0016005 | ParaView | (No Category) | public | 2016-02-18 15:06 | 2016-08-12 10:00 | ||||
Product Version | 5.0 | ||||||||
Target Version | 5.0.1 | Fixed in Version | |||||||
Summary | 0016005: Trace recorder fails for CTH data | ||||||||
Description | The trace recorder fails for CTH data. I am going to create two sections for this bug - what is currently failing, and the test that needs to work, when this first bug is fixed. Current bug: * 5.0.0, Linux, local server. * Start trace. * Open Dave's small CTH dataset (four files). All vars on. Apply. * Optionally, you may want to turn visibility off in the pipeline browser for Markers and Tracers. * Stop trace. * Save as macro (or any other script). * Edit/ Reset Session. * Run macro. You will not get anything to show on the screen, and will get the following output: Traceback (most recent call last): File "<string>", line 39, in <module> NameError: name 'OutputPort' is not defined Further, if you had gotten farther with your script, you would see nothing at all after this point (such as if you had run a filter). OK, what should work? Here is a bare minimum: * 5.0.0, Linux, local server. * Start trace. * Open Dave's small CTH dataset (four files). All vars on. Apply. * Optionally, you may want to turn visibility off in the pipeline browser for Markers and Tracers. * Extract CTH Parts. Material Volume Fraction - 1 only. Apply. * Select Volume data in the pipeline browser. * Extract CTH Parts. Material Volume Fraction - 2 only. Apply. * Paint by pressure. * Stop trace. * Save as macro (or any other script). * Edit/ Reset Session. * Run macro. | ||||||||
Project | Sandia | ||||||||
Attached Files | badOpenCTHFile.py [^] (2,659 bytes) 2016-02-24 17:14 | ||||||||
(0035766) Utkarsh Ayachit (administrator) 2016-02-23 09:57 |
MR: https://gitlab.kitware.com/paraview/paraview/merge_requests/650 [^] |
(0035775) Alan Scott (manager) 2016-02-24 16:30 |
Very close, but not quite. The second block of commands works, but the first one (labeled Current bug) doesn't. It appears there is a Render() missing... This behavior is different than loading can.exo, so I believe it is not by design. |
(0035778) Alan Scott (manager) 2016-02-24 17:12 |
We are wondering if this has to do with my build - incremental, vs a rebuild from scratch. Attaching the python file for the first test block above (at Utkarsh's request). |
(0035780) Utkarsh Ayachit (administrator) 2016-02-24 17:22 |
Alan, try hitting reset camera. Does that work? You're right a render is missing. But we deliberately added a commented out line to the generate trace saying "uncomment the following to render all views". I believe we did that since in several cases when people generate these traces for writing images etc, calling this extra render and the end in unnecessary. |
(0035782) Alan Scott (manager) 2016-02-24 17:29 |
Reset camera works. The issue I have with this bug/feature is that it acts differently than reading exodus data. That isn't right, is it? |
(0035800) Alan Scott (manager) 2016-02-25 22:10 |
Changing to ToDo, Utkarsh is going to add a Render after any GUI based macros or scripts. |
(0039003) Kitware Robot (administrator) 2016-08-12 10:00 |
2016-02-18 15:06 | Alan Scott | New Issue | |
2016-02-18 15:06 | Alan Scott | Target Version | => 5.0.1 |
2016-02-23 09:57 | Utkarsh Ayachit | Note Added: 0035766 | |
2016-02-23 09:57 | Utkarsh Ayachit | Status | backlog => customer review |
2016-02-23 09:57 | Utkarsh Ayachit | Fixed in Version | => 5.1 |
2016-02-23 09:57 | Utkarsh Ayachit | Resolution | open => fixed |
2016-02-23 09:57 | Utkarsh Ayachit | Assigned To | => Utkarsh Ayachit |
2016-02-24 16:30 | Alan Scott | Note Added: 0035775 | |
2016-02-24 16:30 | Alan Scott | Status | customer review => todo |
2016-02-24 17:12 | Alan Scott | Note Added: 0035778 | |
2016-02-24 17:14 | Alan Scott | File Added: badOpenCTHFile.py | |
2016-02-24 17:22 | Utkarsh Ayachit | Note Added: 0035780 | |
2016-02-24 17:23 | Utkarsh Ayachit | Status | todo => customer review |
2016-02-24 17:23 | Utkarsh Ayachit | Fixed in Version | 5.1 => 5.0.1 |
2016-02-24 17:29 | Alan Scott | Note Added: 0035782 | |
2016-02-25 22:10 | Alan Scott | Note Added: 0035800 | |
2016-02-25 22:10 | Alan Scott | Status | customer review => todo |
2016-08-12 10:00 | Kitware Robot | Note Added: 0039003 | |
2016-08-12 10:00 | Kitware Robot | Status | todo => closed |
2016-08-12 10:00 | Kitware Robot | Fixed in Version | 5.0.1 => |
2016-08-12 10:00 | Kitware Robot | Resolution | fixed => moved |
