0003020 | ParaView | (No Category) | public | 2006-03-28 11:03 | 2006-11-22 16:35 | ||||
Reporter | David Rogers | ||||||||
Assigned To | Timothy Shead | ||||||||
Summary | 0003020: Create a way for the checkin process to verify that all Qt widgets are named. | ||||||||
Description | Create a way for the checkin process to verify that all Qt widgets are named. | ||||||||
(0003982) Timothy Shead (reporter) 2006-04-07 20:02 |
Static checking at checkin time turned-out impractical, due to the variety of ways Qt objects can be named (through the API, in forms, dynamically-generated, etc), so I added support for explicit runtime checking of the Qt object tree, plus better debugging output during test recording. |
