0015815ParaView(No Category)public2015-11-02 10:402016-08-12 09:59
ReporterDan Lipsa
Assigned ToKitware Robot
StatusclosedResolutionmoved
PlatformOSOS Version
Product Version
Summary0015815: Catalyst should not do work if not necessary
DescriptionCatalyst should not convert the grid if only ParaView Live is enabled and there is no ParaView Live client connected. I think this can be added on
inputdescription.GetIfGridIsNecessary(). The catalyst script passes frequencies for each input and for paraview live. Work is done only if the timestep matches the given frequency.
An extra test can be added for ParaView Live: Work is done only if the time step matches the input frequency and ParaView Live client is connected.
See
http://paraview.markmail.org/search/?q=Some%20questions%20about%20Catalyst%20Live%20Visualization#query:Some%20questions%20about%20Catalyst%20Live%20Visualization+page:1+mid:dum55u5eubo6fzc2+state:results [^]
for the discussion that led to this bug report.
TagsNo tags attached.
ProjectTBD
Topic Name
Typeincorrect functionality
 Relationships
  Notes
(0038922)
Kitware Robot (administrator)
2016-08-12 09:59
Resolving issue as `moved`.
 Issue History
2015-11-02 10:40 Dan Lipsa New Issue
2016-08-12 09:59 Kitware Robot Note Added: 0038922
2016-08-12 09:59 Kitware Robot Status backlog => closed
2016-08-12 09:59 Kitware Robot Resolution open => moved
2016-08-12 09:59 Kitware Robot Assigned To => Kitware Robot
