0016067 | ParaView | (No Category) | public | 2016-04-08 18:48 | 2016-08-12 10:00 | ||||
Product Version | 5.0.1 | ||||||||
Summary | 0016067: Trace recorder missing GetTimeKeeper() | ||||||||
Description | From a user: Most of my python scripting comes from copy/pasting things from the trace output as I post process my stuff for the first time. It looks like in ParaView 5.0.1 (64-bit) when I type in the time inside the time box (next to controls) and press enter, the view proceeds to the correct time frame, however nothing is reflected in the trace output history. I understand the GetTimeKeeper() command was introduced in version 5 and is relatively new, but it would be nice for it to show up in the trace window along with a small code snippet that sets the current rendered frame to a prescribed time. This can be very helpful in batch processing mode if I want to, for example, save frames based on time stamps. | ||||||||
Project | Sandia | ||||||||
(0039029) Kitware Robot (administrator) 2016-08-12 10:00 |
2016-04-08 18:48 | Alan Scott | New Issue | |
2016-08-12 10:00 | Kitware Robot | Note Added: 0039029 | |
2016-08-12 10:00 | Kitware Robot | Status | backlog => closed |
2016-08-12 10:00 | Kitware Robot | Resolution | open => moved |
2016-08-12 10:00 | Kitware Robot | Assigned To | => Kitware Robot |
