0015989 | ParaView | (No Category) | public | 2016-02-10 22:02 | 2016-08-12 10:00 | ||||
Assigned To | Sujin Philip | ||||||||
Product Version | 5.0 | ||||||||
Target Version | 5.1 | Fixed in Version | |||||||
Summary | 0015989: Angular periodic filter is slow | ||||||||
Description | The Angular Periodic Filter is slow, especially if a user has multiple blocks and uses a thin slice. If possible, please fix this. * 5.0.0, Linux, local server. * Load DoNotRelease-cylinderUpset.e. This dataset has two blocks, and lots of variables, and about 150 timesteps. Load the blocks, load all of the variables, do NOT load the sets. Apply. * Clear the timer log. (Tools/ Timer Log). * Angular Periodic Filter. Turn both blocks on. Resolution angle 1, Axis Z. Apply. * Open the timer log. Notice how long it has taken. This is impacting a user. This toy dataset takes a few seconds to load. The actual dataset (which cannot be shared) takes 20 to 60 seconds per timestep. One way to see what the user sees is to change the Resolution angle to 0.2. From timer log: PropertiesPanel::Apply, 3.59576 seconds Execute vtkAngularPeriodicFilter id: 51, 0.031081 seconds AngularPeriodicFilter::GatherInformatio, 0.076252 seconds AngularPeriodicFilter::GatherInformatio, 0.059751 seconds AngularPeriodicFilter::GatherInformatio, 0.046584 seconds RenderView::Update, 2.65698 seconds vtkPVView::Update, 2.65694 seconds Execute vtkGeometryRepresentationWithFa, 2.65619 seconds vtkPVGeometryFilter::RequestData, 2.58984 seconds vtkPVGeometryFilter::RequestCompositeDa, 2.58983 seconds vtkPVGeometryFilter::ExecuteCompositeDa, 1.65151 seconds vtkSMRepresentationProxy::GetRepresente, 0.069979 seconds Still Render, 0.496506 seconds OpenGL Dev Render, 0.102788 seconds I am sending the dataset to Utkarsh directly. | ||||||||
Project | Sandia | ||||||||
Type | performance | ||||||||
(0035712) Alan Scott (manager) 2016-02-11 17:20 |
OK, I puttered with this a bit further. I did two runs with a larger (real) dataset. Loading all of the data (49 variables, about 60 components (some vars are vectors), about 5000 cells, 11,000 points, about 5 blocks), which represents a 1 degree pie slice, then making a complete cylinder takes the following time: Loading all variables takes 48 seconds per frame. Loading none of the variables takes about 10 seconds per frame. The first, and most significant issue is in the following call stack, top is outside of loops: While(each 1 degree slice, i.e., for 1 to 360) { vtkDataSetSurfaceFilter::UnstructuredGridExecute { While(each cell or point, 1 to 10,000) { vtkDataSetAttributes::CopyData { for(each variable, 1 to 57) vtkDataSetAttributes::CopyTuple vtkDataArrayTemplate<double>::InsertTuple { Lots of useless if tests, making sure data types match, etc. vtkDataArrayTemplate<double>::GetTupleValue { for i = 1 to 1 Copy one variable } } } } } |
(0035821) Utkarsh Ayachit (administrator) 2016-03-03 11:33 |
Sujin, I'd use David Lonie's Generic Array branch for this which includes a different implementation for this filter. Check to see if that implementation has the same issue before proceeding. |
(0038999) Kitware Robot (administrator) 2016-08-12 10:00 |
2016-02-10 22:02 | Alan Scott | New Issue | |
2016-02-10 22:14 | Alan Scott | Target Version | => 5.1 |
2016-02-10 22:20 | Alan Scott | Description Updated | |
2016-02-11 17:20 | Alan Scott | Note Added: 0035712 | |
2016-03-03 11:32 | Utkarsh Ayachit | Assigned To | => Sujin Philip |
2016-03-03 11:33 | Utkarsh Ayachit | Note Added: 0035821 | |
2016-08-12 10:00 | Kitware Robot | Note Added: 0038999 | |
2016-08-12 10:00 | Kitware Robot | Status | backlog => closed |
2016-08-12 10:00 | Kitware Robot | Resolution | open => moved |
