For another project, please consult its home page to locate the current issue tracker.
0002710 | ParaView | (No Category) | public | 2006-01-11 18:13 | 2009-12-09 14:51 | ||||
Reporter | Andrew Maclean | ||||||||
Priority | urgent | Severity | major | Reproducibility | always | ||||
Summary | 0002710: Unable to build from the CVS, problem wuth configure for TCL/TK. | ||||||||
Description | If you build from an empty build directory there is a problem with: /usr/local/src/vtk/ParaView/Utilities/TclTk/tcl8.4.5/unix/configure. I have also attached CMakeCache.txt Here is the make output (edited): -- This is a CVS repository -- Using Buildname: Linux-c++ running /bin/sh "/usr/local/src/vtk/build/ParaView-build/Utilities/TclTk/configure_tcltk.sh" 2>&1 checking whether to use symlinks for manpages... no ... checking if 64bit Sparc VIS support is requested... no checking system version (for dynamic loading)... /usr/local/src/vtk/ParaView/Utilities/TclTk/tcl8.4.5/unix/configure: line 13936: syntax error near unexpected token `)' /usr/local/src/vtk/ParaView/Utilities/TclTk/tcl8.4.5/unix/configure: line 13936: ` OSF*)' -- This is a CVS repository -- Finding Atomic Data Sizes -- Finding a 64 Bit Integer -- Configuring done -- Generating done -- Build files have been written to: /usr/local/src/vtk/build/ParaView-build make: *** No targets specified and no makefile found. Stop. make[2]: *** [maketcltk] Error 1 make[1]: *** [Utilities/TclTk/CMakeFiles/maketcltk.dir/all] Error 2 make: *** [all] Error 2 | ||||||||
Attached Files | CMakeCache.txt [^] (71,607 bytes) 1969-12-31 19:00 [Show Content] [Hide Content]# This is the CMakeCache file. # For build in directory: /usr/local/src/vtk/build/ParaView-build # You can edit this file to change values found and used by cmake. # If you do not want to change any of the values, simply exit the editor. # If you do want to change a value, simply edit, save, and exit the editor. # The syntax for the file is as follows: # KEY:TYPE=VALUE # KEY is the name of a variable in the cache. # TYPE is a hint to GUI's for the type of VALUE, DO NOT EDIT TYPE!. # VALUE is the current value for the KEY. ######################## # EXTERNAL cache entries ######################## //Build the documentation (Doxygen). BUILD_DOCUMENTATION:BOOL=OFF //Build VTK examples. BUILD_EXAMPLES:BOOL=OFF //Build VTK with shared libraries. BUILD_SHARED_LIBS:BOOL=ON //Build the testing tree. BUILD_TESTING:BOOL=ON //Path to a program. CMAKE_AR:FILEPATH=/usr/bin/ar //For backwards compatibility, what version of CMake commands and // syntax should this version of CMake allow. CMAKE_BACKWARDS_COMPATIBILITY:STRING=2.3 //Choose the type of build, options are: None(CMAKE_CXX_FLAGS or // CMAKE_C_FLAGS used) Debug Release RelWithDebInfo MinSizeRel. // CMAKE_BUILD_TYPE:STRING=Release //CXX compiler. CMAKE_CXX_COMPILER:FILEPATH=/usr/bin/c++ //Flags used by the compiler during all build types. CMAKE_CXX_FLAGS:STRING=-Wall //Flags used by the compiler during debug builds. CMAKE_CXX_FLAGS_DEBUG:STRING=-g //Flags used by the compiler during release minsize builds. CMAKE_CXX_FLAGS_MINSIZEREL:STRING=-Os -DNDEBUG //Flags used by the compiler during release builds (/MD /Ob1 /Oi // /Ot /Oy /Gs will produce slightly less optimized but smaller // files). CMAKE_CXX_FLAGS_RELEASE:STRING=-O3 -DNDEBUG //Flags used by the compiler during Release with Debug Info builds. // CMAKE_CXX_FLAGS_RELWITHDEBINFO:STRING=-O2 -g //C compiler. CMAKE_C_COMPILER:FILEPATH=/usr/bin/gcc //Flags for C compiler. CMAKE_C_FLAGS:STRING=-Wall //Flags used by the compiler during debug builds. CMAKE_C_FLAGS_DEBUG:STRING=-g //Flags used by the compiler during release minsize builds. CMAKE_C_FLAGS_MINSIZEREL:STRING=-Os -DNDEBUG //Flags used by the compiler during release builds (/MD /Ob1 /Oi // /Ot /Oy /Gs will produce slightly less optimized but smaller // files). CMAKE_C_FLAGS_RELEASE:STRING=-O3 -DNDEBUG //Flags used by the compiler during Release with Debug Info builds. // CMAKE_C_FLAGS_RELWITHDEBINFO:STRING=-O2 -g //Flags used by the linker. CMAKE_EXE_LINKER_FLAGS:STRING= //Flags used by the linker during debug builds. CMAKE_EXE_LINKER_FLAGS_DEBUG:STRING= //Flags used by the linker during release minsize builds. CMAKE_EXE_LINKER_FLAGS_MINSIZEREL:STRING= //Flags used by the linker during release builds. CMAKE_EXE_LINKER_FLAGS_RELEASE:STRING= //Flags used by the linker during Release with Debug Info builds. // CMAKE_EXE_LINKER_FLAGS_RELWITHDEBINFO:STRING= //Use HP pthreads. CMAKE_HP_PTHREADS:BOOL=OFF //Install path prefix, prepended onto install directories. CMAKE_INSTALL_PREFIX:PATH=/usr/local //Path to a program. CMAKE_MAKE_PROGRAM:FILEPATH=/usr/bin/make //Flags used by the linker during the creation of modules. CMAKE_MODULE_LINKER_FLAGS:STRING= //Flags used by the linker during debug builds. CMAKE_MODULE_LINKER_FLAGS_DEBUG:STRING= //Flags used by the linker during release minsize builds. CMAKE_MODULE_LINKER_FLAGS_MINSIZEREL:STRING= //Flags used by the linker during release builds. CMAKE_MODULE_LINKER_FLAGS_RELEASE:STRING= //Flags used by the linker during Release with Debug Info builds. // CMAKE_MODULE_LINKER_FLAGS_RELWITHDEBINFO:STRING= //Path to a program. CMAKE_RANLIB:FILEPATH=/usr/bin/ranlib //Flags used by the linker during the creation of dll's. CMAKE_SHARED_LINKER_FLAGS:STRING= //Flags used by the linker during debug builds. CMAKE_SHARED_LINKER_FLAGS_DEBUG:STRING= //Flags used by the linker during release minsize builds. CMAKE_SHARED_LINKER_FLAGS_MINSIZEREL:STRING= //Flags used by the linker during release builds. CMAKE_SHARED_LINKER_FLAGS_RELEASE:STRING= //Flags used by the linker during Release with Debug Info builds. // CMAKE_SHARED_LINKER_FLAGS_RELWITHDEBINFO:STRING= //Thread library used. CMAKE_THREAD_LIBS:STRING=-lpthread //Use the pthreads library. CMAKE_USE_PTHREADS:BOOL=ON //If true, cmake will use relative paths in makefiles and projects. // CMAKE_USE_RELATIVE_PATHS:BOOL=OFF //Use sproc libs. CMAKE_USE_SPROC:BOOL=OFF //Use the win32 thread library. CMAKE_USE_WIN32_THREADS:BOOL=OFF //If this value is on, makefiles will be generated without the // .SILENT directive, and all commands will be echoed to the console // during the make. This is useful for debugging only. With Visual // Studio IDE projects all commands are done without /nologo. CMAKE_VERBOSE_MAKEFILE:BOOL=OFF //X11 extra flags. CMAKE_X_CFLAGS:STRING=-I/usr/X11R6/include //Libraries and options used in X11 programs. CMAKE_X_LIBS:STRING=-lSM;-lICE;-lSM;-lICE;/usr/X11R6/lib/libX11.so;/usr/X11R6/lib/libXext.so;/usr/X11R6/lib/libX11.so;/usr/X11R6/lib/libXext.so //Path to program used to compress files for transfer to the dart // server COMPRESSIONCOMMAND:FILEPATH=/bin/gzip //Path to the coverage program that CTest uses for performing coverage // inspection COVERAGE_COMMAND:FILEPATH=/usr/bin/gcov //Path to a program. CVSCOMMAND:FILEPATH=/usr/bin/cvs //Options passed to the cvs update command. CVS_UPDATE_OPTIONS:STRING=-d -A -P //Limit of reported errors, -1 reports all. DART_BUILD_ERROR_REPORT_LIMIT:BOOL=OFF //Limit of reported warnings, -1 reports all. DART_BUILD_WARNING_REPORT_LIMIT:BOOL=OFF //MAximum time allowed before CTest will kill the test. DART_TESTING_TIMEOUT:STRING=1500 //Show the actual output of the build, or if off show a . for each // 1024 bytes. DART_VERBOSE_BUILD:BOOL=OFF //Should Dart server send email when build errors are found in // Continuous builds? DELIVER_CONTINUOUS_EMAIL:BOOL=OFF //Value Computed by CMake DICOMParser_BINARY_DIR:STATIC=/usr/local/src/vtk/build/ParaView-build/VTK/Utilities/DICOMParser //Value Computed by CMake DICOMParser_SOURCE_DIR:STATIC=/usr/local/src/vtk/ParaView/VTK/Utilities/DICOMParser //Path to gunzip executable GUNZIPCOMMAND:FILEPATH=/bin/gunzip //Enable datasets larger than memory HDF5_ENABLE_HSIZET:BOOL=ON //Enable support for large (64-bit) files on Linux. HDF5_ENABLE_LINUX_LFS:BOOL=ON //Compile Stream Virtual File Driver support HDF5_STREAM_VFD:BOOL=ON //Value Computed by CMake HelloWorld_BINARY_DIR:STATIC=/usr/local/src/vtk/build/ParaView-build/GUI/Widgets/Examples/Tcl/HelloWorld //Value Computed by CMake HelloWorld_SOURCE_DIR:STATIC=/usr/local/src/vtk/ParaView/GUI/Widgets/Examples/Tcl/HelloWorld //Value Computed by CMake ICE_BINARY_DIR:STATIC=/usr/local/src/vtk/build/ParaView-build/Utilities/Xdmf/Ice //What is the path where the file fcntl.h can be found ICE_HAVE_FCNTL:PATH=/usr/include //What is the path where the file mman.h can be found ICE_HAVE_MMAN:PATH=/usr/include/sys //What is the path where the file in.h can be found ICE_HAVE_NETINET:PATH=/usr/include/netinet //Value Computed by CMake ICE_SOURCE_DIR:STATIC=/usr/local/src/vtk/ParaView/Utilities/Xdmf/Ice //Path to java command, used by the Dart server to create html. // JAVACOMMAND:FILEPATH=/usr/bin/java //Value Computed by CMake KWCommon_BINARY_DIR:STATIC=/usr/local/src/vtk/build/ParaView-build/Common/KWCommon //Dependencies for the target KWCommon_LIB_DEPENDS:STATIC=vtkFiltering;vtkGenericFiltering;vtkGraphics;vtkIO;vtkImaging;vtkRendering;vtksys; //Value Computed by CMake KWCommon_SOURCE_DIR:STATIC=/usr/local/src/vtk/ParaView/Common/KWCommon //Dependencies for target KWMedicalImageViewerExampleLib_LIB_DEPENDS:STATIC= //Value Computed by CMake KWWidgets_BINARY_DIR:STATIC=/usr/local/src/vtk/build/ParaView-build/GUI/Widgets //Dependencies for the target KWWidgets_LIB_DEPENDS:STATIC=vtkCommonTCL;vtkRendering;vtkVolumeRendering;vtkHybrid;vtkWidgets;vtkParallel;vtkpng;vtksys; //Value Computed by CMake KWWidgets_SOURCE_DIR:STATIC=/usr/local/src/vtk/ParaView/GUI/Widgets //Command used to build entire project from the command line. MAKECOMMAND:STRING=/usr/bin/make -i //Path to the memory checking command, used for memory error detection. // MEMORYCHECK_COMMAND:FILEPATH=/usr/bin/valgrind //File that contains suppressions for the memory checker MEMORYCHECK_SUPPRESSIONS_FILE:FILEPATH= //Value Computed by CMake MaterialLibrary_BINARY_DIR:STATIC=/usr/local/src/vtk/build/ParaView-build/VTK/Utilities/MaterialLibrary //Value Computed by CMake MaterialLibrary_SOURCE_DIR:STATIC=/usr/local/src/vtk/ParaView/VTK/Utilities/MaterialLibrary //Value Computed by CMake MedicalImageViewer_BINARY_DIR:STATIC=/usr/local/src/vtk/build/ParaView-build/GUI/Widgets/Examples/Tcl/MedicalImageViewer //Value Computed by CMake MedicalImageViewer_SOURCE_DIR:STATIC=/usr/local/src/vtk/ParaView/GUI/Widgets/Examples/Tcl/MedicalImageViewer //What is the path where the file GL/gl.h can be found OPENGL_INCLUDE_DIR:PATH=/usr/share/doc/NVIDIA_GLX-1.0/include //Where can one of the GL or MesaGL libraries be found OPENGL_gl_LIBRARY:FILEPATH=/usr/lib/libGL.so //Where can one of the GLU or MesaGLU libraries be found OPENGL_glu_LIBRARY:FILEPATH=/usr/lib/libGLU.so //What is the path where the file GL/xmesa.h can be found OPENGL_xmesa_INCLUDE_DIR:PATH=OPENGL_xmesa_INCLUDE_DIR-NOTFOUND //Build ParaView with enforced secure connection (--connect-id) // PARAVIEW_ALWAYS_SECURE_CONNECTION:BOOL=OFF //Build end user applications (ParaView, pvclient, pvbatch) PARAVIEW_BUILD_GUI:BOOL=ON //Build ParaView against the PVAdaptor private source library. // Requires Kitware License PARAVIEW_BUILD_WITH_ADAPTOR:BOOL=OFF //Build ParaView with Floating Point Exceptions turned on PARAVIEW_ENABLE_FPE:BOOL=OFF //Build ParaView with all experimental options PARAVIEW_EXPERIMENTAL_USER:BOOL=OFF //Extra modules that ParaView will try to import. The modules have // to provide ParaViewImport.cmake file. PARAVIEW_EXTRA_EXTERNAL_MODULES:STRING= //Use ParaView tree for Dart server. Should be OFF PARAVIEW_TESTING_DART_SERVER:BOOL=OFF //Build using SAF library. Requires access to SAF libraries PARAVIEW_USE_SAF:BOOL=OFF //Build using SSLIB_SAF library. Requires access to SSLIB_SAF libraries // PARAVIEW_USE_SSLIB_SAF:BOOL=OFF //Use system installed HDF5 PARAVIEW_USE_SYSTEM_HDF5:BOOL=OFF //Wrap ParaView server manager into Python PARAVIEW_WRAP_PYTHON:BOOL=OFF //Value Computed by CMake PVClientTests_BINARY_DIR:STATIC=/usr/local/src/vtk/build/ParaView-build/GUI/Testing //Value Computed by CMake PVClientTests_SOURCE_DIR:STATIC=/usr/local/src/vtk/ParaView/GUI/Testing //Value Computed by CMake PVClient_BINARY_DIR:STATIC=/usr/local/src/vtk/build/ParaView-build/GUI/Client //Value Computed by CMake PVClient_SOURCE_DIR:STATIC=/usr/local/src/vtk/ParaView/GUI/Client //Value Computed by CMake PVFilters_BINARY_DIR:STATIC=/usr/local/src/vtk/build/ParaView-build/Servers/Filters //Value Computed by CMake PVFilters_SOURCE_DIR:STATIC=/usr/local/src/vtk/ParaView/Servers/Filters //Value Computed by CMake PVGUI_BINARY_DIR:STATIC=/usr/local/src/vtk/build/ParaView-build/GUI //Value Computed by CMake PVGUI_SOURCE_DIR:STATIC=/usr/local/src/vtk/ParaView/GUI //Value Computed by CMake PVServerCommon_BINARY_DIR:STATIC=/usr/local/src/vtk/build/ParaView-build/Servers/Common //Value Computed by CMake PVServerCommon_SOURCE_DIR:STATIC=/usr/local/src/vtk/ParaView/Servers/Common //Value Computed by CMake PVServer_BINARY_DIR:STATIC=/usr/local/src/vtk/build/ParaView-build/Servers //Value Computed by CMake PVServer_SOURCE_DIR:STATIC=/usr/local/src/vtk/ParaView/Servers //Value Computed by CMake PVServers_BINARY_DIR:STATIC=/usr/local/src/vtk/build/ParaView-build/Servers/Executables //Value Computed by CMake PVServers_SOURCE_DIR:STATIC=/usr/local/src/vtk/ParaView/Servers/Executables //Command to run after a failed test to cleanup processes. Example: // "killall -9 rsh paraview" PV_TEST_CLEAN_COMMAND:STRING= //Path to a program. PYTHON_EXECUTABLE:FILEPATH=/usr/bin/python2.4 //Value Computed by CMake ParaView_BINARY_DIR:STATIC=/usr/local/src/vtk/build/ParaView-build //Value Computed by CMake ParaView_SOURCE_DIR:STATIC=/usr/local/src/vtk/ParaView //Value Computed by CMake PolygonalObjectViewer_BINARY_DIR:STATIC=/usr/local/src/vtk/build/ParaView-build/GUI/Widgets/Examples/Tcl/PolygonalObjectViewer //Value Computed by CMake PolygonalObjectViewer_SOURCE_DIR:STATIC=/usr/local/src/vtk/ParaView/GUI/Widgets/Examples/Tcl/PolygonalObjectViewer //Path to scp command, used by CTest for submitting results to // a Dart server SCPCOMMAND:FILEPATH=/usr/bin/scp //Name of the computer/site where compile is being run SITE:STRING=Theobromide //Dependencies for target SPCTH_LIB_DEPENDS:STATIC= //Path to a program. SVNCOMMAND:FILEPATH=SVNCOMMAND-NOTFOUND //Value Computed by CMake ServerManager_BINARY_DIR:STATIC=/usr/local/src/vtk/build/ParaView-build/Servers/ServerManager //Value Computed by CMake ServerManager_SOURCE_DIR:STATIC=/usr/local/src/vtk/ParaView/Servers/ServerManager //Where can one of the tcld, tcl84d, tcl8.4d, tcl83d, tcl8.3d, // tcl82d, tcl8.2d, tcl80d or tcl8.0d libraries be found TCL_LIBRARY_DEBUG:FILEPATH=TCL_LIBRARY_DEBUG-NOTFOUND //Where can one of the tclstubd, tclstub84d, tclstub8.4d, tclstub83d, // tclstub8.3d, tclstub82d, tclstub8.2d, tclstub80d or tclstub8.0d // libraries be found TCL_STUB_LIBRARY_DEBUG:FILEPATH=TCL_STUB_LIBRARY_DEBUG-NOTFOUND //Path to a program. TCL_TCLSH:FILEPATH=/usr/bin/tclsh //Test the MP2 writer used in saving animations TEST_MP2_WRITER:BOOL=OFF //Where can one of the tkd, tk84d, tk8.4d, tk83d, tk8.3d, tk82d, // tk8.2d, tk80d or tk8.0d libraries be found TK_LIBRARY_DEBUG:FILEPATH=TK_LIBRARY_DEBUG-NOTFOUND //Where can one of the tkstubd, tkstub84d, tkstub8.4d, tkstub83d, // tkstub8.3d, tkstub82d, tkstub8.2d, tkstub80d or tkstub8.0d libraries // be found TK_STUB_LIBRARY_DEBUG:FILEPATH=TK_STUB_LIBRARY_DEBUG-NOTFOUND //Path to a program. TK_WISH:FILEPATH=/usr/bin/wish //Value Computed by CMake TclTk_BINARY_DIR:STATIC=/usr/local/src/vtk/build/ParaView-build/Utilities/TclTk //Value Computed by CMake TclTk_SOURCE_DIR:STATIC=/usr/local/src/vtk/ParaView/Utilities/TclTk //Value Computed by CMake VTKCS_BINARY_DIR:STATIC=/usr/local/src/vtk/build/ParaView-build/Utilities/VTKClientServer //Value Computed by CMake VTKCS_SOURCE_DIR:STATIC=/usr/local/src/vtk/ParaView/Utilities/VTKClientServer //Value Computed by CMake VTKEXPAT_BINARY_DIR:STATIC=/usr/local/src/vtk/build/ParaView-build/VTK/Utilities/vtkexpat //Value Computed by CMake VTKEXPAT_SOURCE_DIR:STATIC=/usr/local/src/vtk/ParaView/VTK/Utilities/vtkexpat //Value Computed by CMake VTKFREETYPE_BINARY_DIR:STATIC=/usr/local/src/vtk/build/ParaView-build/VTK/Utilities/vtkfreetype //Value Computed by CMake VTKFREETYPE_SOURCE_DIR:STATIC=/usr/local/src/vtk/ParaView/VTK/Utilities/vtkfreetype //Value Computed by CMake VTKFTGL_BINARY_DIR:STATIC=/usr/local/src/vtk/build/ParaView-build/VTK/Utilities/ftgl //Value Computed by CMake VTKFTGL_SOURCE_DIR:STATIC=/usr/local/src/vtk/ParaView/VTK/Utilities/ftgl //Value Computed by CMake VTKHDF5_BINARY_DIR:STATIC=/usr/local/src/vtk/build/ParaView-build/Utilities/hdf5 //Value Computed by CMake VTKHDF5_SOURCE_DIR:STATIC=/usr/local/src/vtk/ParaView/Utilities/hdf5 //Value Computed by CMake VTKJPEG_BINARY_DIR:STATIC=/usr/local/src/vtk/build/ParaView-build/VTK/Utilities/vtkjpeg //Value Computed by CMake VTKJPEG_SOURCE_DIR:STATIC=/usr/local/src/vtk/ParaView/VTK/Utilities/vtkjpeg //Value Computed by CMake VTKNETCDF_BINARY_DIR:STATIC=/usr/local/src/vtk/build/ParaView-build/VTK/Utilities/vtknetcdf //Value Computed by CMake VTKNETCDF_SOURCE_DIR:STATIC=/usr/local/src/vtk/ParaView/VTK/Utilities/vtknetcdf //Value Computed by CMake VTKPNG_BINARY_DIR:STATIC=/usr/local/src/vtk/build/ParaView-build/VTK/Utilities/vtkpng //Value Computed by CMake VTKPNG_SOURCE_DIR:STATIC=/usr/local/src/vtk/ParaView/VTK/Utilities/vtkpng //Value Computed by CMake VTKTIFF_BINARY_DIR:STATIC=/usr/local/src/vtk/build/ParaView-build/VTK/Utilities/vtktiff //Value Computed by CMake VTKTIFF_SOURCE_DIR:STATIC=/usr/local/src/vtk/ParaView/VTK/Utilities/vtktiff //Value Computed by CMake VTKTclWrapping_BINARY_DIR:STATIC=/usr/local/src/vtk/build/ParaView-build/Utilities/VTKTclWrapping //Value Computed by CMake VTKTclWrapping_SOURCE_DIR:STATIC=/usr/local/src/vtk/ParaView/Utilities/VTKTclWrapping //Value Computed by CMake VTKZLIB_BINARY_DIR:STATIC=/usr/local/src/vtk/build/ParaView-build/VTK/Utilities/vtkzlib //Value Computed by CMake VTKZLIB_SOURCE_DIR:STATIC=/usr/local/src/vtk/ParaView/VTK/Utilities/vtkzlib //Value Computed by CMake VTK_BINARY_DIR:STATIC=/usr/local/src/vtk/build/ParaView-build/VTK //What is the path where the file VTKData.readme can be found VTK_DATA_ROOT:PATH=/usr/local/src/vtk/VTKData //Build leak checking support into VTK. VTK_DEBUG_LEAKS:BOOL=OFF //Location of the OpenGL extensions header file (glext.h). VTK_GLEXT_FILE:FILEPATH=/usr/local/src/vtk/ParaView/VTK/Utilities/ParseOGLExt/headers/glext.h //Location of the GLX extensions header file (glxext.h). VTK_GLXEXT_FILE:FILEPATH=/usr/local/src/vtk/ParaView/VTK/Utilities/ParseOGLExt/headers/glxext.h //Remove all legacy code completely. VTK_LEGACY_REMOVE:BOOL=OFF //Silence all legacy code messages. VTK_LEGACY_SILENT:BOOL=OFF //; separated directories to search for materials/shaders VTK_MATERIALS_DIRS:STRING=/usr/local/src/vtk/build/ParaView-build/VTK/Utilities/MaterialLibrary/Repository //The opengl library being used supports off screen Mesa calls. // VTK_OPENGL_HAS_OSMESA:BOOL=OFF //Value Computed by CMake VTK_SOURCE_DIR:STATIC=/usr/local/src/vtk/ParaView/VTK //Build VTK with 64 bit ids VTK_USE_64BIT_IDS:BOOL=OFF //Build pixel and vertex shader support for Cg. VTK_USE_CG_SHADERS:BOOL=OFF //Turn this option off and tests will not popup windows VTK_USE_DISPLAY:BOOL=ON //Build pixel and vertex shader support for GLSL. VTK_USE_GLSL_SHADERS:BOOL=OFF //Build VTK with GUI Support VTK_USE_GUISUPPORT:BOOL=OFF //Use mangled Mesa with OpenGL. VTK_USE_MANGLED_MESA:BOOL=OFF //Use Message Passing Interface (MPI) library for parallel support. // VTK_USE_MPI:BOOL=OFF //Build shared libraries with rpath. This makes it easy to run // executables from the build tree when using shared libraries, // but removes install support. VTK_USE_RPATH:BOOL=OFF //Use the system's expat library. VTK_USE_SYSTEM_EXPAT:BOOL=OFF //Use the system's freetype library. VTK_USE_SYSTEM_FREETYPE:BOOL=OFF //Use the system's jpeg library. VTK_USE_SYSTEM_JPEG:BOOL=OFF //Use the system's png library. VTK_USE_SYSTEM_PNG:BOOL=OFF //Use the system's tiff library. VTK_USE_SYSTEM_TIFF:BOOL=OFF //Use the system's zlib library. VTK_USE_SYSTEM_ZLIB:BOOL=OFF //Location of the WGL extensions header file (wglext.h). VTK_WGLEXT_FILE:FILEPATH=/usr/local/src/vtk/ParaView/VTK/Utilities/ParseOGLExt/headers/wglext.h //Path to an internal program. VTK_WRAP_ClientServer_EXE:FILEPATH=/usr/local/src/vtk/build/ParaView-build/bin/vtkWrapClientServer //Where can the hints file be found VTK_WRAP_HINTS:FILEPATH=/usr/local/src/vtk/ParaView/VTK/Wrapping/hints //Value Computed by CMake WidgetsTour_BINARY_DIR:STATIC=/usr/local/src/vtk/build/ParaView-build/GUI/Widgets/Examples/Tcl/WidgetsTour //Value Computed by CMake WidgetsTour_SOURCE_DIR:STATIC=/usr/local/src/vtk/ParaView/GUI/Widgets/Examples/Tcl/WidgetsTour //Value Computed by CMake WindowWithPanels_BINARY_DIR:STATIC=/usr/local/src/vtk/build/ParaView-build/GUI/Widgets/Examples/Tcl/WindowWithPanels //Value Computed by CMake WindowWithPanels_SOURCE_DIR:STATIC=/usr/local/src/vtk/ParaView/GUI/Widgets/Examples/Tcl/WindowWithPanels //What is the path where the file X11/X.h can be found X11_X11_INCLUDE_PATH:PATH=/usr/X11R6/include //Where can the X11 library be found X11_X11_LIB:FILEPATH=/usr/X11R6/lib/libX11.so //Where can the Xext library be found X11_Xext_LIB:FILEPATH=/usr/X11R6/lib/libXext.so //What is the path where the file X11/Xlib.h can be found X11_Xlib_INCLUDE_PATH:PATH=/usr/X11R6/include //What is the path where the file X11/Xutil.h can be found X11_Xutil_INCLUDE_PATH:PATH=/usr/X11R6/include //XDMF has Network Distributed Global Memory (NDGM) XDMF_HAS_NDGM:BOOL=OFF //Value Computed by CMake Xdmf_BINARY_DIR:STATIC=/usr/local/src/vtk/build/ParaView-build/Utilities/Xdmf //Dependencies for the target Xdmf_LIB_DEPENDS:STATIC=vtkhdf5;vtkexpat; //Value Computed by CMake Xdmf_SOURCE_DIR:STATIC=/usr/local/src/vtk/ParaView/Utilities/Xdmf //Value Computed by CMake spcth_BINARY_DIR:STATIC=/usr/local/src/vtk/build/ParaView-build/Utilities/SPCTH //Value Computed by CMake spcth_SOURCE_DIR:STATIC=/usr/local/src/vtk/ParaView/Utilities/SPCTH //Dependencies for the target vtkClientServer_LIB_DEPENDS:STATIC=vtkCommon; //Dependencies for the target vtkCommonCS_LIB_DEPENDS:STATIC=vtkClientServer;vtkCommon; //Dependencies for the target vtkCommonTCL_LIB_DEPENDS:STATIC=vtkCommon;vtkIO;vtkRendering;/usr/local/src/vtk/build/ParaView-build/Utilities/TclTk/tcl8.4.5/unix/libtcl8.4.a;/usr/local/src/vtk/build/ParaView-build/Utilities/TclTk/tk8.4.5/unix/libtk8.4.a;-lm;-lXt;-lSM;-lICE;-lSM;-lICE;/usr/X11R6/lib/libX11.so;/usr/X11R6/lib/libXext.so;/usr/X11R6/lib/libX11.so;/usr/X11R6/lib/libXext.so; //Dependencies for the target vtkCommon_LIB_DEPENDS:STATIC=vtksys;-lpthread;-ldl;-lm; //Dependencies for target vtkDICOMParser_LIB_DEPENDS:STATIC= //Value Computed by CMake vtkExodus2_BINARY_DIR:STATIC=/usr/local/src/vtk/build/ParaView-build/VTK/Utilities/vtkexodus2 //Value Computed by CMake vtkExodus2_SOURCE_DIR:STATIC=/usr/local/src/vtk/ParaView/VTK/Utilities/vtkexodus2 //Dependencies for the target vtkFilteringCS_LIB_DEPENDS:STATIC=vtkClientServer;vtkFiltering;vtkCommonCS; //Dependencies for the target vtkFiltering_LIB_DEPENDS:STATIC=vtkCommon; //Dependencies for the target vtkGenericFilteringCS_LIB_DEPENDS:STATIC=vtkClientServer;vtkGenericFiltering;vtkFilteringCS; //Dependencies for the target vtkGenericFiltering_LIB_DEPENDS:STATIC=vtkFiltering;vtkGraphics; //Dependencies for the target vtkGraphicsCS_LIB_DEPENDS:STATIC=vtkClientServer;vtkGraphics;vtkFilteringCS; //Dependencies for the target vtkGraphics_LIB_DEPENDS:STATIC=vtkFiltering; //Dependencies for the target vtkHybridCS_LIB_DEPENDS:STATIC=vtkClientServer;vtkHybrid;vtkRenderingCS; //Dependencies for the target vtkHybrid_LIB_DEPENDS:STATIC=vtkRendering;vtkIO;vtkexoIIc; //Dependencies for the target vtkIOCS_LIB_DEPENDS:STATIC=vtkClientServer;vtkIO;vtkFilteringCS; //Dependencies for the target vtkIO_LIB_DEPENDS:STATIC=vtkFiltering;vtkDICOMParser;vtkpng;vtkzlib;vtkjpeg;vtktiff;vtkexpat;vtksys;vtkMPEG2Encode; //Dependencies for the target vtkImagingCS_LIB_DEPENDS:STATIC=vtkClientServer;vtkImaging;vtkFilteringCS; //Dependencies for the target vtkImaging_LIB_DEPENDS:STATIC=vtkFiltering; //Dependencies for the target vtkKWParaViewCS_LIB_DEPENDS:STATIC=vtkClientServer;vtkKWParaView;vtkPVFiltersCS;vtkPVServerCommonCS; //Dependencies for the target vtkKWParaView_LIB_DEPENDS:STATIC=KWCommon;KWWidgets;vtkPVServerManagerTCL;vtkPVServerCommonTCL;vtkPVFilters;vtkXdmfCS; //Value Computed by CMake vtkMPEG2Encode_BINARY_DIR:STATIC=/usr/local/src/vtk/build/ParaView-build/VTK/Utilities/vtkmpeg2encode //Dependencies for target vtkMPEG2Encode_LIB_DEPENDS:STATIC= //Value Computed by CMake vtkMPEG2Encode_SOURCE_DIR:STATIC=/usr/local/src/vtk/ParaView/VTK/Utilities/vtkmpeg2encode //Dependencies for target vtkNetCDF_LIB_DEPENDS:STATIC= //Dependencies for the target vtkPVFiltersCS_LIB_DEPENDS:STATIC=vtkClientServer;vtkPVFilters;vtkParallelCS;vtkHybridCS;vtkRenderingCS;vtkVolumeRenderingCS; //Dependencies for the target vtkPVFilters_LIB_DEPENDS:STATIC=vtkPVServerCommon;vtkPVServerCommonCS;vtkXdmfCS;vtkHybridCS;vtkParallelCS;vtkVolumeRenderingCS;vtkWidgetsCS;KWCommon;vtksys;vtkhdf5;SPCTH;vtkClientServer; //Dependencies for the target vtkPVServerCommonCS_LIB_DEPENDS:STATIC=vtkClientServer;vtkPVServerCommon;vtkParallelCS;vtkHybridCS;vtkRenderingCS; //Dependencies for the target vtkPVServerCommonTCL_LIB_DEPENDS:STATIC=vtkPVServerCommon;vtkCommonTCL; //Dependencies for the target vtkPVServerCommon_LIB_DEPENDS:STATIC=vtkHybridCS;vtkParallelCS;KWCommon;vtksys;vtkhdf5;vtkClientServer; //Dependencies for the target vtkPVServerManagerTCL_LIB_DEPENDS:STATIC=vtkPVServerManager;vtkCommonTCL;vtkPVServerCommonTCL; //Dependencies for the target vtkPVServerManager_LIB_DEPENDS:STATIC=vtkPVFiltersCS;vtkClientServer;KWCommon; //Dependencies for the target vtkParallelCS_LIB_DEPENDS:STATIC=vtkClientServer;vtkParallel;vtkRenderingCS; //Dependencies for the target vtkParallel_LIB_DEPENDS:STATIC=vtkRendering;vtkIO;vtkexoIIc; //Dependencies for the target vtkRenderingCS_LIB_DEPENDS:STATIC=vtkClientServer;vtkRendering;vtkGenericFilteringCS;vtkGraphicsCS;vtkImagingCS;vtkIOCS; //Dependencies for the target vtkRendering_LIB_DEPENDS:STATIC=vtkGraphics;vtkImaging;vtkIO;vtkftgl;vtkfreetype;/usr/lib/libGL.so;-lXt;-lSM;-lICE;-lSM;-lICE;-lSM;-lICE;/usr/X11R6/lib/libX11.so;/usr/X11R6/lib/libXext.so;/usr/X11R6/lib/libX11.so;/usr/X11R6/lib/libXext.so;/usr/X11R6/lib/libX11.so;/usr/X11R6/lib/libXext.so; //Dependencies for the target vtkVolumeRenderingCS_LIB_DEPENDS:STATIC=vtkClientServer;vtkVolumeRendering;vtkRenderingCS; //Dependencies for the target vtkVolumeRendering_LIB_DEPENDS:STATIC=vtkRendering;vtkIO; //Dependencies for the target vtkWidgetsCS_LIB_DEPENDS:STATIC=vtkClientServer;vtkWidgets;vtkRenderingCS; //Dependencies for the target vtkWidgets_LIB_DEPENDS:STATIC=vtkRendering;vtkHybrid; //Dependencies for the target vtkXdmfCS_LIB_DEPENDS:STATIC=vtkClientServer;vtkXdmf;vtkRenderingCS; //Dependencies for the target vtkXdmf_LIB_DEPENDS:STATIC=vtkIO;Xdmf;vtkRendering;vtkParallel; //Dependencies for the target vtkexoIIc_LIB_DEPENDS:STATIC=vtkNetCDF; //Dependencies for target vtkexpat_LIB_DEPENDS:STATIC= //Dependencies for target vtkfreetype_LIB_DEPENDS:STATIC= //Dependencies for the target vtkftgl_LIB_DEPENDS:STATIC=/usr/lib/libGL.so;vtkfreetype; //Dependencies for the target vtkhdf5_LIB_DEPENDS:STATIC=m;vtkzlib; //Dependencies for target vtkjpeg_LIB_DEPENDS:STATIC= //Dependencies for the target vtkpng_LIB_DEPENDS:STATIC=vtkzlib; //Value Computed by CMake vtksys_BINARY_DIR:STATIC=/usr/local/src/vtk/build/ParaView-build/VTK/Utilities/kwsys //Dependencies for target vtksys_LIB_DEPENDS:STATIC= //Value Computed by CMake vtksys_SOURCE_DIR:STATIC=/usr/local/src/vtk/ParaView/VTK/Utilities/kwsys //Dependencies for the target vtktiff_LIB_DEPENDS:STATIC=vtkzlib;vtkjpeg; //Dependencies for target vtkzlib_LIB_DEPENDS:STATIC= ######################## # INTERNAL cache entries ######################## //Executable to project name. /usr/local/src/vtk/build/ParaView-build/bin/vtkWrapClientServer:INTERNAL=vtkWrapClientServer //Host Arcitecture : Linux IRIXN32 IRIX64 AIX CYGWIN ARCH_TO_BUILD:INTERNAL=Linux //Advanced flag for variable: BUILD_DOCUMENTATION BUILD_DOCUMENTATION-ADVANCED:INTERNAL=1 //Advanced flag for variable: BUILD_EXAMPLES BUILD_EXAMPLES-ADVANCED:INTERNAL=1 //Modified flag for variable: BUILD_SHARED_LIBS BUILD_SHARED_LIBS-MODIFIED:INTERNAL=1 //Advanced flag for variable: BUILD_TESTING BUILD_TESTING-ADVANCED:INTERNAL=1 //Result of TRY_COMPILE CMAKE_ANSI_FOR_SCOPE:INTERNAL=TRUE //Have include iostream CMAKE_ANSI_STREAM_HEADERS:INTERNAL=1 //Advanced flag for variable: CMAKE_AR CMAKE_AR-ADVANCED:INTERNAL=1 //Advanced flag for variable: CMAKE_BUILD_TOOL CMAKE_BUILD_TOOL-ADVANCED:INTERNAL=1 //What is the target build tool cmake is generating for. CMAKE_BUILD_TOOL:INTERNAL=/usr/bin/make //Modified flag for variable: CMAKE_BUILD_TYPE CMAKE_BUILD_TYPE-MODIFIED:INTERNAL=1 //This is the directory where this CMakeCahe.txt was created CMAKE_CACHEFILE_DIR:INTERNAL=/usr/local/src/vtk/build/ParaView-build //Major version of cmake used to create the current loaded cache // CMAKE_CACHE_MAJOR_VERSION:INTERNAL=2 //Minor version of cmake used to create the current loaded cache // CMAKE_CACHE_MINOR_VERSION:INTERNAL=3 //Major version of cmake used to create the current loaded cache // CMAKE_CACHE_RELEASE_VERSION:INTERNAL=development //Path to CMake executable. CMAKE_COMMAND:INTERNAL=/usr/local/bin/cmake //Advanced flag for variable: CMAKE_CTEST_COMMAND CMAKE_CTEST_COMMAND-ADVANCED:INTERNAL=1 //Path to ctest program executable. CMAKE_CTEST_COMMAND:INTERNAL=/usr/local/bin/ctest //Advanced flag for variable: CMAKE_CXX_COMPILER CMAKE_CXX_COMPILER-ADVANCED:INTERNAL=1 //full path to the compiler cmake found CMAKE_CXX_COMPILER_FULLPATH:INTERNAL=/usr/bin/c++ CMAKE_CXX_COMPILER_WORKS:INTERNAL=1 //Advanced flag for variable: CMAKE_CXX_FLAGS CMAKE_CXX_FLAGS-ADVANCED:INTERNAL=1 //Modified flag for variable: CMAKE_CXX_FLAGS CMAKE_CXX_FLAGS-MODIFIED:INTERNAL=1 //Advanced flag for variable: CMAKE_CXX_FLAGS_DEBUG CMAKE_CXX_FLAGS_DEBUG-ADVANCED:INTERNAL=1 //Advanced flag for variable: CMAKE_CXX_FLAGS_MINSIZEREL CMAKE_CXX_FLAGS_MINSIZEREL-ADVANCED:INTERNAL=1 //Advanced flag for variable: CMAKE_CXX_FLAGS_RELEASE CMAKE_CXX_FLAGS_RELEASE-ADVANCED:INTERNAL=1 //Advanced flag for variable: CMAKE_CXX_FLAGS_RELWITHDEBINFO CMAKE_CXX_FLAGS_RELWITHDEBINFO-ADVANCED:INTERNAL=1 //Advanced flag for variable: CMAKE_C_COMPILER CMAKE_C_COMPILER-ADVANCED:INTERNAL=1 //full path to the compiler cmake found CMAKE_C_COMPILER_FULLPATH:INTERNAL=/usr/bin/gcc CMAKE_C_COMPILER_WORKS:INTERNAL=1 //Advanced flag for variable: CMAKE_C_FLAGS CMAKE_C_FLAGS-ADVANCED:INTERNAL=1 //Modified flag for variable: CMAKE_C_FLAGS CMAKE_C_FLAGS-MODIFIED:INTERNAL=1 //Advanced flag for variable: CMAKE_C_FLAGS_DEBUG CMAKE_C_FLAGS_DEBUG-ADVANCED:INTERNAL=1 //Advanced flag for variable: CMAKE_C_FLAGS_MINSIZEREL CMAKE_C_FLAGS_MINSIZEREL-ADVANCED:INTERNAL=1 //Advanced flag for variable: CMAKE_C_FLAGS_RELEASE CMAKE_C_FLAGS_RELEASE-ADVANCED:INTERNAL=1 //Advanced flag for variable: CMAKE_C_FLAGS_RELWITHDEBINFO CMAKE_C_FLAGS_RELWITHDEBINFO-ADVANCED:INTERNAL=1 //Path to cache edit program executable. CMAKE_EDIT_COMMAND:INTERNAL=/usr/local/bin/ccmake //Advanced flag for variable: CMAKE_EXE_LINKER_FLAGS CMAKE_EXE_LINKER_FLAGS-ADVANCED:INTERNAL=1 //Advanced flag for variable: CMAKE_EXE_LINKER_FLAGS_DEBUG CMAKE_EXE_LINKER_FLAGS_DEBUG-ADVANCED:INTERNAL=1 //Advanced flag for variable: CMAKE_EXE_LINKER_FLAGS_MINSIZEREL // CMAKE_EXE_LINKER_FLAGS_MINSIZEREL-ADVANCED:INTERNAL=1 //Advanced flag for variable: CMAKE_EXE_LINKER_FLAGS_RELEASE CMAKE_EXE_LINKER_FLAGS_RELEASE-ADVANCED:INTERNAL=1 //Advanced flag for variable: CMAKE_EXE_LINKER_FLAGS_RELWITHDEBINFO // CMAKE_EXE_LINKER_FLAGS_RELWITHDEBINFO-ADVANCED:INTERNAL=1 //Name of generator. CMAKE_GENERATOR:INTERNAL=Unix Makefiles //Have include sstream CMAKE_HAS_ANSI_STRING_STREAM:INTERNAL=1 //Is X11 around. CMAKE_HAS_X:INTERNAL=1 //Have function connect CMAKE_HAVE_CONNECT:INTERNAL=1 //Have function gethostbyname CMAKE_HAVE_GETHOSTBYNAME:INTERNAL=1 //Have include limits.h CMAKE_HAVE_LIMITS_H:INTERNAL=1 //Have library pthreads CMAKE_HAVE_PTHREADS_CREATE:INTERNAL= //Have library pthread CMAKE_HAVE_PTHREAD_CREATE:INTERNAL=1 //Have include pthread.h CMAKE_HAVE_PTHREAD_H:INTERNAL=1 //Have function remove CMAKE_HAVE_REMOVE:INTERNAL=1 //Have function shmat CMAKE_HAVE_SHMAT:INTERNAL=1 //Have include CMAKE_HAVE_SYS_PRCTL_H CMAKE_HAVE_SYS_PRCTL_H:INTERNAL=1 //Have include unistd.h CMAKE_HAVE_UNISTD_H:INTERNAL=1 //Start directory with the top level CMakeLists.txt file for this // project CMAKE_HOME_DIRECTORY:INTERNAL=/usr/local/src/vtk/ParaView //Advanced flag for variable: CMAKE_HP_PTHREADS CMAKE_HP_PTHREADS-ADVANCED:INTERNAL=1 //Have library ICE CMAKE_LIB_ICE_HAS_ICECONNECTIONNUMBER:INTERNAL=1 //Advanced flag for variable: CMAKE_MAKE_PROGRAM CMAKE_MAKE_PROGRAM-ADVANCED:INTERNAL=1 //Advanced flag for variable: CMAKE_MODULE_LINKER_FLAGS CMAKE_MODULE_LINKER_FLAGS-ADVANCED:INTERNAL=1 //Advanced flag for variable: CMAKE_MODULE_LINKER_FLAGS_DEBUG CMAKE_MODULE_LINKER_FLAGS_DEBUG-ADVANCED:INTERNAL=1 //Advanced flag for variable: CMAKE_MODULE_LINKER_FLAGS_MINSIZEREL // CMAKE_MODULE_LINKER_FLAGS_MINSIZEREL-ADVANCED:INTERNAL=1 //Advanced flag for variable: CMAKE_MODULE_LINKER_FLAGS_RELEASE // CMAKE_MODULE_LINKER_FLAGS_RELEASE-ADVANCED:INTERNAL=1 //Advanced flag for variable: CMAKE_MODULE_LINKER_FLAGS_RELWITHDEBINFO // CMAKE_MODULE_LINKER_FLAGS_RELWITHDEBINFO-ADVANCED:INTERNAL=1 //Does the compiler support ansi for scope. CMAKE_NO_ANSI_FOR_SCOPE:INTERNAL=0 //Advanced flag for variable: CMAKE_NO_ANSI_STREAM_HEADERS CMAKE_NO_ANSI_STREAM_HEADERS-ADVANCED:INTERNAL=1 //Does the compiler support headers like iostream. CMAKE_NO_ANSI_STREAM_HEADERS:INTERNAL=0 //Does the compiler support std::. CMAKE_NO_STD_NAMESPACE:INTERNAL=0 //number of local generators CMAKE_NUMBER_OF_LOCAL_GENERATORS:INTERNAL=125 //Advanced flag for variable: CMAKE_RANLIB CMAKE_RANLIB-ADVANCED:INTERNAL=1 //Path to CMake installation. CMAKE_ROOT:INTERNAL=/usr/local/share/CMake //Advanced flag for variable: CMAKE_SHARED_LINKER_FLAGS CMAKE_SHARED_LINKER_FLAGS-ADVANCED:INTERNAL=1 //Advanced flag for variable: CMAKE_SHARED_LINKER_FLAGS_DEBUG CMAKE_SHARED_LINKER_FLAGS_DEBUG-ADVANCED:INTERNAL=1 //Advanced flag for variable: CMAKE_SHARED_LINKER_FLAGS_MINSIZEREL // CMAKE_SHARED_LINKER_FLAGS_MINSIZEREL-ADVANCED:INTERNAL=1 //Advanced flag for variable: CMAKE_SHARED_LINKER_FLAGS_RELEASE // CMAKE_SHARED_LINKER_FLAGS_RELEASE-ADVANCED:INTERNAL=1 //Advanced flag for variable: CMAKE_SHARED_LINKER_FLAGS_RELWITHDEBINFO // CMAKE_SHARED_LINKER_FLAGS_RELWITHDEBINFO-ADVANCED:INTERNAL=1 //Result of TRY_RUN CMAKE_SIZEOF_CHAR:INTERNAL=1 //Result of TRY_RUN CMAKE_SIZEOF_DOUBLE:INTERNAL=8 //Result of TRY_RUN CMAKE_SIZEOF_FLOAT:INTERNAL=4 //Result of TRY_RUN CMAKE_SIZEOF_INT:INTERNAL=4 //Result of TRY_RUN CMAKE_SIZEOF_LONG:INTERNAL=4 //Result of TRY_RUN CMAKE_SIZEOF_SHORT:INTERNAL=2 //Result of TRY_RUN CMAKE_SIZEOF_VOID_P:INTERNAL=4 //Advanced flag for variable: CMAKE_SKIP_RPATH CMAKE_SKIP_RPATH-ADVANCED:INTERNAL=1 //Whether to build with rpath. CMAKE_SKIP_RPATH:INTERNAL=1 //Result of TRY_COMPILE CMAKE_STD_NAMESPACE:INTERNAL=TRUE //Advanced flag for variable: CMAKE_THREAD_LIBS CMAKE_THREAD_LIBS-ADVANCED:INTERNAL=1 //uname command CMAKE_UNAME:INTERNAL=/bin/uname //Advanced flag for variable: CMAKE_USE_PTHREADS CMAKE_USE_PTHREADS-ADVANCED:INTERNAL=1 //Advanced flag for variable: CMAKE_USE_RELATIVE_PATHS CMAKE_USE_RELATIVE_PATHS-ADVANCED:INTERNAL=1 //Advanced flag for variable: CMAKE_USE_SPROC CMAKE_USE_SPROC-ADVANCED:INTERNAL=1 //Advanced flag for variable: CMAKE_USE_WIN32_THREADS CMAKE_USE_WIN32_THREADS-ADVANCED:INTERNAL=1 //Advanced flag for variable: CMAKE_VERBOSE_MAKEFILE CMAKE_VERBOSE_MAKEFILE-ADVANCED:INTERNAL=1 //Result of TRY_RUN CMAKE_WORDS_BIGENDIAN:INTERNAL=0 //Advanced flag for variable: CMAKE_X_CFLAGS CMAKE_X_CFLAGS-ADVANCED:INTERNAL=1 //Advanced flag for variable: CMAKE_X_LIBS CMAKE_X_LIBS-ADVANCED:INTERNAL=1 //Advanced flag for variable: COMPRESSIONCOMMAND COMPRESSIONCOMMAND-ADVANCED:INTERNAL=1 //Advanced flag for variable: COVERAGE_COMMAND COVERAGE_COMMAND-ADVANCED:INTERNAL=1 //Advanced flag for variable: CVSCOMMAND CVSCOMMAND-ADVANCED:INTERNAL=1 //Advanced flag for variable: CVS_UPDATE_OPTIONS CVS_UPDATE_OPTIONS-ADVANCED:INTERNAL=1 //Path to an executable CommonCxxTests_CMAKE_PATH:INTERNAL=/usr/local/src/vtk/build/ParaView-build/VTK/Common/Testing/Cxx //Path to an executable CommonKWCommonPrintSelf_CMAKE_PATH:INTERNAL=/usr/local/src/vtk/build/ParaView-build/Common/KWCommon/Testing/Cxx //Advanced flag for variable: DART_BUILD_ERROR_REPORT_LIMIT DART_BUILD_ERROR_REPORT_LIMIT-ADVANCED:INTERNAL=1 //Advanced flag for variable: DART_BUILD_WARNING_REPORT_LIMIT DART_BUILD_WARNING_REPORT_LIMIT-ADVANCED:INTERNAL=1 //Advanced flag for variable: DART_ROOT DART_ROOT-ADVANCED:INTERNAL=1 DART_ROOT:INTERNAL= //Advanced flag for variable: DART_TESTING_TIMEOUT DART_TESTING_TIMEOUT-ADVANCED:INTERNAL=1 //Advanced flag for variable: DART_VERBOSE_BUILD DART_VERBOSE_BUILD-ADVANCED:INTERNAL=1 //Advanced flag for variable: DELIVER_CONTINUOUS_EMAIL DELIVER_CONTINUOUS_EMAIL-ADVANCED:INTERNAL=1 //Other test DEV_T_IS_SCALAR:INTERNAL=1 //Advanced flag for variable: EXECUTABLE_OUTPUT_PATH EXECUTABLE_OUTPUT_PATH-ADVANCED:INTERNAL=1 //Single output directory for building all executables. EXECUTABLE_OUTPUT_PATH:INTERNAL=/usr/local/src/vtk/build/ParaView-build/bin //Path to an executable FilteringCxxTests_CMAKE_PATH:INTERNAL=/usr/local/src/vtk/build/ParaView-build/VTK/Filtering/Testing/Cxx //Advanced flag for variable: GUNZIPCOMMAND GUNZIPCOMMAND-ADVANCED:INTERNAL=1 //Path to an executable GenericFilteringCxxTests_CMAKE_PATH:INTERNAL=/usr/local/src/vtk/build/ParaView-build/VTK/GenericFiltering/Testing/Cxx //Path to an executable GraphicsCxxTests_CMAKE_PATH:INTERNAL=/usr/local/src/vtk/build/ParaView-build/VTK/Graphics/Testing/Cxx //Path to an executable H5detect_CMAKE_PATH:INTERNAL=/usr/local/src/vtk/build/ParaView-build/Utilities/hdf5 //Have symbol alloca HAVE_ALLOCA:INTERNAL=1 //Have include HAVE_ALLOCA_H HAVE_ALLOCA_H:INTERNAL=1 //Other test HAVE_ATTRIBUTE:INTERNAL=1 //Result of TRY_COMPILE HAVE_CMAKE_SIZEOF_CHAR:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_CMAKE_SIZEOF_DOUBLE:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_CMAKE_SIZEOF_FLOAT:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_CMAKE_SIZEOF_INT:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_CMAKE_SIZEOF_LONG:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_CMAKE_SIZEOF_SHORT:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_CMAKE_SIZEOF_VOID_P:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_CMAKE_WORDS_BIGENDIAN:INTERNAL=TRUE //Have function difftime HAVE_DIFFTIME:INTERNAL=1 //Have include HAVE_DLFCN_H HAVE_DLFCN_H:INTERNAL=1 //Have include fcntl.h HAVE_FCNTL_H:INTERNAL=1 //Have include HAVE_FEATURES_H HAVE_FEATURES_H:INTERNAL=1 //Have function fork HAVE_FORK:INTERNAL=1 //Have function frexpf HAVE_FREXPF:INTERNAL=1 //Have function frexpl HAVE_FREXPL:INTERNAL=1 //Have function fseek64 HAVE_FSEEK64:INTERNAL= //NetCDF test HAVE_FTRUNCATE:INTERNAL=1 //Other test HAVE_FUNCTION:INTERNAL=1 //Have function gethostname HAVE_GETHOSTNAME:INTERNAL=1 //Have function getpwuid HAVE_GETPWUID:INTERNAL=1 //Have function getrusage HAVE_GETRUSAGE:INTERNAL=1 //Have function gettimeofday HAVE_GETTIMEOFDAY:INTERNAL=1 //Have includes HAVE_GLOBUS_COMMON_H HAVE_GLOBUS_COMMON_H:INTERNAL= //Have include HAVE_INTTYPES_H HAVE_INTTYPES_H:INTERNAL=1 //Have function ioctl HAVE_IOCTL:INTERNAL=1 //Have includes HAVE_IO_H HAVE_IO_H:INTERNAL= //Have library m; HAVE_LIBM:INTERNAL=1 //Have library socket;m HAVE_LIBSOCKET:INTERNAL= //Have library ucb;m HAVE_LIBUCB:INTERNAL= //Have library ws2_32;m HAVE_LIBWS2_32:INTERNAL= //Have library wsock32;m HAVE_LIBWSOCK32:INTERNAL= //Have function longjmp HAVE_LONGJMP:INTERNAL=1 //Have function lseek64 HAVE_LSEEK64:INTERNAL=1 //Have include HAVE_MEMORY_H HAVE_MEMORY_H:INTERNAL=1 //Have includes HAVE_MFHDF_H HAVE_MFHDF_H:INTERNAL= //Have include HAVE_NETDB_H HAVE_NETDB_H:INTERNAL=1 //Have include HAVE_NETINET_TCP_H HAVE_NETINET_TCP_H:INTERNAL=1 //Other test HAVE_OFF64_T:INTERNAL=1 //Have includes HAVE_PDB_H HAVE_PDB_H:INTERNAL= //Have include HAVE_PTHREAD_H HAVE_PTHREAD_H:INTERNAL=1 //Have include HAVE_SETJMP_H HAVE_SETJMP_H:INTERNAL=1 //Have function sigaction HAVE_SIGACTION:INTERNAL=1 //Have function signal HAVE_SIGNAL:INTERNAL=1 //Result of TRY_COMPILE HAVE_SIZEOF_CHAR:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_SIZEOF_DOUBLE:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_SIZEOF_FLOAT:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_SIZEOF_INT:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_SIZEOF_INT16_T:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_SIZEOF_INT32_T:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_SIZEOF_INT64_T:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_SIZEOF_INT8_T:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_SIZEOF_INT_FAST16_T:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_SIZEOF_INT_FAST32_T:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_SIZEOF_INT_FAST64_T:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_SIZEOF_INT_FAST8_T:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_SIZEOF_INT_LEAST16_T:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_SIZEOF_INT_LEAST32_T:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_SIZEOF_INT_LEAST64_T:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_SIZEOF_INT_LEAST8_T:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_SIZEOF_JDSHKJFHDKS:INTERNAL=FALSE //Result of TRY_COMPILE HAVE_SIZEOF_LONG:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_SIZEOF_LONG_DOUBLE:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_SIZEOF_LONG_LONG:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_SIZEOF_OFF_T:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_SIZEOF_PTRDIFF_T:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_SIZEOF_SHORT:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_SIZEOF_SIZE_T:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_SIZEOF_SSIZE_T:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_SIZEOF_UCHAR:INTERNAL=FALSE //Result of TRY_COMPILE HAVE_SIZEOF_UINT16_T:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_SIZEOF_UINT32_T:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_SIZEOF_UINT64_T:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_SIZEOF_UINT8_T:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_SIZEOF_UINT_FAST16_T:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_SIZEOF_UINT_FAST32_T:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_SIZEOF_UINT_FAST64_T:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_SIZEOF_UINT_FAST8_T:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_SIZEOF_UINT_LEAST16_T:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_SIZEOF_UINT_LEAST32_T:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_SIZEOF_UINT_LEAST64_T:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_SIZEOF_UINT_LEAST8_T:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_SIZEOF___INT64:INTERNAL=FALSE //Have function snprintf HAVE_SNPRINTF:INTERNAL=1 //Other test HAVE_SOCKLEN_T:INTERNAL=1 //Have includes HAVE_SRBCLIENT_H HAVE_SRBCLIENT_H:INTERNAL= //Other test HAVE_STAT_ST_BLOCKS:INTERNAL=1 //Have include HAVE_STDDEF_H HAVE_STDDEF_H:INTERNAL=1 //Have include HAVE_STDINT_H HAVE_STDINT_H:INTERNAL=1 //Have include stdint.h HAVE_STDINT_H_CXX:INTERNAL=1 //Have include HAVE_STDIO_H HAVE_STDIO_H:INTERNAL=1 //Have include HAVE_STDLIB_H HAVE_STDLIB_H:INTERNAL=1 //Have function strdup HAVE_STRDUP:INTERNAL=1 //Have symbol strerror HAVE_STRERROR:INTERNAL=1 //Have include HAVE_STRINGS_H HAVE_STRINGS_H:INTERNAL=1 //Have include HAVE_STRING_H HAVE_STRING_H:INTERNAL=1 //Have function strtoll HAVE_STRTOLL:INTERNAL=1 //Other test HAVE_STRUCT_TIMEZONE:INTERNAL=1 //Other test HAVE_STRUCT_TM_TM_ZONE:INTERNAL=1 //NetCDF test HAVE_ST_BLKSIZE:INTERNAL=1 //Have function system HAVE_SYSTEM:INTERNAL=1 //Have includes HAVE_SYS_FILIO_H HAVE_SYS_FILIO_H:INTERNAL= //Have include HAVE_SYS_IOCTL_H HAVE_SYS_IOCTL_H:INTERNAL=1 //Have includes HAVE_SYS_PROC_H HAVE_SYS_PROC_H:INTERNAL= //Have include HAVE_SYS_RESOURCE_H HAVE_SYS_RESOURCE_H:INTERNAL=1 //Have include HAVE_SYS_SOCKET_H HAVE_SYS_SOCKET_H:INTERNAL=1 //Have include HAVE_SYS_STAT_H HAVE_SYS_STAT_H:INTERNAL=1 HAVE_SYS_SYSINFO_H:INTERNAL= //Have include HAVE_SYS_TIMEB_H HAVE_SYS_TIMEB_H:INTERNAL=1 //Have include HAVE_SYS_TIME_H HAVE_SYS_TIME_H:INTERNAL=1 //Have include HAVE_SYS_TYPES_H HAVE_SYS_TYPES_H:INTERNAL=1 //Other test HAVE_TIMEZONE:INTERNAL=1 //Have symbol TIOCGETD HAVE_TIOCGETD:INTERNAL=1 //Have symbol TIOCGWINSZ HAVE_TIOCGWINSZ:INTERNAL=1 //Other test HAVE_TM_GMTOFF:INTERNAL=1 //Other test HAVE_TM_ZONE:INTERNAL=1 //Have include unistd.h HAVE_UNISTD_H:INTERNAL=1 //Have function vsnprintf HAVE_VSNPRINTF:INTERNAL=1 //Result of TRY_COMPILE HAVE_VTK_SIZEOF_LONG_LONG:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_VTK_SIZEOF___INT64:INTERNAL=FALSE //Have function waitpid HAVE_WAITPID:INTERNAL=1 //Have includes HAVE_WINSOCK_H HAVE_WINSOCK_H:INTERNAL= //Result of TRY_COMPILE HAVE_WORDS_BIGENDIAN:INTERNAL=TRUE //Advanced flag for variable: HDF5_ENABLE_HSIZET HDF5_ENABLE_HSIZET-ADVANCED:INTERNAL=1 //Advanced flag for variable: HDF5_ENABLE_LINUX_LFS HDF5_ENABLE_LINUX_LFS-ADVANCED:INTERNAL=1 //Result of TRY_COMPILE HDF5_PRINTF_LL_TEST_COMPILE:INTERNAL=TRUE //Result of TRY_RUN HDF5_PRINTF_LL_TEST_RUN:INTERNAL=0 //Advanced flag for variable: HDF5_STREAM_VFD HDF5_STREAM_VFD-ADVANCED:INTERNAL=1 //This is set from VTK_MPIRUN_EXE. ICET_MPIRUN_EXE:INTERNAL= //This is set from VTK_MPI_MAX_NUMPROCS. ICET_MPI_MAX_NUMPROCS:INTERNAL= //This is set from VTK_MPI_POSTFLAGS. ICET_MPI_POSTFLAGS:INTERNAL= //This is set from a combination of VTK_MPI_NUMPROC_FLAG VTK_MPI_MAX_NUMPROCS // VTK_MPI_PREFLAGS. ICET_MPI_PREFLAGS:INTERNAL=;; //Have include ICE_HAVE_64BIT_STREAMS:INTERNAL= //Advanced flag for variable: ICE_HAVE_FCNTL ICE_HAVE_FCNTL-ADVANCED:INTERNAL=1 //Advanced flag for variable: ICE_HAVE_MMAN ICE_HAVE_MMAN-ADVANCED:INTERNAL=1 //Advanced flag for variable: ICE_HAVE_NETINET ICE_HAVE_NETINET-ADVANCED:INTERNAL=1 //Other test INLINE_TEST___inline:INTERNAL=1 //Other test INLINE_TEST___inline__:INTERNAL=1 //Other test INLINE_TEST_inline:INTERNAL=1 //Path to an executable IOCxxTests_CMAKE_PATH:INTERNAL=/usr/local/src/vtk/build/ParaView-build/VTK/IO/Testing/Cxx //Path to an executable ImagingCxxTests_CMAKE_PATH:INTERNAL=/usr/local/src/vtk/build/ParaView-build/VTK/Imaging/Testing/Cxx //Advanced flag for variable: JAVACOMMAND JAVACOMMAND-ADVANCED:INTERNAL=1 //Path to a library KWCommon_CMAKE_PATH:INTERNAL=/usr/local/src/vtk/build/ParaView-build/Common/KWCommon //include paths for KWCommon KWCommon_INCLUDE_PATH:INTERNAL=/usr/local/src/vtk/ParaView/Common/KWCommon //libraries for KWCommon KWCommon_LIBRARIES:INTERNAL=KWCommon //Path to an executable KWConvertImageToHeader_CMAKE_PATH:INTERNAL=/usr/local/src/vtk/build/ParaView-build/GUI/Widgets/Utilities //Path to an executable KWHelloWorldExample_CMAKE_PATH:INTERNAL=/usr/local/src/vtk/build/ParaView-build/GUI/Widgets/Examples/Cxx/HelloWorld //Path to a library KWMedicalImageViewerExampleLib_CMAKE_PATH:INTERNAL=/usr/local/src/vtk/build/ParaView-build/GUI/Widgets/Examples/Cxx/MedicalImageViewer //Path to an executable KWMedicalImageViewerExample_CMAKE_PATH:INTERNAL=/usr/local/src/vtk/build/ParaView-build/GUI/Widgets/Examples/Cxx/MedicalImageViewer //Path to an executable KWPolygonalObjectViewerExample_CMAKE_PATH:INTERNAL=/usr/local/src/vtk/build/ParaView-build/GUI/Widgets/Examples/Cxx/PolygonalObjectViewer //Result of TRY_COMPILE KWSYS_CXX_HAS_ARGUMENT_DEPENDENT_LOOKUP_COMPILED:INTERNAL=TRUE //Result of TRY_COMPILE KWSYS_CXX_HAS_CSTDDEF_COMPILED:INTERNAL=TRUE //Result of TRY_COMPILE KWSYS_CXX_HAS_FULL_SPECIALIZATION_COMPILED:INTERNAL=TRUE //Result of TRY_COMPILE KWSYS_CXX_HAS_MEMBER_TEMPLATES_COMPILED:INTERNAL=TRUE //Result of TRY_COMPILE KWSYS_CXX_HAS_NULL_TEMPLATE_ARGS_COMPILED:INTERNAL=FALSE //Result of TRY_COMPILE KWSYS_IOS_HAVE_STD_COMPILED:INTERNAL=TRUE //Result of TRY_COMPILE KWSYS_IOS_USE_ANSI_COMPILED:INTERNAL=TRUE //Result of TRY_COMPILE KWSYS_IOS_USE_SSTREAM_COMPILED:INTERNAL=TRUE //Result of TRY_COMPILE KWSYS_STAT_HAS_ST_MTIM_COMPILED:INTERNAL=TRUE //Result of TRY_COMPILE KWSYS_STL_HAS_ALLOCATOR_MAX_SIZE_ARGUMENT_COMPILED:INTERNAL=FALSE //Result of TRY_COMPILE KWSYS_STL_HAS_ALLOCATOR_OBJECTS_COMPILED:INTERNAL=TRUE //Result of TRY_COMPILE KWSYS_STL_HAS_ALLOCATOR_REBIND_COMPILED:INTERNAL=TRUE //Result of TRY_COMPILE KWSYS_STL_HAS_ALLOCATOR_TEMPLATE_COMPILED:INTERNAL=TRUE //Result of TRY_COMPILE KWSYS_STL_HAS_ITERATOR_TRAITS_COMPILED:INTERNAL=TRUE //Result of TRY_COMPILE KWSYS_STL_HAVE_STD_COMPILED:INTERNAL=TRUE //Result of TRY_COMPILE KWSYS_STL_STRING_HAVE_NEQ_CHAR_COMPILED:INTERNAL=TRUE //Path to an executable KWWidgetsTourExample_CMAKE_PATH:INTERNAL=/usr/local/src/vtk/build/ParaView-build/GUI/Widgets/Examples/Cxx/WidgetsTour //Path to a library KWWidgets_CMAKE_PATH:INTERNAL=/usr/local/src/vtk/build/ParaView-build/GUI/Widgets //include paths for KWWidgets KWWidgets_INCLUDE_PATH:INTERNAL=/usr/local/src/vtk/ParaView/GUI/Widgets;/usr/local/src/vtk/build/ParaView-build/GUI/Widgets/AutoGeneratedClasses;/usr/local/src/vtk/build/ParaView-build/GUI/Widgets //libraries for KWWidgets KWWidgets_LIBRARIES:INTERNAL=KWWidgets //Path to an executable KWWindowWithPanelsExample_CMAKE_PATH:INTERNAL=/usr/local/src/vtk/build/ParaView-build/GUI/Widgets/Examples/Cxx/WindowWithPanels //Advanced flag for variable: LIBRARY_OUTPUT_PATH LIBRARY_OUTPUT_PATH-ADVANCED:INTERNAL=1 //Single output directory for building all libraries. LIBRARY_OUTPUT_PATH:INTERNAL=/usr/local/src/vtk/build/ParaView-build/bin //Advanced flag for variable: MAKECOMMAND MAKECOMMAND-ADVANCED:INTERNAL=1 //Path to vtkMaterialLibraryMacro.h MATERIAL_LIBRARY_MATERIAL_MACRO_HEADER:INTERNAL=/usr/local/src/vtk/build/ParaView-build/VTK/Utilities/MaterialLibrary/vtkMaterialLibraryMacro.h //Path to vtkShaderCodeLibraryMacro.h MATERIAL_LIBRARY_SHADER_MACRO_HEADER:INTERNAL=/usr/local/src/vtk/build/ParaView-build/VTK/Utilities/MaterialLibrary/vtkShaderCodeLibraryMacro.h //Advanced flag for variable: MEMORYCHECK_COMMAND MEMORYCHECK_COMMAND-ADVANCED:INTERNAL=1 //Advanced flag for variable: MEMORYCHECK_SUPPRESSIONS_FILE MEMORYCHECK_SUPPRESSIONS_FILE-ADVANCED:INTERNAL=1 //Have library c NOT_NEED_LIBNSL:INTERNAL=1 //Advanced flag for variable: OPENGL_INCLUDE_DIR OPENGL_INCLUDE_DIR-ADVANCED:INTERNAL=1 //Advanced flag for variable: OPENGL_gl_LIBRARY OPENGL_gl_LIBRARY-ADVANCED:INTERNAL=1 //Advanced flag for variable: OPENGL_glu_LIBRARY OPENGL_glu_LIBRARY-ADVANCED:INTERNAL=1 //Advanced flag for variable: OPENGL_xmesa_INCLUDE_DIR OPENGL_xmesa_INCLUDE_DIR-ADVANCED:INTERNAL=1 //Advanced flag for variable: PARAVIEW_ALWAYS_SECURE_CONNECTION // PARAVIEW_ALWAYS_SECURE_CONNECTION-ADVANCED:INTERNAL=1 //Advanced flag for variable: PARAVIEW_BUILD_GUI PARAVIEW_BUILD_GUI-ADVANCED:INTERNAL=1 //Advanced flag for variable: PARAVIEW_BUILD_WITH_ADAPTOR PARAVIEW_BUILD_WITH_ADAPTOR-ADVANCED:INTERNAL=1 //Advanced flag for variable: PARAVIEW_ENABLE_FPE PARAVIEW_ENABLE_FPE-ADVANCED:INTERNAL=1 //Advanced flag for variable: PARAVIEW_EXPERIMENTAL_USER PARAVIEW_EXPERIMENTAL_USER-ADVANCED:INTERNAL=1 //Advanced flag for variable: PARAVIEW_EXTRA_EXTERNAL_MODULES PARAVIEW_EXTRA_EXTERNAL_MODULES-ADVANCED:INTERNAL=1 //Advanced flag for variable: PARAVIEW_TESTING_DART_SERVER PARAVIEW_TESTING_DART_SERVER-ADVANCED:INTERNAL=1 //Advanced flag for variable: PARAVIEW_USE_SAF PARAVIEW_USE_SAF-ADVANCED:INTERNAL=1 //Advanced flag for variable: PARAVIEW_USE_SSLIB_SAF PARAVIEW_USE_SSLIB_SAF-ADVANCED:INTERNAL=1 //Advanced flag for variable: PARAVIEW_USE_SYSTEM_HDF5 PARAVIEW_USE_SYSTEM_HDF5-ADVANCED:INTERNAL=1 //Advanced flag for variable: PARAVIEW_WRAP_PYTHON PARAVIEW_WRAP_PYTHON-ADVANCED:INTERNAL=1 //Width for printf for type `long long' or `__int64', us. `ll PRINTF_LL_WIDTH:INTERNAL="ll" //Advanced flag for variable: PV_TEST_CLEAN_COMMAND PV_TEST_CLEAN_COMMAND-ADVANCED:INTERNAL=1 //Advanced flag for variable: PYTHON_EXECUTABLE PYTHON_EXECUTABLE-ADVANCED:INTERNAL=1 //Path to an executable PrmMagnifyTest_CMAKE_PATH:INTERNAL=/usr/local/src/vtk/build/ParaView-build/VTK/Parallel/Testing/Cxx //Path to an executable ProcessShader-real_CMAKE_PATH:INTERNAL=/usr/local/src/vtk/build/ParaView-build/VTK/Utilities/MaterialLibrary //Path to an executable ProcessShader_CMAKE_PATH:INTERNAL=/usr/local/src/vtk/build/ParaView-build/VTK/Utilities/MaterialLibrary //Path to an executable RenderingCxxTests_CMAKE_PATH:INTERNAL=/usr/local/src/vtk/build/ParaView-build/VTK/Rendering/Testing/Cxx //Advanced flag for variable: SCPCOMMAND SCPCOMMAND-ADVANCED:INTERNAL=1 //Advanced flag for variable: SITE SITE-ADVANCED:INTERNAL=1 //Result of TRY_RUN SIZEOF_CHAR:INTERNAL=1 //Result of TRY_RUN SIZEOF_DOUBLE:INTERNAL=8 //Result of TRY_RUN SIZEOF_FLOAT:INTERNAL=4 //Result of TRY_RUN SIZEOF_INT:INTERNAL=4 //Result of TRY_RUN SIZEOF_INT16_T:INTERNAL=2 //Result of TRY_RUN SIZEOF_INT32_T:INTERNAL=4 //Result of TRY_RUN SIZEOF_INT64_T:INTERNAL=8 //Result of TRY_RUN SIZEOF_INT8_T:INTERNAL=1 //Result of TRY_RUN SIZEOF_INT_FAST16_T:INTERNAL=4 //Result of TRY_RUN SIZEOF_INT_FAST32_T:INTERNAL=4 //Result of TRY_RUN SIZEOF_INT_FAST64_T:INTERNAL=8 //Result of TRY_RUN SIZEOF_INT_FAST8_T:INTERNAL=1 //Result of TRY_RUN SIZEOF_INT_LEAST16_T:INTERNAL=2 //Result of TRY_RUN SIZEOF_INT_LEAST32_T:INTERNAL=4 //Result of TRY_RUN SIZEOF_INT_LEAST64_T:INTERNAL=8 //Result of TRY_RUN SIZEOF_INT_LEAST8_T:INTERNAL=1 //Result of TRY_RUN SIZEOF_LONG:INTERNAL=4 //Result of TRY_RUN SIZEOF_LONG_DOUBLE:INTERNAL=12 //Result of TRY_RUN SIZEOF_LONG_LONG:INTERNAL=8 //Result of TRY_RUN SIZEOF_OFF_T:INTERNAL=4 //Result of TRY_RUN SIZEOF_PTRDIFF_T:INTERNAL=4 //Result of TRY_RUN SIZEOF_SHORT:INTERNAL=2 //Result of TRY_RUN SIZEOF_SIZE_T:INTERNAL=4 //Result of TRY_RUN SIZEOF_SSIZE_T:INTERNAL=4 //Result of TRY_RUN SIZEOF_UINT16_T:INTERNAL=2 //Result of TRY_RUN SIZEOF_UINT32_T:INTERNAL=4 //Result of TRY_RUN SIZEOF_UINT64_T:INTERNAL=8 //Result of TRY_RUN SIZEOF_UINT8_T:INTERNAL=1 //Result of TRY_RUN SIZEOF_UINT_FAST16_T:INTERNAL=4 //Result of TRY_RUN SIZEOF_UINT_FAST32_T:INTERNAL=4 //Result of TRY_RUN SIZEOF_UINT_FAST64_T:INTERNAL=8 //Result of TRY_RUN SIZEOF_UINT_FAST8_T:INTERNAL=1 //Result of TRY_RUN SIZEOF_UINT_LEAST16_T:INTERNAL=2 //Result of TRY_RUN SIZEOF_UINT_LEAST32_T:INTERNAL=4 //Result of TRY_RUN SIZEOF_UINT_LEAST64_T:INTERNAL=8 //Result of TRY_RUN SIZEOF_UINT_LEAST8_T:INTERNAL=1 //Path to a library SPCTH_CMAKE_PATH:INTERNAL=/usr/local/src/vtk/build/ParaView-build/Utilities/SPCTH //Have include STDC_HEADERS STDC_HEADERS:INTERNAL=1 //Advanced flag for variable: SVNCOMMAND SVNCOMMAND-ADVANCED:INTERNAL=1 //Other test SYSTEM_SCOPE_THREADS:INTERNAL=1 //Path to an executable ServersCommonPrintSelf_CMAKE_PATH:INTERNAL=/usr/local/src/vtk/build/ParaView-build/Servers/Common/Testing/Cxx //Path to an executable ServersFiltersPrintSelf_CMAKE_PATH:INTERNAL=/usr/local/src/vtk/build/ParaView-build/Servers/Filters/Testing/Cxx //Path to an executable ServersServerManagerPrintSelf_CMAKE_PATH:INTERNAL=/usr/local/src/vtk/build/ParaView-build/Servers/ServerManager/Testing/Cxx //Path to an executable SocketClient_CMAKE_PATH:INTERNAL=/usr/local/src/vtk/build/ParaView-build/VTK/Parallel/Testing/Cxx //Path to an executable SocketServer_CMAKE_PATH:INTERNAL=/usr/local/src/vtk/build/ParaView-build/VTK/Parallel/Testing/Cxx //Path to tcl include TCL_INCLUDE_PATH:INTERNAL=/usr/local/src/vtk/ParaView/Utilities/TclTk/tcl8.4.5/generic //Path to tcl library TCL_LIBRARY:INTERNAL=/usr/local/src/vtk/build/ParaView-build/Utilities/TclTk/tcl8.4.5/unix/libtcl8.4.a //Advanced flag for variable: TCL_STUB_LIBRARY TCL_STUB_LIBRARY-ADVANCED:INTERNAL=1 //Path to tcl stub library TCL_STUB_LIBRARY:INTERNAL=/usr/local/src/vtk/build/ParaView-build/Utilities/TclTk/tcl8.4.5/unix/libtclstub8.4.a //Advanced flag for variable: TCL_STUB_LIBRARY_DEBUG TCL_STUB_LIBRARY_DEBUG-ADVANCED:INTERNAL=1 //Advanced flag for variable: TCL_TCLSH TCL_TCLSH-ADVANCED:INTERNAL=1 //Advanced flag for variable: TEST_MP2_WRITER TEST_MP2_WRITER-ADVANCED:INTERNAL=1 //Other test TIME_WITH_SYS_TIME:INTERNAL=1 //Path to tk include TK_INCLUDE_PATH:INTERNAL=/usr/local/src/vtk/ParaView/Utilities/TclTk/tk8.4.5/generic //Path to tk library TK_LIBRARY:INTERNAL=/usr/local/src/vtk/build/ParaView-build/Utilities/TclTk/tk8.4.5/unix/libtk8.4.a //Advanced flag for variable: TK_STUB_LIBRARY TK_STUB_LIBRARY-ADVANCED:INTERNAL=1 //Path to tk stub library TK_STUB_LIBRARY:INTERNAL=/usr/local/src/vtk/build/ParaView-build/Utilities/TclTk/tk8.4.5/unix/libtkstub8.4.a //Advanced flag for variable: TK_STUB_LIBRARY_DEBUG TK_STUB_LIBRARY_DEBUG-ADVANCED:INTERNAL=1 //Path to an executable TestCommandLineArguments_CMAKE_PATH:INTERNAL=/usr/local/src/vtk/build/ParaView-build/Common/KWCommon/Testing/Cxx //Path to an executable TestContinuousClose3D_CMAKE_PATH:INTERNAL=/usr/local/src/vtk/build/ParaView-build/Servers/Filters/Testing/Cxx //Path to an executable TestCxxFeatures_CMAKE_PATH:INTERNAL=/usr/local/src/vtk/build/ParaView-build/VTK/Common/Testing/Cxx //Path to an executable TestInstantiator_CMAKE_PATH:INTERNAL=/usr/local/src/vtk/build/ParaView-build/VTK/Common/Testing/Cxx //Path to an executable TestMPI_CMAKE_PATH:INTERNAL=/usr/local/src/vtk/build/ParaView-build/Servers/Filters/Testing/Cxx //Path to an executable TestMemory_CMAKE_PATH:INTERNAL=/usr/local/src/vtk/build/ParaView-build/Common/KWCommon/Testing/Cxx //Path to an executable TestPVFilters_CMAKE_PATH:INTERNAL=/usr/local/src/vtk/build/ParaView-build/Servers/Filters/Testing/Cxx //Path to an executable TestRandom_CMAKE_PATH:INTERNAL=/usr/local/src/vtk/build/ParaView-build/GUI/Widgets/Testing/Cxx //Path to an executable TestRegistry_CMAKE_PATH:INTERNAL=/usr/local/src/vtk/build/ParaView-build/GUI/Widgets/Testing/Cxx //Path to an executable TestRemoteProcess_CMAKE_PATH:INTERNAL=/usr/local/src/vtk/build/ParaView-build/Common/KWCommon/Testing/Cxx //Path to an executable TimeRenderer2_CMAKE_PATH:INTERNAL=/usr/local/src/vtk/build/ParaView-build/VTK/Rendering/Testing/Cxx //Path to an executable TimeRenderer_CMAKE_PATH:INTERNAL=/usr/local/src/vtk/build/ParaView-build/VTK/Rendering/Testing/Cxx //Path to an executable VTKBenchMark_CMAKE_PATH:INTERNAL=/usr/local/src/vtk/build/ParaView-build/VTK/Rendering/Testing/Cxx //Result of TRY_COMPILE VTK_ANSI_STREAM_EOF_COMPILED:INTERNAL=TRUE //Result of TRY_RUN VTK_ANSI_STREAM_EOF_RESULT:INTERNAL=0 VTK_CMAKE_DIR:INTERNAL=/usr/local/src/vtk/ParaView/VTK/CMake //Support for C++ type bool VTK_COMPILER_HAS_BOOL:INTERNAL=1 //Support for full template specialization syntax VTK_COMPILER_HAS_FULL_SPECIALIZATION:INTERNAL=1 //Advanced flag for variable: VTK_DATA_ROOT VTK_DATA_ROOT-ADVANCED:INTERNAL=1 //Advanced flag for variable: VTK_DEBUG_LEAKS VTK_DEBUG_LEAKS-ADVANCED:INTERNAL=1 //The directory in which code for Shaders is provided. VTK_DEFAULT_SHADERS_DIR:INTERNAL=/usr/local/src/vtk/build/ParaView-build/VTK/Utilities/MaterialLibrary/Repository VTK_DIR:INTERNAL=/usr/local/src/vtk/build/ParaView-build/VTK //Support for C++ explict templates VTK_EXPLICIT_TEMPLATES:INTERNAL=1 //Advanced flag for variable: VTK_GLEXT_FILE VTK_GLEXT_FILE-ADVANCED:INTERNAL=1 //Advanced flag for variable: VTK_GLXEXT_FILE VTK_GLXEXT_FILE-ADVANCED:INTERNAL=1 //Result of TRY_COMPILE VTK_GLX_GET_PROC_ADDRESS_ARB_PROTOTYPE_EXISTS:INTERNAL=TRUE //Already set VTK_GLX_GET_PROC_ADDRESS_ARB_PROTOTYPE_EXISTS VTK_GLX_GET_PROC_ADDRESS_ARB_PROTOTYPE_EXISTS_TESTED:INTERNAL=1 //Have include iosfwd VTK_HAVE_ANSI_STREAMS:INTERNAL=1 //Support for getsockname with socklen_t VTK_HAVE_GETSOCKNAME_WITH_SOCKLEN_T:INTERNAL=1 //Have library socket VTK_HAVE_LIBSOCKET:INTERNAL= //Have include iostream.h VTK_HAVE_OLD_STREAMS:INTERNAL=1 //Have include strstream.h VTK_HAVE_OLD_STRSTREAM_H:INTERNAL= //Have include strstrea.h VTK_HAVE_OLD_STRSTREA_H:INTERNAL= //Whether istream supports long long VTK_ISTREAM_SUPPORTS_LONG_LONG:INTERNAL=1 //Advanced flag for variable: VTK_LEGACY_REMOVE VTK_LEGACY_REMOVE-ADVANCED:INTERNAL=1 //Advanced flag for variable: VTK_LEGACY_SILENT VTK_LEGACY_SILENT-ADVANCED:INTERNAL=1 //Advanced flag for variable: VTK_MATERIALS_DIRS VTK_MATERIALS_DIRS-ADVANCED:INTERNAL=1 //Advanced flag for variable: VTK_OPENGL_HAS_OSMESA VTK_OPENGL_HAS_OSMESA-ADVANCED:INTERNAL=1 //Whether ostream supports long long VTK_OSTREAM_SUPPORTS_LONG_LONG:INTERNAL=1 //OpenGL extensions parser. VTK_PARSEOGLEXT_EXE:INTERNAL=/usr/local/src/vtk/build/ParaView-build/bin/vtkParseOGLExt //Result of TRY_RUN VTK_SIZEOF_LONG_LONG:INTERNAL=8 //ParaView links against its own version of Tcl/TK VTK_TCL_TK_COPY_SUPPORT_LIBRARY:INTERNAL=1 //Build with static Tcl/Tk support. TCL_LIBRARY and TK_LIBRARY // must point to the corresponding Tcl/Tk static libraries (example, // tcl84sx.lib, tk84sx.lib). VTK_TCL_TK_STATIC:INTERNAL=1 //Whether char is signed. VTK_TYPE_CHAR_IS_SIGNED:INTERNAL=1 //Result of TRY_COMPILE VTK_TYPE_CHAR_IS_SIGNED_COMPILED:INTERNAL=TRUE //Advanced flag for variable: VTK_USE_64BIT_IDS VTK_USE_64BIT_IDS-ADVANCED:INTERNAL=1 //Advanced flag for variable: VTK_USE_DISPLAY VTK_USE_DISPLAY-ADVANCED:INTERNAL=1 //Have function glXGetProcAddressARB VTK_USE_GLX_GET_PROC_ADDRESS_ARB:INTERNAL=1 //Advanced flag for variable: VTK_USE_GUISUPPORT VTK_USE_GUISUPPORT-ADVANCED:INTERNAL=1 //Advanced flag for variable: VTK_USE_MANGLED_MESA VTK_USE_MANGLED_MESA-ADVANCED:INTERNAL=1 //Advanced flag for variable: VTK_USE_MATROX_IMAGING VTK_USE_MATROX_IMAGING-ADVANCED:INTERNAL=1 //Use Matrox Imaging Library for video input. VTK_USE_MATROX_IMAGING:INTERNAL=OFF //Advanced flag for variable: VTK_USE_MPI VTK_USE_MPI-ADVANCED:INTERNAL=1 //Build the vtkRendering kit. Needed for displaying data or using // widgets. VTK_USE_RENDERING:INTERNAL=ON //Modified flag for variable: VTK_USE_RPATH VTK_USE_RPATH-MODIFIED:INTERNAL=1 //Advanced flag for variable: VTK_USE_SYSTEM_EXPAT VTK_USE_SYSTEM_EXPAT-ADVANCED:INTERNAL=1 //Advanced flag for variable: VTK_USE_SYSTEM_FREETYPE VTK_USE_SYSTEM_FREETYPE-ADVANCED:INTERNAL=1 //Advanced flag for variable: VTK_USE_SYSTEM_JPEG VTK_USE_SYSTEM_JPEG-ADVANCED:INTERNAL=1 //Advanced flag for variable: VTK_USE_SYSTEM_PNG VTK_USE_SYSTEM_PNG-ADVANCED:INTERNAL=1 //Advanced flag for variable: VTK_USE_SYSTEM_TIFF VTK_USE_SYSTEM_TIFF-ADVANCED:INTERNAL=1 //Advanced flag for variable: VTK_USE_SYSTEM_ZLIB VTK_USE_SYSTEM_ZLIB-ADVANCED:INTERNAL=1 //Advanced flag for variable: VTK_WGLEXT_FILE VTK_WGLEXT_FILE-ADVANCED:INTERNAL=1 //Advanced flag for variable: VTK_WRAP_ClientServer_EXE VTK_WRAP_ClientServer_EXE-ADVANCED:INTERNAL=1 //Advanced flag for variable: VTK_WRAP_HINTS VTK_WRAP_HINTS-ADVANCED:INTERNAL=1 //Wrap VTK classes into the Java language. VTK_WRAP_JAVA:INTERNAL=OFF //Wrap VTK classes into the Python language. VTK_WRAP_PYTHON:INTERNAL=OFF //Wrap VTK classes into the TCL language. VTK_WRAP_TCL:INTERNAL=OFF //Location of program to do tcl wrapping VTK_WRAP_TCL_EXE:INTERNAL=/usr/local/src/vtk/build/ParaView-build/bin/vtkWrapTcl //Location of program to do tcl wrapping VTK_WRAP_TCL_INIT_EXE:INTERNAL=/usr/local/src/vtk/build/ParaView-build/bin/vtkWrapTclInit //Path to an executable VolumeRenderingCxxTests_CMAKE_PATH:INTERNAL=/usr/local/src/vtk/build/ParaView-build/VTK/VolumeRendering/Testing/Cxx //Result of TRY_RUN WORDS_BIGENDIAN:INTERNAL=0 //Path to an executable WidgetsCxxTests_CMAKE_PATH:INTERNAL=/usr/local/src/vtk/build/ParaView-build/VTK/Widgets/Testing/Cxx //Have library /usr/X11R6/lib/libX11.so;/usr/X11R6/lib/libXext.so // X11_LIB_X11_SOLO:INTERNAL=1 //Advanced flag for variable: X11_X11_INCLUDE_PATH X11_X11_INCLUDE_PATH-ADVANCED:INTERNAL=1 //Advanced flag for variable: X11_X11_LIB X11_X11_LIB-ADVANCED:INTERNAL=1 //Advanced flag for variable: X11_Xext_LIB X11_Xext_LIB-ADVANCED:INTERNAL=1 //Advanced flag for variable: X11_Xlib_INCLUDE_PATH X11_Xlib_INCLUDE_PATH-ADVANCED:INTERNAL=1 //Advanced flag for variable: X11_Xutil_INCLUDE_PATH X11_Xutil_INCLUDE_PATH-ADVANCED:INTERNAL=1 //Advanced flag for variable: XDMF_HAS_NDGM XDMF_HAS_NDGM-ADVANCED:INTERNAL=1 //Have include malloc.h XDMF_HAVE_MALLOC_H:INTERNAL=1 //Advanced flag for variable: XDMF_REGENERATE_WRAPPERS XDMF_REGENERATE_WRAPPERS-ADVANCED:INTERNAL=1 //Regenerate XdmfPython.cxx XdmfTcl.cxx and XdmfJava.cxx XDMF_REGENERATE_WRAPPERS:INTERNAL=OFF //Advanced flag for variable: XDMF_REGENERATE_YACCLEX XDMF_REGENERATE_YACCLEX-ADVANCED:INTERNAL=1 //Regenerate XdmfExprYacc.cxx and XdmfExprLex.cxx XDMF_REGENERATE_YACCLEX:INTERNAL=OFF //Build a Python wrapping interface XDMF_WRAP_PYTHON:INTERNAL=OFF //Build a TCL wrapping interface XDMF_WRAP_TCL:INTERNAL=OFF //Path to a library Xdmf_CMAKE_PATH:INTERNAL=/usr/local/src/vtk/build/ParaView-build/Utilities/Xdmf/libsrc //Path to an executable kwProcessXML-real_CMAKE_PATH:INTERNAL=/usr/local/src/vtk/build/ParaView-build/Common/KWCommon //Path to an executable kwProcessXML_CMAKE_PATH:INTERNAL=/usr/local/src/vtk/build/ParaView-build/Common/KWCommon //Path to an executable mkg3states_CMAKE_PATH:INTERNAL=/usr/local/src/vtk/build/ParaView-build/VTK/Utilities/vtktiff //Path to an executable paraview-real_CMAKE_PATH:INTERNAL=/usr/local/src/vtk/build/ParaView-build/GUI/Client //Path to an executable paraview_CMAKE_PATH:INTERNAL=/usr/local/src/vtk/build/ParaView-build/GUI/Client //Path to an executable pvTestDriver-real_CMAKE_PATH:INTERNAL=/usr/local/src/vtk/build/ParaView-build/GUI/Client //Path to an executable pvTestDriver_CMAKE_PATH:INTERNAL=/usr/local/src/vtk/build/ParaView-build/GUI/Client //Path to an executable pvbatch-real_CMAKE_PATH:INTERNAL=/usr/local/src/vtk/build/ParaView-build/Servers/Executables //Path to an executable pvbatch_CMAKE_PATH:INTERNAL=/usr/local/src/vtk/build/ParaView-build/Servers/Executables //Path to an executable pvclient-real_CMAKE_PATH:INTERNAL=/usr/local/src/vtk/build/ParaView-build/GUI/Client //Path to an executable pvclient_CMAKE_PATH:INTERNAL=/usr/local/src/vtk/build/ParaView-build/GUI/Client //Path to an executable pvdataserver-real_CMAKE_PATH:INTERNAL=/usr/local/src/vtk/build/ParaView-build/Servers/Executables //Path to an executable pvdataserver_CMAKE_PATH:INTERNAL=/usr/local/src/vtk/build/ParaView-build/Servers/Executables //Path to an executable pvrenderserver-real_CMAKE_PATH:INTERNAL=/usr/local/src/vtk/build/ParaView-build/Servers/Executables //Path to an executable pvrenderserver_CMAKE_PATH:INTERNAL=/usr/local/src/vtk/build/ParaView-build/Servers/Executables //Path to an executable pvserver-real_CMAKE_PATH:INTERNAL=/usr/local/src/vtk/build/ParaView-build/Servers/Executables //Path to an executable pvserver_CMAKE_PATH:INTERNAL=/usr/local/src/vtk/build/ParaView-build/Servers/Executables //Path to a library vtkClientServer_CMAKE_PATH:INTERNAL=/usr/local/src/vtk/build/ParaView-build/Utilities/VTKClientServer //Path to a library vtkCommonCS_CMAKE_PATH:INTERNAL=/usr/local/src/vtk/build/ParaView-build/Utilities/VTKClientServer/Common //Path to a library vtkCommonTCL_CMAKE_PATH:INTERNAL=/usr/local/src/vtk/build/ParaView-build/Utilities/VTKTclWrapping //Path to a library vtkCommon_CMAKE_PATH:INTERNAL=/usr/local/src/vtk/build/ParaView-build/VTK/Common //Path to a library vtkDICOMParser_CMAKE_PATH:INTERNAL=/usr/local/src/vtk/build/ParaView-build/VTK/Utilities/DICOMParser //Path to a library vtkFilteringCS_CMAKE_PATH:INTERNAL=/usr/local/src/vtk/build/ParaView-build/Utilities/VTKClientServer/Filtering //Path to a library vtkFiltering_CMAKE_PATH:INTERNAL=/usr/local/src/vtk/build/ParaView-build/VTK/Filtering //Path to a library vtkGenericFilteringCS_CMAKE_PATH:INTERNAL=/usr/local/src/vtk/build/ParaView-build/Utilities/VTKClientServer/GenericFiltering //Path to a library vtkGenericFiltering_CMAKE_PATH:INTERNAL=/usr/local/src/vtk/build/ParaView-build/VTK/GenericFiltering //Path to a library vtkGraphicsCS_CMAKE_PATH:INTERNAL=/usr/local/src/vtk/build/ParaView-build/Utilities/VTKClientServer/Graphics //Path to a library vtkGraphics_CMAKE_PATH:INTERNAL=/usr/local/src/vtk/build/ParaView-build/VTK/Graphics //Path to a library vtkHybridCS_CMAKE_PATH:INTERNAL=/usr/local/src/vtk/build/ParaView-build/Utilities/VTKClientServer/Hybrid //Path to a library vtkHybrid_CMAKE_PATH:INTERNAL=/usr/local/src/vtk/build/ParaView-build/VTK/Hybrid //Path to a library vtkIOCS_CMAKE_PATH:INTERNAL=/usr/local/src/vtk/build/ParaView-build/Utilities/VTKClientServer/IO //Path to a library vtkIO_CMAKE_PATH:INTERNAL=/usr/local/src/vtk/build/ParaView-build/VTK/IO //Path to a library vtkImagingCS_CMAKE_PATH:INTERNAL=/usr/local/src/vtk/build/ParaView-build/Utilities/VTKClientServer/Imaging //Path to a library vtkImaging_CMAKE_PATH:INTERNAL=/usr/local/src/vtk/build/ParaView-build/VTK/Imaging //Path to a library vtkKWParaViewCS_CMAKE_PATH:INTERNAL=/usr/local/src/vtk/build/ParaView-build/GUI/Client //Path to a library vtkKWParaView_CMAKE_PATH:INTERNAL=/usr/local/src/vtk/build/ParaView-build/GUI/Client //Path to a library vtkMPEG2Encode_CMAKE_PATH:INTERNAL=/usr/local/src/vtk/build/ParaView-build/VTK/Utilities/vtkmpeg2encode //include paths for vtkMPEG2Encode vtkMPEG2Encode_INCLUDE_PATH:INTERNAL=/usr/local/src/vtk/ParaView/VTK/Utilities/vtkmpeg2encode //libraries for vtkMPEG2Encode vtkMPEG2Encode_LIBRARIES:INTERNAL=vtkMPEG2Encode //Path to a library vtkNetCDF_CMAKE_PATH:INTERNAL=/usr/local/src/vtk/build/ParaView-build/VTK/Utilities/vtknetcdf //Path to a library vtkPVFiltersCS_CMAKE_PATH:INTERNAL=/usr/local/src/vtk/build/ParaView-build/Servers/Filters //Path to a library vtkPVFilters_CMAKE_PATH:INTERNAL=/usr/local/src/vtk/build/ParaView-build/Servers/Filters //Path to a library vtkPVServerCommonCS_CMAKE_PATH:INTERNAL=/usr/local/src/vtk/build/ParaView-build/Servers/Common //Path to a library vtkPVServerCommonTCL_CMAKE_PATH:INTERNAL=/usr/local/src/vtk/build/ParaView-build/Servers/Common //Path to a library vtkPVServerCommon_CMAKE_PATH:INTERNAL=/usr/local/src/vtk/build/ParaView-build/Servers/Common //Path to a library vtkPVServerManagerTCL_CMAKE_PATH:INTERNAL=/usr/local/src/vtk/build/ParaView-build/Servers/ServerManager //Path to a library vtkPVServerManager_CMAKE_PATH:INTERNAL=/usr/local/src/vtk/build/ParaView-build/Servers/ServerManager //Path to a library vtkParallelCS_CMAKE_PATH:INTERNAL=/usr/local/src/vtk/build/ParaView-build/Utilities/VTKClientServer/Parallel //Path to a library vtkParallel_CMAKE_PATH:INTERNAL=/usr/local/src/vtk/build/ParaView-build/VTK/Parallel //Path to an executable vtkParseOGLExt_CMAKE_PATH:INTERNAL=/usr/local/src/vtk/build/ParaView-build/VTK/Utilities/ParseOGLExt //Path to a library vtkRenderingCS_CMAKE_PATH:INTERNAL=/usr/local/src/vtk/build/ParaView-build/Utilities/VTKClientServer/Rendering //Path to a library vtkRendering_CMAKE_PATH:INTERNAL=/usr/local/src/vtk/build/ParaView-build/VTK/Rendering //Path to an executable vtkVREncodeString_CMAKE_PATH:INTERNAL=/usr/local/src/vtk/build/ParaView-build/VTK/VolumeRendering //Path to a library vtkVolumeRenderingCS_CMAKE_PATH:INTERNAL=/usr/local/src/vtk/build/ParaView-build/Utilities/VTKClientServer/VolumeRendering //Path to a library vtkVolumeRendering_CMAKE_PATH:INTERNAL=/usr/local/src/vtk/build/ParaView-build/VTK/VolumeRendering //Path to a library vtkWidgetsCS_CMAKE_PATH:INTERNAL=/usr/local/src/vtk/build/ParaView-build/Utilities/VTKClientServer/Widgets //Path to a library vtkWidgets_CMAKE_PATH:INTERNAL=/usr/local/src/vtk/build/ParaView-build/VTK/Widgets //Path to an executable vtkWrapClientServer_CMAKE_PATH:INTERNAL=/usr/local/src/vtk/build/ParaView-build/Utilities/VTKClientServer/Wrapping //Path to an executable vtkWrapTclInit_CMAKE_PATH:INTERNAL=/usr/local/src/vtk/build/ParaView-build/Utilities/VTKTclWrapping //Path to an executable vtkWrapTcl_CMAKE_PATH:INTERNAL=/usr/local/src/vtk/build/ParaView-build/Utilities/VTKTclWrapping //Path to a library vtkXdmfCS_CMAKE_PATH:INTERNAL=/usr/local/src/vtk/build/ParaView-build/Utilities/VTKClientServer/Xdmf //Path to a library vtkXdmf_CMAKE_PATH:INTERNAL=/usr/local/src/vtk/build/ParaView-build/Utilities/Xdmf/vtk //Path to a library vtkexoIIc_CMAKE_PATH:INTERNAL=/usr/local/src/vtk/build/ParaView-build/VTK/Utilities/vtkexodus2 //Path to a library vtkexpat_CMAKE_PATH:INTERNAL=/usr/local/src/vtk/build/ParaView-build/VTK/Utilities/vtkexpat //Path to a library vtkfreetype_CMAKE_PATH:INTERNAL=/usr/local/src/vtk/build/ParaView-build/VTK/Utilities/vtkfreetype //Path to a library vtkftgl_CMAKE_PATH:INTERNAL=/usr/local/src/vtk/build/ParaView-build/VTK/Utilities/ftgl //Path to a library vtkhdf5_CMAKE_PATH:INTERNAL=/usr/local/src/vtk/build/ParaView-build/Utilities/hdf5 //Path to a library vtkjpeg_CMAKE_PATH:INTERNAL=/usr/local/src/vtk/build/ParaView-build/VTK/Utilities/vtkjpeg //Path to a library vtkpng_CMAKE_PATH:INTERNAL=/usr/local/src/vtk/build/ParaView-build/VTK/Utilities/vtkpng //Path to a library vtksys_CMAKE_PATH:INTERNAL=/usr/local/src/vtk/build/ParaView-build/VTK/Utilities/kwsys //Path to a library vtktiff_CMAKE_PATH:INTERNAL=/usr/local/src/vtk/build/ParaView-build/VTK/Utilities/vtktiff //Path to a library vtkzlib_CMAKE_PATH:INTERNAL=/usr/local/src/vtk/build/ParaView-build/VTK/Utilities/vtkzlib | ||||||||
There are no notes attached to this issue. |
