0016129 | ParaView | (No Category) | public | 2016-05-17 17:09 | 2016-08-12 10:00 | ||||
Summary | 0016129: Axes grid fails for no front/back face cull | ||||||||
Description | * Linux, master, local server. * Load can.exo, apply. * Properties tab, select Axes Grid. * Edit/ Advanced. * Turn off Cull Backface and turn off Cull Frontface. All of the annotation disappears! This is a bug. | ||||||||
Project | Sandia | ||||||||
(0036038) Utkarsh Ayachit (administrator) 2016-06-01 10:42 |
This is a limitation of the current implementation. If no faces are culled, an "Label Unique Edges Only" is on, there are no edges not shared between multiple faces and hence none are labelled. There are two workarounds: 1. uncheck "Label Unique Edges Only" and then use "Axes To Label" to finely tune which axes are labelled, or 2. use "Faces to Render" to explicitly select a few faces to render. So long as all are not selected, you'll start seeing labels on edges. |
(0039059) Kitware Robot (administrator) 2016-08-12 10:00 |
2016-05-17 17:09 | Alan Scott | New Issue | |
2016-06-01 10:42 | Utkarsh Ayachit | Note Added: 0036038 | |
2016-08-12 10:00 | Kitware Robot | Note Added: 0039059 | |
2016-08-12 10:00 | Kitware Robot | Status | backlog => closed |
2016-08-12 10:00 | Kitware Robot | Resolution | open => moved |
2016-08-12 10:00 | Kitware Robot | Assigned To | => Kitware Robot |
