0015832 | ParaView | (No Category) | public | 2015-11-11 18:49 | 2016-08-12 09:59 | ||||
Reporter | Nico Schlömer | ||||||||
Summary | 0015832: vtkExodusIIWriter: vtk int array converted to double | ||||||||
Description | Writing an Int array to an exodus file, the data is incorrectly stored as double in the file. An MWE ``` import numpy import vtk from vtk.util import numpy_support points = [ [0.0, 0.0, 0.0], [1.0, 0.0, 0.0], [1.0, 1.0, 0.0], [0.0, 1.0, 0.0] ] mesh = vtk.vtkUnstructuredGrid() # set points vtk_points = vtk.vtkPoints() # Not using a deep copy here results in a segfault. vtk_array = vtk.util.numpy_support.numpy_to_vtk(points) vtk_points.SetData(vtk_array) mesh.SetPoints(vtk_points) # TODO use numpy_support here, avoid the copying c = numpy.array([ 3, 0, 1, 2, 3, 0, 2, 3 ], dtype=int) a = vtk.util.numpy_support.numpy_to_vtkIdTypeArray(c) cell_array = vtk.vtkCellArray() cell_array.SetCells(2, a) mesh.SetCells(vtk.VTK_TRIANGLE, cell_array) # add int point data X = numpy.array([7, 8, 3, -2], dtype=int) array = vtk.util.numpy_support.numpy_to_vtk(X) array.SetName('X') pd = mesh.GetPointData() pd.AddArray(array) writer = vtk.vtkExodusIIWriter() writer.SetFileName('test.e') writer.SetInput(mesh) writer.Write() ``` The array `X` is stored as `double` in `test.e`. | ||||||||
Project | TBD | ||||||||
(0038930) Kitware Robot (administrator) 2016-08-12 09:59 |
2015-11-11 18:49 | Nico Schlömer | New Issue | |
2016-08-12 09:59 | Kitware Robot | Note Added: 0038930 | |
