0015946 | ParaView | (No Category) | public | 2016-01-20 10:05 | 2016-08-12 09:59 | ||||
Reporter | Paul Melis | ||||||||
Product Version | 5.0 | ||||||||
Summary | 0015946: Second view not directly updated after changing color scale | ||||||||
Description | Reproductive steps: 1. Create a Wavelet source 2. Switch to slice view 3. Split the current view and add a second Render view 4. Show wavelet in new view, switch to slice view 5. Use the Color Map Editor to pick a different color scale 6. Only one of the views updates its coloring, interacting with that view leaves the other view inconsistent 7. Only after interacting with the faulty view is its coloring updated This is with the official ParaView 5.0 Linux 64-bit binaries | ||||||||
Project | TBD | ||||||||
(0038979) Kitware Robot (administrator) 2016-08-12 09:59 |
2016-01-20 10:05 | Paul Melis | New Issue | |
2016-08-12 09:59 | Kitware Robot | Note Added: 0038979 | |
