0016765 | ParaView | (No Category) | public | 2016-06-30 13:09 | 2016-08-12 10:00 | ||||
Summary | 0016765: Box clip fails for 2d surfaces. | ||||||||
Description | Box clip appears to fail clipping a 2d surface. Sphere clip works. Here is how to replicate. * 5.1.0, Linux, local server. * disk_out_ref.exo. Apply. * Slice. Apply. (we now have a 2d surface in a 3d view) * +X (we now can see the slice) * clip. Box. Now, drag in the left and right boundary lines of the box clip tool. Apply. Nothing shows. If you run Inside Out, everything shows. I suspect that the tool isn't being resized correctly. Works correctly in 3d (i.e., against the disk_out_ref itself. | ||||||||
Project | TBD | ||||||||
(0039082) Kitware Robot (administrator) 2016-08-12 10:00 |
2016-06-30 13:09 | Alan Scott | New Issue | |
2016-06-30 13:09 | Alan Scott | Assigned To | => Alan Scott |
2016-07-08 15:29 | Alan Scott | Assigned To | Alan Scott => |
2016-08-12 10:00 | Kitware Robot | Note Added: 0039082 | |
2016-08-12 10:00 | Kitware Robot | Status | backlog => closed |
2016-08-12 10:00 | Kitware Robot | Resolution | open => moved |
2016-08-12 10:00 | Kitware Robot | Assigned To | => Kitware Robot |
