0003019 | ParaView | (No Category) | public | 2006-03-28 10:48 | 2007-08-14 09:05 | ||||
Reporter | David Rogers | ||||||||
Summary | 0003019: Element Inspector: add capability to handly large data quickly | ||||||||
Description | Element Inspector: add capability to handly large data quickly | ||||||||
(0004679) Berk Geveci (administrator) 2006-08-17 15:21 |
I don't know what this means. |
(0004690) Clinton Stimpson (developer) 2006-08-18 08:42 |
It meant that we pull data from the server only as it is viewed in a Qt View (as in model/view). So pqDataSetModel currently wraps a vtkDataSet in a Qt model. And that method requires all the data to be on the client side for it to work. If we're going to assume that's not going to be a problem, for whatever reason, then we don't need this feature request. |
(0004692) Berk Geveci (administrator) 2006-08-18 09:18 |
Ah, I understand now. It would be awesome to have this feature in the long run. It would allow users to browse their data or a large selection on the client (or with the python client). I will keep this as low priority. We should bring it up after our first pass is done. Around October-November maybe. |
(0008431) Berk Geveci (administrator) 2007-08-13 15:05 |
Spreadsheet view can do this. |
(0008448) Ken Moreland (manager) 2007-08-14 09:05 |
... and spreadsheet view is going to replace the element inspector. Very soon there will be a button to allow you to look at only the selection rather than everything. |
2007-08-13 15:05 | Berk Geveci | Note Added: 0008431 | |
2007-08-13 15:05 | Berk Geveci | Status | tabled => @80@ |
2007-08-13 15:05 | Berk Geveci | Resolution | open => fixed |
2007-08-14 09:05 | Ken Moreland | Status | @80@ => closed |
2007-08-14 09:05 | Ken Moreland | Note Added: 0008448 | |
