0016039 | ParaView | (No Category) | public | 2016-03-23 14:52 | 2016-08-12 10:00 | ||||
Product Version | 5.0.1 | ||||||||
Summary | 0016039: Warning when creating "Point Source" with auto apply | ||||||||
Description | When you create a Point Source with auto apply on, you immediately get the following warning: Warning: In /Users/kitware/buildbot-slave/paraview-bigmac-osx-shared-release_opengl2_osx10_7_qt4_superbuild/source-paraview/VTK/Rendering/Core/vtkRenderer.cxx, line 1062 vtkOpenGLRenderer (0x7ff7142d2390): Resetting view-up since view plane normal is parallel I suspect this is because the default options for point source create a single vertex, which messes with the camera resetting. | ||||||||
Project | TBD | ||||||||
Relationships | ||||||
(0039018) Kitware Robot (administrator) 2016-08-12 10:00 |
2016-03-23 14:52 | Ken Moreland | New Issue | |
2016-05-17 14:20 | Alan Scott | Relationship added | related to 0016127 |
2016-08-12 10:00 | Kitware Robot | Note Added: 0039018 | |
2016-08-12 10:00 | Kitware Robot | Status | backlog => closed |
2016-08-12 10:00 | Kitware Robot | Resolution | open => moved |
2016-08-12 10:00 | Kitware Robot | Assigned To | => Kitware Robot |
