0002545 | ParaView | (No Category) | public | 2005-12-01 10:37 | 2009-12-09 14:51 | ||||
Reporter | Lee Ankeny | ||||||||
Summary | 0002545: SNL: Plotting improvements | ||||||||
Description | Specifically, I'd like to be able to plot log/log plots with the line probe filter. More generally, I'd like to have control over labeling, tic marks and everything else. Providing a filter that implements vtkXYPlotActor might be a good start. | ||||||||
(0003345) Brian Wylie (reporter) 2005-12-01 10:59 |
Lee, Just putting 'SNL:' on the feature so that it will be covered under our contract. |
(0003545) Brian Wylie (reporter) 2006-01-11 14:41 |
Deferred until ParaQ |
(0003553) Brian Wylie (reporter) 2006-01-12 19:58 |
I\'m going to change this feature request. This feature request is now a general \'Plotting improvements\' request. We need a specify Plotting functionality in ParaView (not part of pick or probe). The plotting functionality needs to make plotting much simpler than it is now. Specifically 1) pick a cell/node with the mouse or specify an ID 2) Temporal/Line probe choser (temporal as default) 3) Go (if temporal invoke \'play\') 4) Plotting options should includecontrol over labeling, tic marks and everything else. Providing a filter that implements vtkXYPlotActor might be a good start. 5) Temporal plots should be constructed ^once^ and then have a little dot indicating which time you are on if the user is going through time. |
(0003554) Brian Wylie (reporter) 2006-01-12 19:59 |
Also I would like the new plotting feature to be checked into the 2.4 branch as well. :) |
(0003631) Berk Geveci (administrator) 2006-01-31 10:26 |
This would take about 1 week. |
(0003813) Utkarsh Ayachit (administrator) 2006-02-28 10:34 |
Added a new Data Analysis filter that's a combination of both pick/probe with temporal support.One can query interpolated point data : * at a point * along a line * by point Id. One can query cell data : * for a cell nearest to a point. * by Cell Id. If the filter is connected to a reader with time support, temporal plot generation is available. There's a new GUI "Temporal Parameters" which one can use to generate the temporal plot. We no longer use the system animation. Additionally many plot parameters are changeable like titles/their positions/colors for curves,tick marks etc etc. This patch also includes fix for Bug 0002655 - SNL: Client/server state saved wrong. /cvsroot/ParaView/ParaView/GUI/Client/CMakeLists.txt,v <-- CMakeLists.txt new revision: 1.138; previous revision: 1.137 /cvsroot/ParaView/ParaView/GUI/Client/vtkPVArraySelection.cxx,v <-- vtkPVArraySelection.cxx new revision: 1.83; previous revision: 1.82 /cvsroot/ParaView/ParaView/GUI/Client/vtkPVArraySelection.h,v <-- vtkPVArraySelection.h new revision: 1.45; previous revision: 1.44 /cvsroot/ParaView/ParaView/GUI/Client/vtkPVDataAnalysis.cxx,v <-- vtkPVDataAnalysis.cxx initial revision: 1.1 /cvsroot/ParaView/ParaView/GUI/Client/vtkPVDataAnalysis.h,v <-- vtkPVDataAnalysis.h initial revision: 1.1 /cvsroot/ParaView/ParaView/GUI/Client/vtkPVLineSourceWidget.cxx,v <-- vtkPVLineSourceWidget.cxx new revision: 1.40; previous revision: 1.39 /cvsroot/ParaView/ParaView/GUI/Client/vtkPVPlotArraySelection.cxx,v <-- vtkPVPlotArraySelection.cxx initial revision: 1.1 /cvsroot/ParaView/ParaView/GUI/Client/vtkPVPlotArraySelection.h,v <-- vtkPVPlotArraySelection.h initial revision: 1.1 /cvsroot/ParaView/ParaView/GUI/Client/vtkPVPlotDisplayLabelPropertiesDialog.cxx,v <-- vtkPVPlotDisplayLabelPropertiesDialog.cxx initial revision: 1.1 /cvsroot/ParaView/ParaView/GUI/Client/vtkPVPlotDisplayLabelPropertiesDialog.h,v <-- vtkPVPlotDisplayLabelPropertiesDialog.h initial revision: 1.1 /cvsroot/ParaView/ParaView/GUI/Client/vtkPVPointSourceWidget.cxx,v <-- vtkPVPointSourceWidget.cxx new revision: 1.53; previous revision: 1.52 /cvsroot/ParaView/ParaView/GUI/Client/vtkPVPointSourceWidget.h,v <-- vtkPVPointSourceWidget.h new revision: 1.25; previous revision: 1.24 /cvsroot/ParaView/ParaView/GUI/Client/vtkPVPointWidget.cxx,v <-- vtkPVPointWidget.cxx new revision: 1.62; previous revision: 1.61 /cvsroot/ParaView/ParaView/GUI/Client/vtkPVProbe.cxx,v <-- vtkPVProbe.cxx new revision: 1.171; previous revision: 1.170 /cvsroot/ParaView/ParaView/GUI/Client/vtkPVReaderModule.cxx,v <-- vtkPVReaderModule.cxx new revision: 1.73; previous revision: 1.72 /cvsroot/ParaView/ParaView/GUI/Client/vtkPVSelectWidget.cxx,v <-- vtkPVSelectWidget.cxx new revision: 1.78; previous revision: 1.77 /cvsroot/ParaView/ParaView/GUI/Client/vtkPVSelectWidget.h,v <-- vtkPVSelectWidget.h new revision: 1.37; previous revision: 1.36 /cvsroot/ParaView/ParaView/GUI/Client/vtkPVSource.cxx,v <-- vtkPVSource.cxx new revision: 1.477; previous revision: 1.476 /cvsroot/ParaView/ParaView/GUI/Client/vtkPVSource.h,v <-- vtkPVSource.h new revision: 1.205; previous revision: 1.204 /cvsroot/ParaView/ParaView/GUI/Client/vtkPVTraceHelper.cxx,v <-- vtkPVTraceHelper.cxx new revision: 1.7; previous revision: 1.6 /cvsroot/ParaView/ParaView/GUI/Client/vtkPVTraceHelper.h,v <-- vtkPVTraceHelper.h new revision: 1.6; previous revision: 1.5 /cvsroot/ParaView/ParaView/GUI/Client/vtkPVWindow.cxx,v <-- vtkPVWindow.cxx new revision: 1.783; previous revision: 1.782 /cvsroot/ParaView/ParaView/GUI/Client/vtkPVWindow.h,v <-- vtkPVWindow.h new revision: 1.246; previous revision: 1.245 /cvsroot/ParaView/ParaView/GUI/Client/Resources/Filters.xml,v <-- Filters.xml new revision: 1.169; previous revision: 1.168 /cvsroot/ParaView/ParaView/Servers/Filters/CMakeLists.txt,v <-- CMakeLists.txt new revision: 1.85; previous revision: 1.84 /cvsroot/ParaView/ParaView/Servers/Filters/vtkDataAnalysisFilter.cxx,v <-- vtkDataAnalysisFilter.cxx initial revision: 1.1 /cvsroot/ParaView/ParaView/Servers/Filters/vtkDataAnalysisFilter.h,v <-- vtkDataAnalysisFilter.h initial revision: 1.1 /cvsroot/ParaView/ParaView/Servers/Filters/vtkPPickFilter.cxx,v <-- vtkPPickFilter.cxx initial revision: 1.1 /cvsroot/ParaView/ParaView/Servers/Filters/vtkPPickFilter.h,v <-- vtkPPickFilter.h initial revision: 1.1 /cvsroot/ParaView/ParaView/Servers/Filters/vtkPickFilter.h,v <-- vtkPickFilter.hnew revision: 1.9; previous revision: 1.8 /cvsroot/ParaView/ParaView/Servers/Filters/vtkTemporalCacheFilter.cxx,v <-- vtkTemporalCacheFilter.cxx initial revision: 1.1 /cvsroot/ParaView/ParaView/Servers/Filters/vtkTemporalCacheFilter.h,v <-- vtkTemporalCacheFilter.h initial revision: 1.1 /cvsroot/ParaView/ParaView/Servers/ServerManager/CMakeLists.txt,v <-- CMakeLists.txt new revision: 1.83; previous revision: 1.82 /cvsroot/ParaView/ParaView/Servers/ServerManager/vtkSMAnimationCueProxy.h,v <-- vtkSMAnimationCueProxy.h new revision: 1.10; previous revision: 1.9 /cvsroot/ParaView/ParaView/Servers/ServerManager/vtkSMTemporalXYPlotDisplayProxy.cxx,v <-- vtkSMTemporalXYPlotDisplayProxy.cxx initial revision: 1.1 /cvsroot/ParaView/ParaView/Servers/ServerManager/vtkSMTemporalXYPlotDisplayProxy.h,v <-- vtkSMTemporalXYPlotDisplayProxy.h initial revision: 1.1 /cvsroot/ParaView/ParaView/Servers/ServerManager/vtkSMXYPlotActorProxy.cxx,v <-- vtkSMXYPlotActorProxy.cxx new revision: 1.7; previous revision: 1.6 /cvsroot/ParaView/ParaView/Servers/ServerManager/vtkSMXYPlotActorProxy.h,v <-- vtkSMXYPlotActorProxy.h new revision: 1.6; previous revision: 1.5 /cvsroot/ParaView/ParaView/Servers/ServerManager/vtkSMXYPlotDisplayProxy.cxx,v <-- vtkSMXYPlotDisplayProxy.cxx new revision: 1.19; previous revision: 1.18 /cvsroot/ParaView/ParaView/Servers/ServerManager/vtkSMXYPlotDisplayProxy.h,v <-- vtkSMXYPlotDisplayProxy.h new revision: 1.13; previous revision: 1.12 /cvsroot/ParaView/ParaView/Servers/ServerManager/Resources/filters.xml,v <-- filters.xml new revision: 1.105; previous revision: 1.104 /cvsroot/ParaView/ParaView/Servers/ServerManager/Resources/rendering.xml,v <-- rendering.xml new revision: 1.70; previous revision: 1.69 /cvsroot/ParaView/ParaView/Servers/ServerManager/Resources/utilities.xml,v <-- utilities.xml new revision: 1.46; previous revision: 1.45 |
