0015931 | ParaView | (No Category) | public | 2016-01-12 07:20 | 2016-08-12 09:59 | ||||
Reporter | Mathieu Westphal | ||||||||
Summary | 0015931: vtkCompositeMapper not displaying correctly normals generated by the Tube Filter | ||||||||
Description | When displaying a composite dataset containing normals for triangle strips , the Composite Mapper seems completelly breaking normals. | ||||||||
Steps To Reproduce | Open brokenNormals.pvsm or Open Paraview Create a line Create another line and move it to see both lines Create tube filters on each line ( will generate Triangle Strips) tubes are displayed correctly Group tubes outputs together using group dataset tubes are NOT displayed correctly Create triangulate filters on each tubes filters Group triangulate outputs together using group dataset tubes are displayed correctly | ||||||||
Project | TBD | ||||||||
Attached Files | brokenNormals.pvsm [^] (404,092 bytes) 2016-01-12 07:27 | ||||||||
(0038972) Kitware Robot (administrator) 2016-08-12 09:59 |
2016-01-12 07:20 | Mathieu Westphal | New Issue | |
2016-01-12 07:20 | Mathieu Westphal | File Added: brokenNormals.pvsm | |
2016-01-12 07:27 | Mathieu Westphal | Description Updated | |
2016-01-12 07:27 | Mathieu Westphal | Steps to Reproduce Updated | |
2016-01-12 07:27 | Mathieu Westphal | File Deleted: brokenNormals.pvsm | |
2016-01-12 07:27 | Mathieu Westphal | File Added: brokenNormals.pvsm | |
2016-08-12 09:59 | Kitware Robot | Note Added: 0038972 | |
