0015717 | ParaView | (No Category) | public | 2015-09-10 04:16 | 2016-08-12 09:59 | ||||
Reporter | Mathieu Westphal | ||||||||
Priority | low | Severity | minor | Reproducibility | have not tried | ||||
Summary | 0015717: Polygon selection not correctly recorded by record xml test | ||||||||
Description | Polygon selections ( points/cells) Are not correctly recorded by record test xml. | ||||||||
Steps To Reproduce | Open paraview create sphere, apply tools->record test select polygon cells select the whole visible sphere stop recording clear selection replay the test nothing is selected | ||||||||
Project | TBD | ||||||||
(0038889) Kitware Robot (administrator) 2016-08-12 09:59 |
2015-09-10 04:16 | Mathieu Westphal | New Issue | |
2015-09-10 04:21 | Mathieu Westphal | Steps to Reproduce Updated | |
2016-08-12 09:59 | Kitware Robot | Note Added: 0038889 | |
