0015819 | ParaView | (No Category) | public | 2015-11-04 21:03 | 2015-11-05 22:21 | ||||
Assigned To | Alan Scott | ||||||||
Product Version | 5.0 | ||||||||
Target Version | 5.1 | Fixed in Version | |||||||
Summary | 0015819: Backface Representation default | ||||||||
Description | Please change the Backface Representation default to be "Cull Backfaces". This looks much better with Opacity set to non 1. | ||||||||
Project | Sandia | ||||||||
Type | feature | ||||||||
(0035427) Ken Moreland (manager) 2015-11-05 00:03 |
I think this is a bad idea. First, there is no guarantee that the front faces are actually facing out. It is entirely possible that all the "front" faces point inside, so you would not see anything when you culled it. Second, this would never work for a non-closed surface, which is very common. To see for yourself, make a sphere source and clip it. Then turn on back face culling and rotate around. Oops. You can't see the inner surface of the sphere like you should. |
(0035431) Alan Scott (manager) 2015-11-05 22:21 |
I agree with Ken. This isn't actually what I want. I will think it over. Closing bug. |
2015-11-04 21:03 | Alan Scott | New Issue | |
2015-11-04 21:03 | Alan Scott | Target Version | => 5.1 |
2015-11-05 00:03 | Ken Moreland | Note Added: 0035427 | |
2015-11-05 22:21 | Alan Scott | Note Added: 0035431 | |
2015-11-05 22:21 | Alan Scott | Status | backlog => closed |
2015-11-05 22:21 | Alan Scott | Assigned To | => Alan Scott |
2015-11-05 22:21 | Alan Scott | Resolution | open => fixed |
