachit | Assigned To | => Schuyler Kylstra |
2015-08-31 16:15 | Utkarsh Ayachit | Note Added: 0035107 | |
2015-08-31 16:24 | Utkarsh Ayachit | Note Edited: 0035107 | |
2015-09-23 10:14 | Schuyler Kylstra | Status | backlog => active development |
2015-09-29 14:52 | Utkarsh Ayachit | Assigned To | Schuyler Kylstra => |
2016-08-12 09:59 | Kitware Robot | Note Added: 0038870 | |
2016-08-12 09:59 | Kitware Robot | Status | active development => closed |
