0015770 | ParaView | (No Category) | public | 2015-10-12 08:39 | 2016-08-12 09:59 | ||||
Reporter | Eelco van Vliet | ||||||||
Product Version | 4.4 | ||||||||
Summary | 0015770: Not all numpy funtions can be acccessed in PythonCalculator | ||||||||
Description | I would like to clip my data field using the PythonCalculator in order to be able to clip the largest vectors from a data array Normally I did this with minimum(0.1, mag(U))*U/(mag(U)+1e-6) But I noticed that minimum does not work anymore. Also other useful numpy routines like clip do not work in 4.4. I would like to do clip(mag(U), 0, 0.1) But this gives 'name' clip ' not defined error. Other numpy function like sin, square, and sqrt are available. Is it possible to include the whole list as given here: http://docs.scipy.org/doc/numpy/reference/routines.math.html [^] | ||||||||
Additional Information | I found that the following PythonProgramableFilter does more or less what I want. But I used to do this in a one liner in the PythonCalculator. Anyway how to do this easier? from vtk.numpy_interface import dataset_adapter as dsa from vtk.numpy_interface import algorithms as algs import numpy as np import numpy.linalg # input parameter Umax = 1 data = inputs[0] U = data.PointData['U'] alpha1 = data.PointData['alpha1'] def mag(x): return algs.sqrt(x[:,0]*x[:,0]+x[:,1]*x[:,1]+x[:,2]*x[:,2]) Umag = mag(U) Un = U/algs.max(Umag) msk = 1*(Umag<Umax) Uclip = (U*msk+Umax*(1-msk))*alpha1 #print algs.min(Uclip), algs.max(Uclip) #print algs.min(Umag), algs.max(Umag) #print algs.min(msk), algs.max(msk) output.PointData.append(Uclip, "Uclip") | ||||||||
Project | ParaViewVR | ||||||||
Type | feature | ||||||||
(0038906) Kitware Robot (administrator) 2016-08-12 09:59 |
2015-10-12 08:39 | Eelco van Vliet | New Issue | |
2015-10-12 10:21 | Eelco van Vliet | Additional Information Updated | |
2016-08-12 09:59 | Kitware Robot | Note Added: 0038906 | |
