0015929ParaView(No Category)public2016-01-12 05:182016-08-12 09:59
ReporterMathieu Westphal
Assigned ToKitware Robot
PriorityhighSeverityminorReproducibilityhave not tried
StatusclosedResolutionmoved
PlatformOSOS Version
Product Versiongit-master
Summary0015929: wavelet broken when inversing range
DescriptionWavelet does not seem to support an inversed range, but the underlying problem might be bigger
Steps To ReproduceOpen Paraview
Create a wavelet
Set extent Z min to 100
Apply
Crash
Additional Information(gdb) bt
#0 0x00007ffff736b621 in std::min<float> (__a=@0x7fffffffc860: 9.99999968e+37, __b=@0x0: <error reading variable>)
    at /usr/include/c++/5.3.0/bits/stl_algobase.h:200
#1 0x00007fffeacae9e5 in vtkDataArrayPrivate::ComputeScalarRange<float, 1, 2>::operator()<float const*> (this=0x7fffffffc8d7, begin=0x0,
    end=0xfffffffffffd9abc, ranges=0x306f640) at /home/glow/work/kitware/paraview/paraview/VTK/Common/Core/vtkDataArrayPrivate.txx:82
#2 0x00007fffeacadcee in vtkDataArrayPrivate::DoComputeScalarRange<float, float const*> (begin=0x0, end=0xfffffffffffd9abc, numComp=1, ranges=0x306f640)
    at /home/glow/work/kitware/paraview/paraview/VTK/Common/Core/vtkDataArrayPrivate.txx:123
#3 0x00007fffeacacd6e in vtkDataArrayTemplate<float>::ComputeScalarRange (this=0x305f330, ranges=0x306f640)
    at /home/glow/work/kitware/paraview/paraview/VTK/Common/Core/vtkDataArrayTemplate.txx:1015
#4 0x00007fffeab960d7 in vtkDataArray::ComputeRange (this=0x305f330, range=0x7fffffffca40, comp=0)
    at /home/glow/work/kitware/paraview/paraview/VTK/Common/Core/vtkDataArray.cxx:1159
#5 0x00007ffff3da8ef5 in vtkDataArray::GetRange (this=0x305f330, range=0x7fffffffca40, comp=0)
    at /home/glow/work/kitware/paraview/paraview/VTK/Common/Core/vtkDataArray.h:311
#6 0x00007ffff3da4d92 in vtkPVArrayInformation::CopyFromObject (this=0x304e580, obj=0x305f330)
    at /home/glow/work/kitware/paraview/paraview/ParaViewCore/ClientServerCore/Core/vtkPVArrayInformation.cxx:570
#7 0x00007ffff3dc1b7f in vtkPVDataSetAttributesInformation::CopyFromDataSetAttributes (this=0x2cb5250, da=0x2cbd770)
    at /home/glow/work/kitware/paraview/paraview/ParaViewCore/ClientServerCore/Core/vtkPVDataSetAttributesInformation.cxx:228
#8 0x00007ffff3db4553 in vtkPVDataInformation::CopyFromDataSet (this=0x2cbc280, data=0x2cbdfc0)
    at /home/glow/work/kitware/paraview/paraview/ParaViewCore/ClientServerCore/Core/vtkPVDataInformation.cxx:509
0000009 0x00007ffff3db50fb in vtkPVDataInformation::CopyFromObject (this=0x2cbc280, object=0x296f450)
    at /home/glow/work/kitware/paraview/paraview/ParaViewCore/ClientServerCore/Core/vtkPVDataInformation.cxx:687
#10 0x00007ffff450788f in vtkPVSessionCore::GatherInformationInternal (this=0x9a5b00, information=0x2cbc280, globalid=3734)
    at /home/glow/work/kitware/paraview/paraview/ParaViewCore/ServerImplementation/Core/vtkPVSessionCore.cxx:842
0000011 0x00007ffff450796d in vtkPVSessionCore::GatherInformation (this=0x9a5b00, location=1, information=0x2cbc280, globalid=3734)
    at /home/glow/work/kitware/paraview/paraview/ParaViewCore/ServerImplementation/Core/vtkPVSessionCore.cxx:862
#12 0x00007ffff450349e in vtkPVSessionBase::GatherInformation (this=0xd93410, location=1, information=0x2cbc280, globalid=3734)
    at /home/glow/work/kitware/paraview/paraview/ParaViewCore/ServerImplementation/Core/vtkPVSessionBase.cxx:253
#13 0x00007ffff49740b5 in vtkSMProxy::GatherInformation (this=0x29d6e70, information=0x2cbc280)
    at /home/glow/work/kitware/paraview/paraview/ParaViewCore/ServerManager/Core/vtkSMProxy.cxx:841
#14 0x00007ffff49486b6 in vtkSMOutputPort::GatherDataInformation (this=0x2cb5110)
TagsNo tags attached.
ProjectTBD
Topic Name
Typecrash
 Relationships
  Notes
(0038971)
Kitware Robot (administrator)
2016-08-12 09:59
Resolving issue as `moved`.
 Issue History
2016-01-12 05:18 Mathieu Westphal New Issue
2016-01-12 05:20 Mathieu Westphal Description Updated
2016-01-12 05:20 Mathieu Westphal Steps to Reproduce Updated
2016-01-12 05:20 Mathieu Westphal Additional Information Updated
2016-08-12 09:59 Kitware Robot Note Added: 0038971
2016-08-12 09:59 Kitware Robot Status backlog => closed
2016-08-12 09:59 Kitware Robot Resolution open => moved
2016-08-12 09:59 Kitware Robot Assigned To => Kitware Robot
