0015846 | ParaView | (No Category) | public | 2015-11-24 09:30 | 2016-08-12 09:59 | ||||
Reporter | Dan C. | ||||||||
Platform | 64 bit Linux | OS | Ubuntu | OS Version | 12.04 | ||||
Product Version | 4.4 | ||||||||
Summary | 0015846: Time sequence out of order on VTK file import within ParaView | ||||||||
Description | When a user imports the attached data into ParaView, the file import dialogue shows an incorrect numerical order of the vtk files. This happens regardless of file name being String_integer.vtk string_string_integer.vtk In the terminal, the files are in the proper order (see additional screenshot). The integer convention is tied to the real time step value for easy post processing. Screenshots and test data are attached. Also tested on Paraview 4.1 | ||||||||
Steps To Reproduce | 1. unzip data compressed inside the attachment 2. start paraview and open the data sequence 3. notice the wrong order when the list is expanded (see screenshot of order) | ||||||||
Project | TBD | ||||||||
Attached Files | VTKSequenceError.zip [^] (1,287,666 bytes) 2015-11-24 09:30 | ||||||||
(0038934) Kitware Robot (administrator) 2016-08-12 09:59 |
2015-11-24 09:30 | Dan C. | New Issue | |
2015-11-24 09:30 | Dan C. | File Added: VTKSequenceError.zip | |
2015-11-24 10:03 | Dan C. | OS | => Ubuntu |
2015-11-24 10:03 | Dan C. | OS Version | => 12.04 |
2015-11-24 10:03 | Dan C. | Platform | => 64 bit Linux |
2015-11-24 10:03 | Dan C. | Steps to Reproduce Updated | |
2016-08-12 09:59 | Kitware Robot | Note Added: 0038934 | |
