0016021 | ParaView | (No Category) | public | 2016-03-04 16:24 | 2016-08-12 10:00 | ||||
Reporter | Cory Quammen | ||||||||
Assigned To | Cory Quammen | ||||||||
Product Version | 5.0 | ||||||||
Summary | 0016021: Need mechanism to restore array-specific default color map | ||||||||
Description | ParaView now defines a special color map for the vtkBlockColors array, which is available when multiblock data sets are loaded. It also makes it possible to define array-specific default color maps. However, no mechanism for restoring the default array-specific color map exists. To test: - Start ParaView, local server - Load bake.e. Note the colorful color map used to color the blocks. - Open Color Map Editor. - At the bottom of the panel, click "Restore application default setting values for color map" - The color map will be completely reset. | ||||||||
Project | Sandia | ||||||||
Relationships | ||||||
(0036036) Cory Quammen (developer) 2016-06-01 05:44 |
Fix for parent issue pushed to https://gitlab.kitware.com/paraview/paraview/merge_requests/805: [^] |
(0036107) Cory Quammen (developer) 2016-06-27 04:03 |
Fix is now merged into master |
(0039010) Kitware Robot (administrator) 2016-08-12 10:00 |
2016-03-04 16:24 | Cory Quammen | New Issue | |
2016-03-04 16:24 | Cory Quammen | Assigned To | => Cory Quammen |
2016-03-04 16:25 | Cory Quammen | Relationship added | child of 0015860 |
2016-06-01 05:44 | Cory Quammen | Note Added: 0036036 | |
2016-06-27 04:03 | Cory Quammen | Note Added: 0036107 | |
2016-06-27 04:03 | Cory Quammen | Status | backlog => gatekeeper review |
2016-06-27 04:03 | Cory Quammen | Resolution | open => fixed |
2016-08-12 10:00 | Kitware Robot | Note Added: 0039010 | |
2016-08-12 10:00 | Kitware Robot | Status | gatekeeper review => closed |
2016-08-12 10:00 | Kitware Robot | Resolution | fixed => moved |
