0002838 | ParaView | (No Category) | public | 2006-02-06 18:33 | 2009-12-09 14:51 | ||||
Reporter | Gary Templet | ||||||||
Summary | 0002838: SNL: Materials and Actor Control | ||||||||
Description | When a material is applied to an object it's 'Actor Control' settings are ignored. For example, once an object is applied the user can no longer translate the object with widgets in the 'Actor Control' box. | ||||||||
(0005456) Amy Squillacote (reporter) 2006-10-18 13:31 |
Since this a problem with the shaders and not with the GUI, I am assigning this bug to Utkarsh; it will be more efficient for him to fix it since he knows the shader code well. |
(0005457) Ken Moreland (manager) 2006-10-18 15:18 |
Don't spend more than 1 hour on this. If it takes longer, downgrade this bug to a 2 and get it after ParaView 2.6. |
(0005673) Utkarsh Ayachit (administrator) 2006-11-08 11:16 |
vtkOpenGLActor::Render() has the responsibility of pushing the actor transformations on the Model-View stack. However, in case of CG, the model view matrices are passed as unformarms in the vtkShader::PassShaderVariables() which happens before vtkOpenGLActor::Render(). Hence in CgShader, we override PassShaderVariables() to explicitly push actor transformations. /cvsroot/ParaView/ParaView/VTK/Rendering/vtkCgShader.cxx,v <-- vtkCgShader.cxx new revision: 1.7; previous revision: 1.6 /cvsroot/ParaView/ParaView/VTK/Rendering/vtkCgShader.h,v <-- vtkCgShader.h new revision: 1.8; previous revision: 1.7 /cvsroot/ParaView/ParaView/VTK/Rendering/vtkShader.cxx,v <-- vtkShader.cxx new revision: 1.23; previous revision: 1.22 |
