0015737 | ParaView | (No Category) | public | 2015-09-18 10:39 | 2015-11-04 21:18 | ||||
Reporter | Joachim Pouderoux | ||||||||
Assigned To | Ben Boeckel (Kitware) | ||||||||
Product Version | 4.4 | ||||||||
Target Version | 5.0 | Fixed in Version | |||||||
Summary | 0015737: Windows ParaView binaries do not have associated icons | ||||||||
Description | When installing the official ParaView-4.4.0-Qt4-Windows-64bit.exe, it appears that the paraview.exe program does not have the ParaView icon resource. The shortcuts to paraview application thus show the ugly default application icon. | ||||||||
Project | TBD | ||||||||
Attached Files | qt-bug.jpg [^] (137,457 bytes) 2015-10-19 03:53
(0035303) Utkarsh Ayachit (administrator) 2015-10-16 13:16 |
I believe this has been since fixed. Do let me know if the nightly binaries have the same issue. |
(0035305) Joachim Pouderoux (developer) 2015-10-19 03:53 |
I tried ParaView-4.4.0-185-g4e6f9a4-Qt4-OpenGL2-Windows-64bit.exe and the issue is solved. However I detected another problem with this version as you can see on the attached image. I have already seen this problem with Qt 4.8.6/7 (4.8.4 is known to work well). |
(0035306) Utkarsh Ayachit (administrator) 2015-10-19 09:04 |
Doh! Okay...guess we'll have to revert the superbuild to 4.8.4. Ben, mind doing that? |
(0035308) Ben Boeckel (Kitware) (developer) 2015-10-19 11:38 |
https://gitlab.kitware.com/paraview/paraview-superbuild/merge_requests/56 [^] |
(0035309) Joachim Pouderoux (developer) 2015-10-19 11:41 |
So ParaView 5.0 will not embed Qt 5.0? |
(0035310) Utkarsh Ayachit (administrator) 2015-10-19 12:56 |
No, it will not. No final version of Qt 5 has a critical fix for Unix that we need. We'll wait till the fix for that Qt bug gets in a release (which seems like will be in time for ParaView 5.1). |
(0035422) Alan Scott (manager) 2015-11-04 21:18 |
Tested master, Linux, local server, OGL2 |
2015-09-18 10:39 | Joachim Pouderoux | New Issue | |
2015-09-18 10:39 | Joachim Pouderoux | Assigned To | => Ben Boeckel (Kitware) |
2015-10-15 21:47 | Alan Scott | Target Version | => 5.0 |
2015-10-16 13:16 | Utkarsh Ayachit | Note Added: 0035303 | |
2015-10-16 13:17 | Utkarsh Ayachit | Status | backlog => customer review |
2015-10-16 13:17 | Utkarsh Ayachit | Resolution | open => fixed |
2015-10-19 03:53 | Joachim Pouderoux | Note Added: 0035305 | |
2015-10-19 03:53 | Joachim Pouderoux | File Added: qt-bug.jpg | |
2015-10-19 09:04 | Utkarsh Ayachit | Note Added: 0035306 | |
2015-10-19 11:38 | Ben Boeckel (Kitware) | Note Added: 0035308 | |
2015-10-19 11:41 | Joachim Pouderoux | Note Added: 0035309 | |
2015-10-19 12:56 | Utkarsh Ayachit | Note Added: 0035310 | |
2015-11-04 21:18 | Alan Scott | Note Added: 0035422 | |
2015-11-04 21:18 | Alan Scott | Status | customer review => closed |
