0015685 | ParaView | (No Category) | public | 2015-08-26 10:55 | 2016-08-12 09:59 | ||||
Reporter | Vadim SANDLER | ||||||||
Assigned To | Joachim Pouderoux | ||||||||
Product Version | 4.3 | ||||||||
Summary | 0015685: Box Chart View is not showing the box chart | ||||||||
Description | In the attachement there's a datafile mysample.csv (a 100 integers from 1 to 100) to illustrate the question below. The workflow is: - open the csv file; - open a new view and choose box chart view; - click on the eye of the csv file to display it into that box chart view. You get a box chart which is not what you expect from a box chart (a box with an inside line equal to the second quartile or the median (here 50), its bottom and its top equal to the first quartile (here 25) and the third quartile (here 75) and a whisker. You can actually see what you expect with the Compute quartiles filter. But the question is: what does the box chart view represent after the workflow above? | ||||||||
Project | ParaViS | ||||||||
Type | usability | ||||||||
Attached Files | mysample.csv [^] (398 bytes) 2015-08-26 10:55 boxplot.png [^] (94,893 bytes) 2016-03-03 09:23 | ||||||||
(0035818) Joachim Pouderoux (developer) 2016-03-03 09:23 edited on: 2016-03-03 09:24 |
You have to apply the "Compute Quartiles" filter on your table. This will compute the data necessary to display the box plot. Note that a box plot view is automatically created when applying this filter. I attached the image obtained when applying this filter on the provided dataset. Best, Joachim Pouderoux |
(0035819) Joachim Pouderoux (developer) 2016-03-03 09:27 |
Note: the filter "Compute quartiles" computes the data necessary for the box plot view to make the display. This split the 'heavy' computation part on the data server whereas the plot rendering is performed on the client side. |
(0038878) Kitware Robot (administrator) 2016-08-12 09:59 |
2015-08-26 10:55 | Vadim SANDLER | New Issue | |
2015-08-26 10:55 | Vadim SANDLER | File Added: mysample.csv | |
2016-03-03 09:23 | Joachim Pouderoux | Note Added: 0035818 | |
2016-03-03 09:23 | Joachim Pouderoux | File Added: boxplot.png | |
2016-03-03 09:24 | Joachim Pouderoux | Note Edited: 0035818 | |
2016-03-03 09:24 | Joachim Pouderoux | Assigned To | => Joachim Pouderoux |
2016-03-03 09:24 | Joachim Pouderoux | Status | backlog => active development |
2016-03-03 09:27 | Joachim Pouderoux | Note Added: 0035819 | |
2016-08-12 09:59 | Kitware Robot | Note Added: 0038878 | |
2016-08-12 09:59 | Kitware Robot | Status | active development => closed |
