0015894 | ParaView | (No Category) | public | 2015-12-19 09:56 | 2016-08-12 09:59 | ||||
Reporter | Nico Schlömer | ||||||||
Summary | 0015894: vtkExodusIIWriter: _ (underscore) added only to 2D data arrays | ||||||||
Description | When writing 1D or 3D data arrays, the name of the array is preserved in the output file. When writing 2D data arrays, however, an underscore (_) is added to the name. MWE: ``` import numpy import vtk from vtk.util import numpy_support points = [ [0.0, 0.0, 0.0], [1.0, 0.0, 0.0], [1.0, 1.0, 0.0], ] mesh = vtk.vtkUnstructuredGrid() # set points vtk_points = vtk.vtkPoints() # Not using a deep copy here results in a segfault. vtk_array = vtk.util.numpy_support.numpy_to_vtk(points) vtk_points.SetData(vtk_array) mesh.SetPoints(vtk_points) c = numpy.array([ 3, 0, 1, 2, ], dtype=int) a = vtk.util.numpy_support.numpy_to_vtkIdTypeArray(c) cell_array = vtk.vtkCellArray() cell_array.SetCells(1, a) mesh.SetCells(vtk.VTK_TRIANGLE, cell_array) # add point data pd = mesh.GetPointData() A = numpy.array([7, 3, -2], dtype=float) array = vtk.util.numpy_support.numpy_to_vtk(A) array.SetName('A') pd.AddArray(array) B = numpy.array([[7, 1], [3, 2], [-2, 0]], dtype=float) array = vtk.util.numpy_support.numpy_to_vtk(B) array.SetName('B') pd.AddArray(array) C = numpy.array([[7, 1, 3], [3, 2, -2], [-2, 0, 7]], dtype=float) array = vtk.util.numpy_support.numpy_to_vtk(C) array.SetName('C') pd.AddArray(array) # writer = vtk.vtkUnstructuredGridWriter() # writer.SetFileName('test.vtk') writer = vtk.vtkExodusIIWriter() writer.SetFileName('test.e') writer.SetInputData(mesh) writer.Write() ``` Open the file in, e.g., ParaView and observe the difference between A, B_, C. When using the `vtkUnstructuredGridWriter` to write VTK files (any other file type, in fact), no underscore is added. | ||||||||
Project | TBD | ||||||||
(0038957) Kitware Robot (administrator) 2016-08-12 09:59 |
2015-12-19 09:56 | Nico Schlömer | New Issue | |
2016-08-12 09:59 | Kitware Robot | Note Added: 0038957 | |
