0002099 | ParaView | (No Category) | public | 2005-08-04 13:00 | 2009-12-10 06:53 | ||||
Reporter | Kent Eschenberg | ||||||||
Summary | 0002099: Cut Doesn't Remove Old Offsets | ||||||||
Description | Cut doesn't remove old offsets in the drawing after they are removed in the property sheet. Using 2.2.1 on Redhat Fedora Core 3. Test: read bluntfin.vts; add cut; add offset of 1 (2nd cut plane added to drawing; delete offset of 1; drawing of 2nd cut plane remains. | ||||||||
(0007799) Berk Geveci (administrator) 2007-06-02 14:08 |
Is this still valid for 3.0? |
2009-12-09 14:50 | Berk Geveci | Project | @3@ => ParaView |
2009-12-10 06:53 | Berk Geveci | Status | tabled => closed |
2009-12-10 06:53 | Berk Geveci | Resolution | open => fixed |
