0015771 | ParaView | (No Category) | public | 2015-10-12 09:49 | 2016-02-24 19:36 | ||||
Target Version | 5.0 | Fixed in Version | 5.0 | ||||||
Summary | 0015771: Expose FlyingEdges filter in ParaView | ||||||||
Description | Expose FlyingEdges filter in ParaView. Let's create a new menu entry for "Accelerated Algorithms" or something like that where we can put these filters for now. | ||||||||
Project | Kitware | ||||||||
(0035283) Utkarsh Ayachit (administrator) 2015-10-14 09:26 |
A few more things: + Change the label for the filter so its more readable e.g. "Flying Edges 3D". Currently it's simply called "FlyingEdges3D". Same for FlyingEdges2D + Create a new category to put these filters so it's easier for users to spot these new filters. Maybe create a new "Accelerated Filters" category. |
(0035319) Dan Lipsa (developer) 2015-10-21 09:52 |
See: https://gitlab.kitware.com/paraview/paraview/merge_requests/439 [^] I also added vtkFlyingEdgesPlaneCutter to the list of accelerated filters. |
(0035563) Alan Scott (manager) 2015-12-15 20:11 |
Note to myself: * I don't know how to test well. Tried some simple contours on Wavelet and Mandlebrot. Worked. * Tried Plane Cutter on Wavelet, remote server, plane offset, crashed. |
(0035564) Alan Scott (manager) 2015-12-15 20:16 |
Moving back to todo. It crashed as follows: * Linux, remote server (8 servers - redsky), 5.0.0-RC2 * Added the plugin for advanced algorithms. * Load Whipple Shield 32. All vars on, apply. * Filters/ Advanced Algorithms/ Flying Edges Plane Cutter. Apply. Server side dies. Ask me if you want a call stack with fewer servers. It's a mess, so I haven't included it here. |
(0035589) Utkarsh Ayachit (administrator) 2015-12-17 09:48 |
MR: https://gitlab.kitware.com/paraview/paraview/merge_requests/536 [^] Alan, BTW these filters only work on ImageData -- hence won't work on WhippleShield. I've updated the XML so that filter is not enabled anymore for unstructured grid datasets. I could not reproduce the "Tried Plane Cutter on Wavelet, remote server, plane offset, crashed" crash. Mind elaborating? BTW, these was a bogus "Slice Offset Value" property on the filter that I removed. |
(0035590) Ken Moreland (manager) 2015-12-17 11:32 |
As we add these accelerated algorithms, at some point they should supplant the standard implementation of the algorithm. Thus, when the user hits the contour button in the standard filters toolbar, it should use the flying edges algorithm when appropriate. This is of course contingent on the algorithm being robust and feature rich enough to be a replacement. That might be a longer time scale than just adding another filter. |
(0035591) Utkarsh Ayachit (administrator) 2015-12-17 12:05 |
@ken, yup that's correct. We decided to do it as a plugin for now so people can at least start playing with them without us actually committing to how these continue to work in ParaView in long run. The ultimate goal will indeed be as you say, to supplant standard implementations under the covers. |
(0035792) Alan Scott (manager) 2016-02-24 19:36 |
Looks good. Tried running a contour on Whipple Shield, filters were grayed out. Read in the Turtle tiff stack, slice and contour worked fine. Tested 4 nodes, 32 cores, master, Linux client. |
2015-10-12 09:49 | Utkarsh Ayachit | New Issue | |
2015-10-12 09:49 | Utkarsh Ayachit | Assigned To | => Dan Lipsa |
2015-10-12 09:49 | Utkarsh Ayachit | Target Version | => 5.1 |
2015-10-14 09:26 | Utkarsh Ayachit | Note Added: 0035283 | |
2015-10-21 09:52 | Dan Lipsa | Status | backlog => active development |
2015-10-21 09:52 | Dan Lipsa | Note Added: 0035319 | |
2015-10-21 15:44 | Dan Lipsa | Status | active development => gatekeeper review |
2015-12-11 14:59 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
2015-12-11 14:59 | Utkarsh Ayachit | Resolution | open => fixed |
2015-12-11 14:59 | Utkarsh Ayachit | Fixed in Version | => 5.0 |
2015-12-15 20:11 | Alan Scott | Note Added: 0035563 | |
2015-12-15 20:16 | Alan Scott | Note Added: 0035564 | |
2015-12-15 20:16 | Alan Scott | Status | customer review => todo |
2015-12-17 09:36 | Utkarsh Ayachit | Assigned To | Dan Lipsa => Utkarsh Ayachit |
2015-12-17 09:36 | Utkarsh Ayachit | Target Version | 5.1 => 5.0 |
2015-12-17 09:48 | Utkarsh Ayachit | Note Added: 0035589 | |
2015-12-17 09:48 | Utkarsh Ayachit | Status | todo => gatekeeper review |
2015-12-17 11:32 | Ken Moreland | Note Added: 0035590 | |
2015-12-17 12:05 | Utkarsh Ayachit | Note Added: 0035591 | |
2015-12-17 13:09 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
2016-02-24 19:36 | Alan Scott | Note Added: 0035792 | |
2016-02-24 19:36 | Alan Scott | Status | customer review => closed |
