0015707 | ParaView | (No Category) | public | 2015-09-08 04:00 | 2016-08-12 09:59 | ||||
Reporter | Mathieu Westphal | ||||||||
Summary | 0015707: "Find Data" Selection expansion error | ||||||||
Description | When selecting points or cells using the Find Data dialog, the resultant selection is not expandable, and trying to expand it will result the following warning : Generic Warning: In /home/glow/work/kitware/paraview/paraview/ParaViewCore/ServerManager/Core/vtkSMPropertyHelper.cxx, line 511 Failed to locate property: ContainingCells The selection is then lost. | ||||||||
Steps To Reproduce | Open paraview create a sphere, apply edit->FindData Id = 1 -> runQuery close select cells on "Ctrl" + selection | ||||||||
Additional Information | I tried to look into the issue, but i'm not sure of how responsible tu add this property to the selection source, and why find data selection does not have it. I do not understand what is the use of this property anyway. | ||||||||
Project | TBD | ||||||||
(0038885) Kitware Robot (administrator) 2016-08-12 09:59 |
2015-09-08 04:00 | Mathieu Westphal | New Issue | |
2015-09-08 04:02 | Mathieu Westphal | Steps to Reproduce Updated | |
2015-09-08 04:02 | Mathieu Westphal | Additional Information Updated | |
2016-08-12 09:59 | Kitware Robot | Note Added: 0038885 | |
