0002205 | ParaView | (No Category) | public | 2005-09-02 04:11 | 2009-12-09 14:51 | ||||
Reporter | Johnny Devaprasad | ||||||||
Priority | normal | Severity | major | Reproducibility | unable to reproduce | ||||
Status | closed | Resolution | unable to reproduce | ||||||
Summary | 0002205: server crashes while loading data when number of procs>2 | ||||||||
Description | the server crashes with the following error messages when number of pvserver > 2, but after client connects to the server: Error message:Listen on port: 11111 Waiting for client... connected to port 11111 Client connected. Process id: 0 >> ERROR: In /home/johnny/app/paraview/paraview-2.2.1/VTK/IO/vtkDataReader.cxx, line 432 vtkDataSetReader (0x200d5e0): Unrecognized file type: ##* for file: (Null FileName) Process id: 0 >> ERROR: In /home/johnny/app/paraview/paraview-2.2.1/VTK/Filtering/vtkExecutive.cxx, line 680 vtkStreamingDemandDrivenPipeline (0x200d450): Algorithm vtkDataSetReader(0x200d5e0) returned failure for request: vtkInformation (0x200d8e0) Debug: Off Modified Time: 29862 Reference Count: 1 Registered Events: (none) ALGORITHM_AFTER_FORWARD: 1 FORWARD_DIRECTION: 0 REQUEST_DATA_OBJECT: 1 [node01:3] Fatal Error: Unexpected disconnect received from [node01:0] at line 1698 in file vapiutil.c [node01:2] Fatal Error: [node01:1] Fatal Error: Unexpected disconnect received from [node01:0] at line 1698 in file vapiutil.c Unexpected disconnect received from [node01:0] at line 1698 in file vapiutil.c | ||||||||
There are no notes attached to this issue. |
