0015887 | ParaView | (No Category) | public | 2015-12-16 21:05 | 2016-08-12 09:59 | ||||
Product Version | 5.0 | ||||||||
Target Version | 5.1 | Fixed in Version | |||||||
Summary | 0015887: Resample with dataset doesn't work with time | ||||||||
Description | The Resample with dataset filter doesn't work correctly over time. Here is how to replicate. I will send dataset to Utkarsh. * Dataset is Resample-Cone-DoNotRelease. This has two files, donor.g and recipient.g. * Linux, 5.0.0-RC2, local server. * Timestep 0. * (If desired, but not necessary, Edit/ Settings/ Clamp and update every timestep). * Open donor.g. All vars on. Apply. * Open recipient.g. All vars on. Apply. * Filter/ Alphabetical/ ResampleWithDataset. ** Input == donor.g ** Source == recipient.g ** OK ** Turn on Pass Cell Array ** Turn on Pass Point Arrays ** Turn off Compute Tolerance. 1e-3. ** Apply. * Paint by TEMPK. Lets look at our data. * Turn visibility off for ResampleWithDataset. * Turn visibility on for donor.g. * (Rescale to datarange, there is a weirdness here.) * Move forward a few timesteps, one at a time. Timestep 0 - Min is about 293.9, max is 293.9. Timestep 1 - min is 294.0, max is 294.4 Now, we can see the bug. * Turn visibility off for donor.g. * Turn visibility on for ResampleWithDataset. * Back to time 0. Min is 0, max is 293.9. Not sure if this is correct. * Forward to time 1. Min is 0, max is 293.9. This is wrong. Basically, Rescale with Dataset isn't updating as time is changing. (Note to me - Trevor, blade.) | ||||||||
Project | Sandia | ||||||||
(0038954) Kitware Robot (administrator) 2016-08-12 09:59 |
2015-12-16 21:05 | Alan Scott | New Issue | |
2015-12-16 21:06 | Alan Scott | Target Version | => 5.1 |
2016-08-12 09:59 | Kitware Robot | Note Added: 0038954 | |
