0016090 | ParaView | (No Category) | public | 2016-04-22 14:47 | 2016-08-12 10:00 | ||||
Reporter | Philip Eisenlohr | ||||||||
Product Version | 5.0.1 | ||||||||
Summary | 0016090: vtkXMLStructuredDataWriter fails with WriteToOutputStringOn() | ||||||||
Description | ERROR: In /tmp/vtk20160219-59710-1ih9gsl/VTK-7.0.0/IO/XML/vtkXMLStructuredDataWriter.cxx, line 124 vtkXMLRectilinearGridWriter (0x7fe17b31b390): The FileName or Stream must be set first. ERROR: In /tmp/vtk20160219-59710-1ih9gsl/VTK-7.0.0/Common/ExecutionModel/vtkExecutive.cxx, line 784 vtkCompositeDataPipeline (0x7fe17b31cc10): Algorithm vtkXMLRectilinearGridWriter(0x7fe17b31b390) returned failure for request: vtkInformation (0x7fe17b31e9f0) in structuredDataWriter it reads (line 121): if (!this->Stream && !this->FileName) { this->SetErrorCode(vtkErrorCode::NoFileNameError); vtkErrorMacro("The FileName or Stream must be set first."); return 0; } while in unstructuredDataWriter (line 117): if(!this->Stream && !this->FileName && !this->WriteToOutputString) { this->SetErrorCode(vtkErrorCode::NoFileNameError); vtkErrorMacro("The FileName or Stream must be set first or " "the output must be written to a string."); return 0; } Is omitting outputting to a string a deliberate curtailing of the functionality of the structuredWriter?? | ||||||||
Tags | VTK | ||||||||
Project | TBD | ||||||||
(0039040) Kitware Robot (administrator) 2016-08-12 10:00 |
2016-04-22 14:47 | Philip Eisenlohr | New Issue | |
2016-04-22 14:49 | Philip Eisenlohr | Tag Attached: VTK | |
2016-08-12 10:00 | Kitware Robot | Note Added: 0039040 | |
2016-08-12 10:00 | Kitware Robot | Status | backlog => closed |
2016-08-12 10:00 | Kitware Robot | Resolution | open => moved |
2016-08-12 10:00 | Kitware Robot | Assigned To | => Kitware Robot |
