0015834 | ParaView | (No Category) | public | 2015-11-12 16:14 | 2016-08-12 09:59 | ||||
Product Version | 4.4 | ||||||||
Target Version | 5.1 | Fixed in Version | |||||||
Summary | 0015834: Find data/ max fails for variables with spaces in name | ||||||||
Description | Find data is failing for such operations as find max for variables with spaces in their name. I have a dataset that shows this, if needed. (note to self, Windows, data, erg.., pflotran) Linux, 4.4.0, local server. Open the pflotran-00.* files. All vars on. Apply. Find Data. Cells. pflotran-00. Liquid Pressure [Pa]. is max. Run Selection Query. This fails as follows: Error: Failed to evaluate Expression 'Liquid Pressure [Pa] == max(Liquid Pressure [Pa])'. The following exception stack should provide additional developer specific information. This typically implies a malformed expression. Verify that the expression is valid. Traceback (most recent call last): File "<string>", line 8, in <module> File "<string>", line 5, in vtkPythonExtractSelection_RequestData File "C:\Program Files (x86)\ParaView 4.4.0\lib\paraview-4.4\site-packages\paraview\extract_selection.py", line 74, in execute maskArray = calculator.compute(inputs, query, ns=elocals) File "C:\Program Files (x86)\ParaView 4.4.0\lib\paraview-4.4\site-packages\paraview\calculator.py", line 74, in compute retVal = eval(expression, globals(), mylocals) File "<string>", line 1 Liquid Pressure [Pa] == max(Liquid Pressure [Pa]) ^ SyntaxError: invalid syntax | ||||||||
Project | Sandia | ||||||||
(0035444) Alan Scott (manager) 2015-11-12 16:24 |
OK, I just found an easier way to replicate this bug. * Open can.exo. All vars on. Apply. * Calculator. Attribute Mode Cell Data. Result Array Name >>> Split Name. (i.e., two words, with a space in the middle). Equation, EQPS. Apply. * Find data, cell, use the output of the calculator, choose Split Name, is max. * Run Selection Query. Find data won't work, and you get lots of warning verbosity. |
(0038931) Kitware Robot (administrator) 2016-08-12 09:59 |
2015-11-12 16:14 | Alan Scott | New Issue | |
2015-11-12 16:15 | Alan Scott | Target Version | => 5.1 |
2015-11-12 16:24 | Alan Scott | Note Added: 0035444 | |
2016-08-12 09:59 | Kitware Robot | Note Added: 0038931 | |
