0015670 | ParaView | (No Category) | public | 2015-08-21 04:53 | 2016-08-12 09:59 | ||||
Reporter | Vadim SANDLER | ||||||||
Assigned To | Tristan Coulange | ||||||||
Product Version | 4.3 | ||||||||
Summary | 0015670: Imp: Add possibility to specify exact size of the Tick labels of the Color Map | ||||||||
Description | Currently in the paraview application there is no possibility to specify exact size of the Tick labels of the Color Map. The size of the Tick labels is computed automatically on the base of the size of the render window, size and orientation of the Color Map … etc. Is it possible to implement feature which allows specify exact size of the Tick labels? | ||||||||
Project | ParaViS | ||||||||
Type | feature | ||||||||
(0035054) Mathieu Westphal (developer) 2015-08-25 07:17 |
it may be possible, but please explain why this would be necessary? computed size is not correct ? |
(0035064) Vadim SANDLER (reporter) 2015-08-26 04:09 |
Some people just want to control the size of tick labels to adapt the general aspect of the plot to what is expected for presentations or papers. |
(0035153) Mathieu Westphal (developer) 2015-09-03 05:45 |
Berk say: There are plans to revamp the scalar bar entirely. I want it to use the same labelling code as the Axes Grid (and 2D charts). Some work has happened in that direction, it's not complete yet. I am going to push on it after 5.0. |
(0038872) Kitware Robot (administrator) 2016-08-12 09:59 |
2015-08-21 04:53 | Vadim SANDLER | New Issue | |
2015-08-21 04:53 | Vadim SANDLER | Assigned To | => Tristan Coulange |
2015-08-25 07:17 | Mathieu Westphal | Note Added: 0035054 | |
2015-08-26 04:09 | Vadim SANDLER | Note Added: 0035064 | |
2015-09-03 05:45 | Mathieu Westphal | Note Added: 0035153 | |
2016-08-12 09:59 | Kitware Robot | Note Added: 0038872 | |
