0002839 | ParaView | (No Category) | public | 2006-02-07 07:04 | 2016-08-12 09:57 | ||||
Reporter | Johnny DP | ||||||||
Summary | 0002839: Ensight Gold File reader - parallel | ||||||||
Description | 1) I am loadiing an ensight gold file (.case) while running paraview in parallel (client/server mode) through MPI. Paraview seems to use the EnsightMasterServerReader though the file is not in master server(.sos) format and partition the file across the different processes in the mpirun. Is this the default behavior? I have attached the .case file with this report. 2) Is there a limitation on the size of the file with regard to the available memory in the node? Thank you Johnny. | ||||||||
Attached Files | mqt_room_1_58M.case [^] (259 bytes) 1969-12-31 19:00 | ||||||||
(0037492) Kitware Robot (administrator) 2016-08-12 09:57 |
2016-08-12 09:57 | Kitware Robot | Note Added: 0037492 | |
