0002652 | ParaView | (No Category) | public | 2005-12-19 10:02 | 2009-12-09 14:51 | ||||
Assigned To | Amy Squillacote | ||||||||
Summary | 0002652: SNL: Range of thrid component wrong. | ||||||||
Description | If you have some data with a 3-tuple array, then click on the Information tab to look at information about the Data Arrays, you will see that the range for the third component of the tuple is incorrect. Attached is a simple pvs file that demonstrates the bug. Look at the arrays of the calculator. | ||||||||
Attached Files | DataRangeBug.pvs [^] (18,394 bytes) 1969-12-31 19:00 | ||||||||
(0003450) Ken Moreland (manager) 2005-12-19 10:14 |
Correction: I only see this in client/server mode. Run the example with a 2-node server. |
(0003648) Berk Geveci (administrator) 2006-01-31 11:25 |
This would take about 2 days. |
(0005409) Amy Squillacote (reporter) 2006-10-16 11:02 |
This was only showing up in client/server mode because the problem was in copying array information (vtkPVArrayInformation) from a client server stream. The final component of a multi-component array was not being copied; we were not accounting for the fact that the magnitude of a multi-component array is also stored in array information (as the 0th component). This has now been corrected. /cvsroot/ParaView/ParaView/Servers/Common/vtkPVArrayInformation.cxx,v <-- vtkPVArrayInformation.cxx new revision: 1.6; previous revision: 1.5 |
