0015993 | ParaView | (No Category) | public | 2016-02-11 20:46 | 2016-02-22 19:48 | ||||
Product Version | 5.0 | ||||||||
Target Version | 5.0.1 | Fixed in Version | 5.0.1 | ||||||
Summary | 0015993: Rubber band selection is broken | ||||||||
Description | The area outline box goes away in crazy ways for rubber band select. * Delete your .config files (or try running paraview -dr) * 5.0.0, Linux, local server. * Sources/ Wavelet. Apply. Representation Surface. * Now, select Select Points On. Rubber band select from about an inch above and left of the upper left corner of Wavelet, dragging to about the center of Wavelet. Everything is fine. * Try this again. The rubber band select box does not show against the background. | ||||||||
Project | Sandia | ||||||||
(0035742) Utkarsh Ayachit (administrator) 2016-02-16 10:43 |
MR: https://gitlab.kitware.com/vtk/vtk/merge_requests/1224 [^] |
(0035757) Utkarsh Ayachit (administrator) 2016-02-22 14:54 |
Also test on "release" branch for 5.0.1 |
(0035762) Alan Scott (manager) 2016-02-22 19:48 |
Tested master, Linux, remote server. |
2016-02-11 20:46 | Alan Scott | New Issue | |
2016-02-11 20:46 | Alan Scott | Target Version | => 5.1 |
2016-02-13 11:45 | Utkarsh Ayachit | Target Version | 5.1 => 5.0.1 |
2016-02-16 10:43 | Utkarsh Ayachit | Note Added: 0035742 | |
2016-02-22 14:54 | Utkarsh Ayachit | Note Added: 0035757 | |
2016-02-22 14:54 | Utkarsh Ayachit | Status | backlog => customer review |
2016-02-22 14:54 | Utkarsh Ayachit | Fixed in Version | => 5.0.1 |
2016-02-22 14:54 | Utkarsh Ayachit | Resolution | open => fixed |
2016-02-22 14:54 | Utkarsh Ayachit | Assigned To | => Utkarsh Ayachit |
2016-02-22 19:48 | Alan Scott | Note Added: 0035762 | |
2016-02-22 19:48 | Alan Scott | Status | customer review => closed |
