0015950 | ParaView | (No Category) | public | 2016-01-20 17:19 | 2016-08-12 09:59 | ||||
Assigned To | Nathan Fabian | ||||||||
Product Version | 5.0 | ||||||||
Summary | 0015950: Exodus writer - edge sets not written correctly, | ||||||||
Description | A customer is having issues writing edge sets, coming from the Resample with Dataset filter. Here is how to replicate: * Open donor-DoNotRelease.g. All variables on. Apply. * Note - Two important vars - PRES_PA and TEMP_K * Open recipient-DoNotRelease.g. Select Has Mode Shapes. Advanced Properties tab. Select all Sets. Select all Variables. Apply. * Note - PRES_PA and TEMP_K do not exist in this dataset. * Resample with Dataset. ** Input > donor-DoNotRelease.g ** Source > recipient-DoNotRelease.g OK. * (Advanced properties need to be on.) * select Pass Cell Array, select Pass Point Array. * unselect Compute Tolerance. Set manual tolerance to 1e-3. * Apply * Note - ResampleToDataset should already be selected. If not, select it. * Save Data. Exodus file. Save as some known file, such as combined-DoNotRelease.e. Don't save all timesteps - it will take forever. * Now, open combined-DoNotRelease.e. All variables on, all sets on, all blocks off. There's nothing here! This is a bug. | ||||||||
Project | Sandia | ||||||||
(0035680) Alan Scott (manager) 2016-01-26 17:09 |
Tested Nathan's patch. Works better, still broken. * Remote server acts the same as local server, so I believe that is working. * Using the directions above, when you write - and then read in - the exodus dataset, set's names are lost. This needs to be fixed. * Using the directions above, from the saved Exodus dataset, turn all blocks and sets off. Turn on the first sideset. It doesn't look like the first sideset from the original donor mesh. This needs to be fixed. |
(0038982) Kitware Robot (administrator) 2016-08-12 09:59 |
2016-01-20 17:19 | Alan Scott | New Issue | |
2016-01-26 17:03 | Alan Scott | Assigned To | => Nathan Fabian |
2016-01-26 17:09 | Alan Scott | Note Added: 0035680 | |
2016-08-12 09:59 | Kitware Robot | Note Added: 0038982 | |
