0015925 | ParaView | (No Category) | public | 2016-01-11 11:47 | 2016-08-12 09:59 | ||||
Reporter | Dan Ibanez | ||||||||
Product Version | 5.0 | ||||||||
Summary | 0015925: can't parse valid Float64 ASCII values | ||||||||
Description | Using Paraview 5.0.0-RC3 binary distribution for Mac, but also reproduced on Linux with older Paraview versions. The VTK UnstructuredGrid XML Parser fails to read ASCII DataArrays containing values like this: -8.89836e-313 Even when we explicitly state type="Float64". The current workaround is to cast our "double" values to "float" before output. A stand-alone C++ program using "std::cin >> float" accepts these values just fine. Actually, this may have more to do with that value being a sub-normal double precision value. I've confirmed that Paraview accepts the file if the values are changed to this: -8.89836e-300 Which is just above the sub-normal cutoff. An example UnstructuredGrid file is attached. | ||||||||
Steps To Reproduce | Open the attached file with Paraview. | ||||||||
Project | TBD | ||||||||
Type | crash | ||||||||
Attached Files | bug.vtu [^] (1,037 bytes) 2016-01-11 11:47 | ||||||||
(0038969) Kitware Robot (administrator) 2016-08-12 09:59 |
2016-01-11 11:47 | Dan Ibanez | New Issue | |
2016-01-11 11:47 | Dan Ibanez | File Added: bug.vtu | |
2016-01-11 11:59 | Dan Ibanez | Description Updated | |
2016-01-11 11:59 | Dan Ibanez | Steps to Reproduce Updated | |
2016-08-12 09:59 | Kitware Robot | Note Added: 0038969 | |
