0015739 | ParaView | (No Category) | public | 2015-09-23 11:37 | 2016-08-12 09:59 | ||||
Product Version | 4.4 | ||||||||
Summary | 0015739: X-, Y-, Z-axis rotation lock does not work with multi-rotation tool | ||||||||
Description | Introduced with ParaView 4.4, you can hold down the x, y, or z button while dragging to lock the camera rotation around the respective axis of the data. This works fine with the default "Rotate" camera manipulator, but does not work with the "Multi-Rotate" camera manipulator. I often replace the rotate tool with the multi-rotate tool when the right mouse button is not as accessible as the left. | ||||||||
Project | Sandia | ||||||||
(0035240) Utkarsh Ayachit (administrator) 2015-09-23 12:34 |
I am going to learn something new today -- I have no idea what Multi-Rotate is :). |
(0035241) Ken Moreland (manager) 2015-09-23 12:38 |
Multi-rotate is a cool variation of the rotate camera interaction. To enable it, go to Settings -> Camera and select it as one of the 3D manipulators. I usually replace Rotate with Multi-Rotate. With multi-rotate, if you click and drag near the center of the view, it will behave exactly like rotate. If you click and drag near the corners, it will behave like a roll. That way you can get all three degrees of rotation with one button. That's why it's so nice to use on Macs that have only one mouse button. I think when you hold down x, y, or z, it should rotate the same way that the rotate interaction does now. |
(0038897) Kitware Robot (administrator) 2016-08-12 09:59 |
2015-09-23 11:37 | Ken Moreland | New Issue | |
2015-09-23 12:28 | Ken Moreland | Project | TBD => Sandia |
2015-09-23 12:34 | Utkarsh Ayachit | Note Added: 0035240 | |
2015-09-23 12:38 | Ken Moreland | Note Added: 0035241 | |
2016-08-12 09:59 | Kitware Robot | Note Added: 0038897 | |
