0015877 | ParaView | (No Category) | public | 2015-12-11 21:00 | 2016-08-12 09:59 | ||||
Product Version | 4.4 | ||||||||
Target Version | 5.1 | Fixed in Version | |||||||
Summary | 0015877: pipeline failing for temporal statistics with some timesteps with no data | ||||||||
Description | ParaView is failing for the temporal statistics filter when we start with a timestep with no data. Here is an example: * Windows, 4.4.0, local server * can.exo. All vars on. Apply. * Threshold filter. EQPS. Min of 1, Max of 2. Apply. (No data is written from this filter, but at higher timesteps there is data from Threshold.) * Temporal Statisitics filter. No output. This is causing one of my users grief. | ||||||||
Project | Sandia | ||||||||
(0035545) Alan Scott (manager) 2015-12-11 21:13 |
Note that we get bazillions of line of output. Here is some: Warning: In C:\bbd\b51c3c7f\source-paraview\VTK\Filters\General\vtkTemporalStatistics.cxx, line 735 vtkTemporalStatistics (000000000BDB93E0): Size of array ObjectId_minimum has changed. Does the source change the topology over time? Warning: In C:\bbd\b51c3c7f\source-paraview\VTK\Filters\General\vtkTemporalStatistics.cxx, line 735 vtkTemporalStatistics (000000000BDB93E0): Size of array ObjectId_maximum has changed. Does the source change the topology over time? Warning: In C:\bbd\b51c3c7f\source-paraview\VTK\Filters\General\vtkTemporalStatistics.cxx, line 735 vtkTemporalStatistics (000000000BDB93E0): Size of array DISPL_stddev has changed. Does the source change the topology over time? Warning: In C:\bbd\b51c3c7f\source-paraview\VTK\Filters\General\vtkTemporalStatistics.cxx, line 735 vtkTemporalStatistics (000000000BDB93E0): Size of array VEL_stddev has changed. Does the source change the topology over time? Warning: In C:\bbd\b51c3c7f\source-paraview\VTK\Filters\General\vtkTemporalStatistics.cxx, line 735 vtkTemporalStatistics (000000000BDB93E0): Size of array ACCL_stddev has changed. Does the source change the topology over time? Warning: In C:\bbd\b51c3c7f\source-paraview\VTK\Filters\General\vtkTemporalStatistics.cxx, line 735 vtkTemporalStatistics (000000000BDB93E0): Size of array EQPS_stddev has changed. Does the source change the topology over time? Warning: In C:\bbd\b51c3c7f\source-paraview\VTK\Filters\General\vtkTemporalStatistics.cxx, line 735 vtkTemporalStatistics (000000000BDB93E0): Size of array ObjectId_stddev has changed. Does the source change the topology over time? |
(0038950) Kitware Robot (administrator) 2016-08-12 09:59 |
2015-12-11 21:00 | Alan Scott | New Issue | |
2015-12-11 21:01 | Alan Scott | Target Version | => 5.1 |
2015-12-11 21:13 | Alan Scott | Note Added: 0035545 | |
2016-08-12 09:59 | Kitware Robot | Note Added: 0038950 | |
