0015659 | ParaView | (No Category) | public | 2015-08-18 13:45 | 2015-09-09 21:50 | ||||
Reporter | Dan Lipsa | ||||||||
Assigned To | Dan Lipsa | ||||||||
Product Version | 4.3 | ||||||||
Target Version | Fixed in Version | 4.4 | |||||||
Summary | 0015659: Interactive selection de-syncs when scale, rotate or translate | ||||||||
Description | Load can.ex2 Set Interactive Select Cells On Interactively select some cells Scale the data using the mouse wheel The mouse position and the selected cell do not match up anymore. The same mismatch can be obtained by rotating the object with the right mouse button instead of scale. | ||||||||
Additional Information | commit 4d6826e29bce5a52c2b7edc8cdf06fd75dd6ee41 Author: Dan Lipsa <dan.lipsa@kitware.com> Date: Fri Aug 28 09:47:01 2015 -0400 BUG 0015659: Fix interactive selection + transformation. When interactive selection is enabled, the dataset can be transformed using right click and drag for rotation and middle click and drag for translation or wheel rotate for scale. When doing these transformation the selected cell becomes out of sync with the data. | ||||||||
Project | TBD | ||||||||
(0035160) Utkarsh Ayachit (administrator) 2015-09-03 09:59 |
Merge request: https://gitlab.kitware.com/paraview/paraview/merge_requests/337 [^] |
(0035193) Alan Scott (manager) 2015-09-09 21:50 |
Looks good. Tested remote server, Linux, master. |
2015-08-18 13:45 | Dan Lipsa | New Issue | |
2015-08-18 13:45 | Dan Lipsa | Assigned To | => Dan Lipsa |
2015-08-21 21:52 | Dan Lipsa | Summary | Interactive selection de-syncs when scale => Interactive selection de-syncs when scale, rotate or translate |
2015-08-27 15:12 | Dan Lipsa | Status | backlog => active development |
2015-08-27 15:12 | Dan Lipsa | Additional Information Updated | |
2015-08-28 12:57 | Dan Lipsa | Additional Information Updated | |
2015-09-01 10:44 | Dan Lipsa | Status | active development => gatekeeper review |
2015-09-01 10:44 | Dan Lipsa | Additional Information Updated | |
2015-09-03 09:59 | Utkarsh Ayachit | Note Added: 0035160 | |
2015-09-03 09:59 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
2015-09-03 09:59 | Utkarsh Ayachit | Resolution | open => fixed |
2015-09-03 09:59 | Utkarsh Ayachit | Fixed in Version | => git-master |
2015-09-06 12:17 | Utkarsh Ayachit | Fixed in Version | git-master => 4.4 |
2015-09-09 21:50 | Alan Scott | Note Added: 0035193 | |
2015-09-09 21:50 | Alan Scott | Status | customer review => closed |
