0015868 | ParaView | (No Category) | public | 2015-12-08 20:38 | 2016-08-12 09:59 | ||||
Product Version | 4.4 | ||||||||
Target Version | 5.1 | Fixed in Version | |||||||
Summary | 0015868: ResetCamera creates bad python | ||||||||
Description | Having a ResetCamera between two filters makes the first filter non visible. I created a trace as follows, and will attach said trace. I will add a comment where the bad ResetCamera is. * ParaView 4.4.0, local server, Windows. * Start trace recorder. * Wavelet. Apply. * Contour. 1000. Apply. * Turn visibility of the contour off. * Reset * Contour. 2000. Apply. * Stop trace. Save this trace. * Reset Session. * Tools/ Python Shell/ run this trace. | ||||||||
Project | Sandia | ||||||||
Attached Files | waveletPythonBug.py [^] (34,329 bytes) 2015-12-08 20:38 | ||||||||
(0038947) Kitware Robot (administrator) 2016-08-12 09:59 |
2015-12-08 20:38 | Alan Scott | New Issue | |
2015-12-08 20:38 | Alan Scott | File Added: waveletPythonBug.py | |
2015-12-08 20:39 | Alan Scott | Target Version | => 5.1 |
2016-08-12 09:59 | Kitware Robot | Note Added: 0038947 | |
