0002704 | ParaView | (No Category) | public | 2006-01-09 23:07 | 2011-01-13 17:00 | ||||
Reporter | Brian Wylie | ||||||||
Summary | 0002704: SNL: MAC client not getting correct visual | ||||||||
Description | There seems to be an issue with Sandia's MAC client. The stand alone works fine but the client does not get the correct visual and then of course looks dorky. This is not a Kitware issue at this point. :) | ||||||||
Attached Files | vtkXOpenGLRenderWindow.cxx.patch [^] (3,700 bytes) 1969-12-31 19:00 [Show Content] | ||||||||
(0003566) Brian Wylie (reporter) 2006-01-13 15:09 |
Berk, does kitware have a MAC they can test this on. Ken has reproduced this problem on his MAC but Thompson says he cannot. |
(0003586) Brian Wylie (reporter) 2006-01-19 14:27 |
I would like to check this into the 2.4 branch. |
(0003635) Berk Geveci (administrator) 2006-01-31 10:28 |
This may take 2 days. It is not clear as to what the problem is right now. We can't reproduce it. We built here and it runs fine. |
(0003661) Ken Moreland (manager) 2006-01-31 16:50 |
A-ha! The problem is that some Macs do not support alpha bit planes. When the AlphaBitPlanes flag was on, vtkXOpenGLRenderWindow failed to try visuals that did not have alpha bit planes (even though it tried getting rid of stereo, multiple samples, and depth buffers). I have attached a patch to vtkXOpenGLRenderWindow.cxx that should fix the problem. This change should definitly go to the ParaView 2.4 branch. |
(0003662) Amy Squillacote (reporter) 2006-02-01 10:37 |
The patch has been applied both on the head of the CVS tree and the ParaView-2-4 branch: /cvsroot/ParaView/ParaView/VTK/Rendering/vtkXOpenGLRenderWindow.cxx,v <-- vtkXOpenGLRenderWindow.cxx new revision: 1.61.2.3; previous revision: 1.61.2.2 /cvsroot/ParaView/ParaView/VTK/Rendering/vtkXOpenGLRenderWindow.cxx,v <-- vtkXOpenGLRenderWindow.cxx new revision: 1.70; previous revision: 1.69 |
2011-01-13 17:00 | Source_changeset_attached | => VTK master a2bd8391 | |
2011-01-13 17:00 | Source_changeset_attached | => VTK master 020ef709 | |
