0002791 | ParaView | (No Category) | public | 2006-01-30 11:09 | 2009-12-09 14:51 | ||||
Reporter | Gary Templet | ||||||||
Summary | 0002791: SNL: Add Material/Shader support to ParaView | ||||||||
Description | Allow users to apply library and possibly repository materials through ParaView's 'Display' gui tab. | ||||||||
(0003660) Utkarsh Ayachit (administrator) 2006-01-31 14:58 |
Added support for library materials. |
(0003670) Utkarsh Ayachit (administrator) 2006-02-02 16:00 |
I've committed changes to allow loading of material xml. There's one caveat: In client-server mode, the material file is located on the client and the contents of the xml are sent to the server(s). However, only the material xml is sent, no attempt is to send the actual code for the shader(s) used by the material. Thus, only material xmls that use the library or repository shaders or have shader code inline, can be loaded successfully in client-server mode. |
