0002363 | ParaView | (No Category) | public | 2005-10-13 11:50 | 2011-01-13 17:00 | ||||
Priority | low | Severity | major | Reproducibility | always | ||||
Summary | 0002363: SNL: ZSweep does not work with cell data | ||||||||
Description | ZSweep does not work with cell data. When you select it when rendering cell data, ParaView crashes. ZSweep should be changed to work correctly with cell data, not just removed from the options when rendering cell data. | ||||||||
Attached Files | ZSweep_edge_artifacts.png [^] (171,253 bytes) 1969-12-31 19:00
(0003133) Berk Geveci (administrator) 2005-10-13 13:01 |
I noticed that the priority for this bug is 1.3. Is this to make the 2.4 release? |
(0003164) François Bertel (reporter) 2005-10-19 09:49 |
Fixed the crash. However rendering cell data with the Zsweep method leads to a bad result because it interpolates scalar at vertices. See revision 1.5 (2005/10/19) of vtkUnstructuredGridVolumeZSweepMapper.cxx |
(0003172) François Bertel (reporter) 2005-10-21 12:47 |
Fixed the rendering result with cell data. See revisions (1.2 for .h and 1.5 for .cxx) from 2005/10/21. There are still some issues on edges. |
(0003173) François Bertel (reporter) 2005-10-21 13:14 |
correction to the last comment: revision 1.3 for .h and 1.6 for .cxx |
(0003174) Amy Squillacote (reporter) 2005-10-21 13:53 |
These changes have been added to the ParaView 2.6 branch as well. |
(0003176) Amy Squillacote (reporter) 2005-10-21 14:25 |
Actually it's the 2.4 branch... |
(0003180) Berk Geveci (administrator) 2005-10-24 10:59 |
Can someone check if the artifacts on edges are acceptable? I was told that it is not trivial to fix it. |
(0003205) Ken Moreland (manager) 2005-10-31 12:16 |
The artifacts I see in the attached image are not acceptable. |
(0003639) Berk Geveci (administrator) 2006-01-31 10:42 |
It is not clear how long this can take, probably 1 week or more. |
(0005460) Berk Geveci (administrator) 2006-10-18 15:37 |
Postpone after 2.6. |
(0019243) Ken Moreland (manager) 2010-01-21 12:55 |
This aged bug seems reasonably fixed. |
(0019247) Alan Scott (manager) 2010-01-21 16:44 |
Tested local server, with disk_out_ref.exo, then point to cell filter. Works fine. |
2010-01-21 12:55 | Ken Moreland | Note Added: 0019243 | |
2010-01-21 12:56 | Ken Moreland | Status | tabled => @80@ |
2010-01-21 12:56 | Ken Moreland | Resolution | open => fixed |
2010-01-21 16:44 | Alan Scott | Note Added: 0019247 | |
2010-01-21 16:44 | Alan Scott | Status | @80@ => closed |
2011-01-13 17:00 | Source_changeset_attached | => VTK master a2bd8391 | |
2011-01-13 17:00 | Source_changeset_attached | => VTK master 020ef709 | |
