0015906 | ParaView | (No Category) | public | 2015-12-23 20:52 | 2016-08-12 09:59 | ||||
Product Version | 5.0 | ||||||||
Summary | 0015906: Plot over line, selecting Use Custom Range jumps | ||||||||
Description | When plotting over line, and trying to set the Use Custom Range, the Properties tab jumps. This is very obnoxious and needs to be fixed. * ParaView 5.0.0-RC2, Linux, local server. * Sources/ Wavelet. Apply. * Plot over line. Apply. * Select Advanced icon on Properties tab. * Now, slide the Properties tab down to Left Axis use Custom Range. Select this. The whole Properties tab jumps. I bet it is positioned as though the Properties tab advanced icon isn't enabled. | ||||||||
Project | Sandia | ||||||||
(0035600) Alan Scott (manager) 2015-12-23 20:54 |
I lied. For 5.0, it also happens for standard Properties tab. |
(0036089) T.J. Corona (developer) 2016-06-21 09:06 |
I cannot reproduce this behavior on OS X. |
(0036114) Sujin Philip (developer) 2016-06-28 12:28 |
I can see this in 5.0 but not in the latest master. |
(0036115) Alan Scott (manager) 2016-06-28 13:06 |
Thanks for the heads up. I will retest. |
(0038961) Kitware Robot (administrator) 2016-08-12 09:59 |
2015-12-23 20:52 | Alan Scott | New Issue | |
2015-12-23 20:54 | Alan Scott | Note Added: 0035600 | |
2016-06-21 09:06 | T.J. Corona | Note Added: 0036089 | |
2016-06-28 12:28 | Sujin Philip | Note Added: 0036114 | |
2016-06-28 13:06 | Alan Scott | Note Added: 0036115 | |
2016-08-12 09:59 | Kitware Robot | Note Added: 0038961 | |
