0016013ParaView(No Category)public2016-02-25 20:332016-03-11 22:21
ReporterAlan Scott
Assigned ToAlan Scott
StatusclosedResolutionfixed
PlatformOSOS Version
Product Versiongit-master
Summary0016013: OpenGL error messages for debug build
DescriptionOK, I have two builds, one release and one one debug. The release build is fine.
The debug build consistently puts out an error message. Due to a mixup on my builds, I actually had a debug client/ debug server, then a release client/ debug server show this error. No error release server. Here is how to replicate:
• Linux, remote server (8 ranks), master (about 2pm today pull), debug build.
• Delete all .config/ParaView files.
• Change Remote Rendering threshold to 0.
• Sources/ Wavelet. Apply. Surface. Color by RTData.
• Edit Color Map.
Immediately, I get this error, and anything I do after that continues to spew out more error messages.
ERROR: In /projects/viz/paraview/src/ParaView/5.0.0-junk/ParaView5/VTK/Rendering/OpenGL2/vtkOpenGLTexture.cxx, line 233
vtkOpenGLTexture (0x2826270): failed at glGetIntegerv 1 OpenGL errors detected
  0 : (1282) Invalid operation
ERROR: In /projects/viz/paraview/src/ParaView/5.0.0-junk/ParaView5/VTK/Rendering/OpenGL2/vtkOpenGLActor.cxx, line 91
vtkOpenGLActor (0x2075650): failed after Render 1 OpenGL errors detected
By the way, I do not see this with 5.0.0.
TagsNo tags attached.
ProjectSandia
Topic Name
Typeincorrect functionality
 Relationships
  Notes
(0035803)
2016-02-25 22:44
Alan,
What is your server built with? Mesa? Mind post what GL version is reported for the server in the About dialog?
Do you get error messages when you simply resize the window (instead of clicking "Edit Color Map")?
(0035837)
Alan Scott (manager)
2016-03-11 22:21
I can't replicate this. If I do, I will write it up with easier to replicate directions. Closing.
 Issue History
2016-02-25 20:33 Alan Scott New Issue
2016-02-25 22:44 Utkarsh Ayachit Note Added: 0035803
2016-03-11 22:21 Alan Scott Note Added: 0035837
2016-03-11 22:21 Alan Scott Status backlog => closed
2016-03-11 22:21 Alan Scott Assigned To => Alan Scott
2016-03-11 22:21 Alan Scott Resolution open => fixed
