0016038 | ParaView | (No Category) | public | 2016-03-23 14:32 | 2016-08-12 10:00 | ||||
Product Version | 5.0.1 | ||||||||
Summary | 0016038: Block ID selection in Find Data does nothing | ||||||||
Description | On some selections in the Find Data dialog box, there is a criterium line that allows you to select the Block ID. This selection seems to do nothing. To replicate, do the following: 1. Open can.ex2. Turn on all variables. Apply. 2. Open the Find Data dialog. 3. Set the top row to "Cell(s)" from "can.ex2" (the default). 4. Set the first criterium to "ID" "is >=" "0" 5. When you select ID as the thing to select, a second criterium line appears. Set this to "Block ID" "is" "2" 6. Click "Run Selection Query" You can see that both blocks (numbered 2 and 3) are selected instead of just block 2. | ||||||||
Project | TBD | ||||||||
(0039017) Kitware Robot (administrator) 2016-08-12 10:00 |
2016-03-23 14:32 | Ken Moreland | New Issue | |
2016-08-12 10:00 | Kitware Robot | Note Added: 0039017 | |
2016-08-12 10:00 | Kitware Robot | Status | backlog => closed |
2016-08-12 10:00 | Kitware Robot | Resolution | open => moved |
2016-08-12 10:00 | Kitware Robot | Assigned To | => Kitware Robot |
