0002499 | ParaView | (No Category) | public | 2005-11-16 13:19 | 2009-12-09 15:18 | ||||
Reporter | yvan.fournier | ||||||||
Summary | 0002499: SNL: Volume rendering not working with 'Multi-block' datasets | ||||||||
Description | Segmentation fault under Linux when trying to set display style to "volume rendering" on EnSight Data. Data is hexahedral (unstructured) mesh, with cell values; using "Tetrahedralize" and "Cell Data to Point Data" do not help (the stack backtrace is similar). The same bug occurs on the same machine with ParaView CVS (compiled from source) and 2.4 (paraview.org binary), not on 2.2.1 (paraview.org binary). It also occurs on another Linux machine running Debian (Sarge), so it does not seem to be system dependent. | ||||||||
Attached Files | backtrace.txt [^] (2,626 bytes) 1969-12-31 19:00 [Show Content]
simple.ensight.tar.gz [^] (9,579 bytes) 1969-12-31 19:00 | ||||||||
(0003591) Brian Wylie (reporter) 2006-01-22 12:04 |
It appears that any multi-block dataset does not work with volume rendering. Second way to Replicate: source->Hierarchical Fractal (small 3d) -> tetrahedralize -> volume rendering = core dump. Third way to Replicate: spcth/3DFlat -> tetrahedralize -> volume rendering = core dump. |
(0003640) Berk Geveci (administrator) 2006-01-31 10:44 |
There two separate issues associated with this: 1. volume rendering of AMR-like datasets. This is a long task and will not be addressed in the short term. 2. volume rendering of multi-block unstructured datasets. This would take about 1 week to fix. |
2009-12-09 15:18 | Berk Geveci | Status | tabled => closed |
2009-12-09 15:18 | Berk Geveci | Resolution | open => fixed |
