0016775 | ParaView | (No Category) | public | 2016-07-08 13:53 | 2016-08-12 10:00 | ||||
Assigned To | T.J. Corona | ||||||||
Product Version | 5.0.1 | ||||||||
Summary | 0016775: Ruler doesn't stay visible! | ||||||||
Description | The ruler doesn't stay visible as you change selected filters in the pipeline browser. This needs to be fixed. I should give an example. * can.exo. Apply. * Sources/ Ruler. Apply. * Now, select the can. Ruler goes away. It needs to remain visible. | ||||||||
Project | Sandia | ||||||||
(0036336) Ken Moreland (manager) 2016-07-10 10:46 |
I'm sure the issue is that the entirety of the ruler's representation is considered a 3D widget. I think the requested change would be to make the line and label be represented as geometry/annotation. There should still be a 3D widget, but it really should only be used for placing the annotation, not representing it. |
(0039088) Kitware Robot (administrator) 2016-08-12 10:00 |
2016-07-08 13:53 | Alan Scott | New Issue | |
2016-07-08 13:53 | Alan Scott | Assigned To | => Alan Scott |
2016-07-08 13:54 | Alan Scott | Description Updated | |
2016-07-08 13:55 | Alan Scott | Assigned To | Alan Scott => |
2016-07-10 10:46 | Ken Moreland | Note Added: 0036336 | |
2016-07-25 17:08 | T.J. Corona | Assigned To | => T.J. Corona |
2016-07-25 17:08 | T.J. Corona | Status | backlog => active development |
2016-08-12 10:00 | Kitware Robot | Note Added: 0039088 | |
2016-08-12 10:00 | Kitware Robot | Status | active development => closed |
2016-08-12 10:00 | Kitware Robot | Resolution | open => moved |
